Question about Echo Inc. 44 CC, Carb Certified Backpack Blower
Fuel mix ratio echo pb-413h leaf blower - Echo Inc. 44 CC, Carb Certified Backpack Blower
localwonder
  • 6784 Answers
SOURCE: oil gas mixture of model pb-2100 echo leaf blower
GAS-- Use 89 octane r+m over 2 (mid grade or higher) This gasoline known to be good quality. Gasoline may contain up 10 15% MTBE (methyltertiary-butyl ether). Gasohol containig methyl alcohol is not approved.
TWO STROKE OIL-- 50: 1 is usable.
please rate and god bless.
Posted on Mar 27, 2009
  • 413 Answers
SOURCE: echo pb 200 leaf blower want start
Turn on ignition switch, Choke, prime bulb 5 times (or until fuel flows), hold throttle down and pull starter cord sharply until it tries to start, then place choke in mid position pull cord sharply again until it runs then move choke to off when it will allow it.
Also you can go to toro.com then customer care, then manuals and parts then type in model no. and download an owners manual.
Posted on Apr 06, 2009
97F350diesel
  • 1326 Answers
SOURCE: I have a Echo PB 2601 made a loud bang then stoped working.
Sounds like it has seized up. If the pull cord won't pull then the motor is locked up. Did you run gas/oil mix for the fuel its a 2 cycle motor...
Posted on Sep 25, 2009
taran_2005
  • 10515 Answers
SOURCE: what is the correct oil to gas ratio for an Echo
Fuel/oil mix ratio should be 32to1 or 32 ounces gasoline to 1 ounce oil.
Thanks!!
Posted on Nov 04, 2009
Testimonial: "Very prompt answer."
  • 198 Answers
SOURCE: First time to add gasoline, I am not sure how to
50:1 means 50 parts gas to 1 part oil
you can mix a quart of gas with 1.5 oz of 2 sroke oil
Posted on May 07, 2010
What's mis ratio for ECHO PB-400E blower
Two very good answers, if you go to use the 50:1 ratio you will probably not be wrong most new stuff mixes with the 50:1 ratio these days if your not comfortable mixing the gas, Menards has premixed can for sale, as do most of the big box stores. Very good for novice mixers who don't want to keep alot of fuel around and let it go bad. Great alternative to mixing!
Jun 21, 2014 | Echo Gas Blower 135 MPH390 CFM Blower...
What is the fuel/oil mixture for my echo pb 250 blower
Sometimes, the fuel ratio is stamped on the fuel cap. Your ratio is 50:1. Echo specifies using 89 (mid-grade ) octane Here is a chart that tells you how much oil you need in a gallon of gas...Just 1/2 it for a half-gallon mix. A copy of your manual is also here.
http://support.mtdproducts.com/app/answers/detail/a_id/347/~/two-cycle-engine-fuel%3Aoil-mixture-chart
http://www.echo-usa.com/getattachment/624aee9f-103c-416c-ae9b-55fb42dd94af/PB250es1112_010410_1.pdf
Jul 22, 2011 | Echo Gas Blower 135 MPH390 CFM Blower...
SIR. I HAVE A ECHO PB 200 POWER BLOWER..WHAT IS THE FUEL GAS/OIL RATIO? THANK YOU
You can't go wrong with 25:1. Common accepted best ratio for this item to give best life for the internal components.
Nov 15, 2010 | ECHO, Inc. PB-251C Handheld Blower
First time to add gasoline, I am not sure how to mix oil and gas for ECHO PB-2100 ratio 50-1
May 06, 2010 | ECHO, Inc. PB-251C Handheld Blower
Oil/gas ratio for mod. PB 260L
I didn’t see a manual for your blower but page 14 for a PAS 260 says:
“IMPORTANT
Echo Premium 2-Stroke Oil may be mixed at 50:1 ratio for application
in all Echo engines sold in the past regardless of ratio
specified in those manuals”
http://www.echo-usa.com/documentation.asp?Model=PAS-260&lang=E
HTH
Lou
Nov 01, 2009 | Garden
What type of oil do I need to mix with the gas for the Echo PB 2100?  Also, what ratio?
Misplace your Manual? Want to view a Safety Video? Look up a Part for your ECHO Equipment? Do It All Right Here
  • www.echo-usa.com/documentation.asp?Model=PB-2100&lang=E
  • Echo recommends 89 octane fuel and 50:1 mix to one gallon gas for your pb2100
  • go to this site and find fuel and read about it if you would like
  • i use 40:1 in everything i have and have had no problems
  • The oil you buy make sure it is for 2 cycle engines and not outboard motors
  • 50:1 =2.6oz to i gallon gas
  • 40:1 =3.2 oz to i gallon gas
Jun 07, 2009 | ECHO, Inc. PB-251C Handheld Blower
Proper gasoline and oil mix ratio.
My echo uses 50-1 ration. Home Depot sells the small containers for Echo Leaf Blowers that you mix with one gallon of gas.
May 24, 2009 | ECHO, Inc. PB-251C Handheld Blower
Echo Inc. 44 CC, Carb Certified Backpack Blower Logo
75 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
