Question about Homelite Pressure Washer. EZ Clean 1600 psi 1.3 GPM Electric Pressure
Soap wont dispense from pressure washer - Homelite Pressure Washer. EZ Clean 1600 psi 1.3 GPM Electric Pressure
How do i install my soap dispenser into the 1600 all-power electric power washer
There should be a 1/4" hose nipple on the pump which will connect to the soap dispenser with a 1/4" line.
Sep 28, 2013 | All-Power America Garden
DO NOT KNOW HOW TO USE SAOP/SOLUTION CONTAINER
soap dispensers only work wit no or low pressure nozzels. when you have high pressure nozzles there is too much back pressure for the soap dispenser to function ..
Sep 14, 2013 | Campbell Hausfeld PW1750 Electric Pressure...
Soap wont dispense into washing machine
Hello - Sounds like the washer could possibly have a blocked dispenser cap, screens are restricted or an issue with the water pressure in home. Are you using a low-sudsing, high efficiency detergent? If so, but issue continues contact a professional to move forward accurately.
Oct 27, 2012 | Frigidaire FAFS4272LA Washer
DETERGENT DISPENSER WONT WORK???
A common mistake people make when using the detergent dispenser is to use one of the high pressure tips on the wand while trying to dispense detergent. You have to use the black, soap tip so there isn't too much back pressure in the line for the dispenser to work. If you are using the black tip, check the dispenser line and fitting where it connects to the line for anything that may be blocking the line.
Jul 18, 2012 | Honda Garden
Craftsman pressure washer how to adjust soap 2300 psi
A common mistake made when using the soap pickup function on pressure washers is to use one of the high pressure tips, usually green, white, yellow or red. If you are using one of these there will be too much back pressure in the line for the soap dispenser to work. You have to use the low pressure, soap tip, usually black, for this function to work.
Jun 28, 2012 | Garden
How to get soap to come out of dispenser of mcculloch power washer fhh 18a
Most people make the mistake of using a high pressure tip on their power washer while trying to get the soap dispenser to work. These tips are usually red, green, white or yellow and they cause too much back pressure at the dispenser for it to work. You need to use the soap tip, they're usually black, for the dispenser to work properly.
Jun 17, 2012 | McCulloch Garden
Fix soap dispenser on xtreme dw-1840 bv pressure washer
it will only draw soap when your using the large fitting they don't draw with the high pressure nozzles
Mar 22, 2012 | Garden
How to use soap dispenser on Karcher K2.87 power washer
Also, be sure the cap is turned to the direction that lets the soap in. It has a gradation on it and if it is turned all the way to the smallest (cap fully closed) very little soap will be injected into the stream.
Apr 18, 2010 | Karcher Garden
Pressure washer won't pull the from the soap dispenser
Nozzle dirty, clean out nozzle with small diameter wire. Soap dispensing only happen at nozzle low pressure setting
Jul 26, 2009 | Honda Maxus Pressure Washer MX5222
Wont pull detergent
problem is that u have to use with lowest pressure i believe black tip
Jun 20, 2009 | Honda Maxus Pressure Washer MX5222
Homelite Pressure Washer. EZ Clean 1600 psi 1.3 GPM Electric Pressure Logo
27 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
