Question about Hardware & Accessories
Instructions for setting a Barclay Geneve battery operated timer
2 Suggested Answers
  • 659 Answers
SOURCE: Timer operation Daikin BRC1C517 wired remote (Air Con)
http://www.daikin.co.uk/Product_Operation_Manuals/Controllers/default.jsp
Follow the link above. This is where you find the manuals for these units. I couldn't find the one that is specific for your unit but they do have a way you can contact them and also you might gain enough info from the ones they do have to figure yours out.
Posted on Mar 20, 2009
Intermatic timer instructions
Setting time will not work I did replace battery but now have to operate with manual setting only? ?
May 03, 2013 | Intermatic EH40 - Electronic Water Heater...
I lost my instructions for my Utilitech #0357930 timer. I cannot get it to work; I can set it to start but not stop. Just need some directions. Buttons on it are On, Off, Day, Hour, Min, Enter, Pro
The AutoChron 81000 Programmable Wall Light Switch Timer is identical to the Utilitec #0357930 (AmerTac) TMDW50L. Here are links to manuals for models prior to and as of 2012.
Before 2012
As of 2012
Nov 28, 2012 | Hardware & Accessories
Utilitech #0192773 setting the timer for not working
I do not have repair for defective timer.
Open following link for clear large-print instructions.
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Add a comment about part of manual that does not work, for possible additional help.
1) Timer replaces single-pole light switch only.
2) Timer does not have a battery and must be wired correctly before programming can take place.
3) Choose either dawn-dusk or programmable on-off:
Timer can be set for dawn-dusk operation
-OR-
Timer can be set with 7-day on-off functions of your choice
Aug 18, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I just installed a GE Smart Digital Timer. After I programmed the timer and went to manually turn on the light the light started to click on and off and the timer ticked?
Timer wiring instructions shown on following page:
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
You connected the white wire and red wire together, and that is why lights are clicking on-off.
I test timers and have done this intentionally during testing.
Follow instructions shown on link above, and GE timer will work correctly.
Same wiring applies to Tork, Swilight, Utilitec, Woods, Leviton, Intermatic non-battery operated timers.
Instructions are different for Aube, Brinks, UPM and Intermatic battery operated
Dec 28, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I forgot how to set my lamp to turn on at 4PM and turn off at 12 midnight.
You posted under Intermatic ST01C battery-operated in-wall timer.
This is not a plug-in timer.
You say you have a timer for controlling a lamp >> that sounds like a plug-in timer and not an in-wall timer.
If this is not your timer, or you are uncertain about which timer you have, then add a comment and describe your timer in detail including buttons and anything you can remember about setting times.
If you have the ST01C timer, instructions are lengthy and best done with accompanying images:
See instructions with images:
http://waterheatertimer.org/ST01C-program.html
If ST01C was programmed correctly in the past, and the timer stopped working, then battery might need replacement, or timer might be bad. If battery is dead, your programs are still saved inside timer, and all you do is reset current time.
If you do not have ST01C, the following page will help identify your timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Add a comment and I will help for free.
Fixya also offers phone support for a fee, and that person can walk you through the steps. You must identify timer for that specialist to help, since each timer is programmed differently.
Dec 18, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I need to find instructions on how to reprogram an Intermatic indoor wall timer.
You posted under ST01C Intermatic battery operated timer.
If you have different timer, then add a comment.
Let's review ST01C timer for a moment.
Programming will stay inside timer memory indefinitely until timer no longer works.
Even if battery is removed, programs remain. Current time setting does not remain in memory.
If battery goes dead, then current time will disappear, but programs remain forever.
If previous programming was correct, you might only need to set current time,.
In that case, you do not want to 'reset' timer and clear memory.
If you want to clear old programming entirely, then you can 'reset' timer using following instructions.
Press and hold on-off button, and then use paper clip to push in reset button for 3 seconds.
Release reset button but keep holding on-off button until INIT displays momentarily.
Release on-off button.
If display does not show, then timer battery is bad, or timer is bad.
For instructions how to set current time, click link below.
In addition to current time, the link has ST01C manual and also has EZ to follow instructions and photos for setting on-off times (but not astro times)
Instructions are different for astro dawn to dusk.
Add a comment at any time if you need free help with specific steps in the manual.
If you do not want to read the manual or open a link and read the steps or add a comment for further free help, then you can pay a fixya expert for phone support and that person will walk you through the steps while on the phone.
Keep in mind that ST01C timer has 1 year limited warranty, and your timer might be broken.
In that case you should try the free steps first.
Dec 16, 2010 | Intermatic Inc. ST01C Digital In-Wall...
How do I set the on time for the timer and the off time? I want to set this for all days at once?
You posted under ST01C timer.
If you have different timer, add a comment.
Intermatic battery-operated timers are finicky.
Intermatic has a EZ programming guide:
If you are having a problem. Use paper clip and push-in round reset button while holding down ON-OFF button. This will clear all programs that could be in the way.
http://www.intermatic.com/st01c-easy-set-instructions.ashx
Nov 20, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I have a geneve quartz 14k gold mans watch dont no how to take apart to put battery in.
mcdevito75 here, Battery usually lasts 1 year and longer, even if you did change the battery yourself now, you"d forget for a year or even longer next time battery needeed to be changed, I know I did. Add to this you can easily destroy your watch with in-correct handleing. BEST BET, look for a small watch repair shop in your area for this battery change $10--$15.00 and peace of mind.
Oct 26, 2010 | Geneve 14K Gold Ladies Diamond Panther...
I need to replace the battery on my Geneve watch....where can i go to have it done professionally?
mcdevito75 Here, Best Bet is to look for a small watch repair shop in your area for this battery change.
Sep 01, 2010 | Geneve Strap OGW154 Wrist Watch
I lost instructions on setting the timer.
I Googled in Diehl digital timer and located a website that had the exact timer I have. Included in the list of information was a manual with instructions on setting the timer. I downloaded the instructions and set the timer. Exactly what I needed.
Jan 17, 2010 | Solar Digital Electronic Timer 20/40/60...
Hardware & Accessories Logo
79 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
