Question about Black & Decker 14" Grass Hog Xp Trimmer/Edger
The grasshog head spins but it does not cut - Black & Decker 14" Grass Hog Xp Trimmer/Edger
2 Suggested Answers
jgwhomeequip
  • 1902 Answers
SOURCE: My grasshog weed trimmer only spins when it is upside down.
It sounds like the rod that runs from the motor to the head, is either loose or it has broken, so when you turn it upside down that causes it to engage itself and turn. You will have to take this apart and make sure that the holding clamps are in place
Posted on May 04, 2010
Grasshog GH700 spins but doesn't cut the grass
Most likely the string is not the right size in length and/or diameter.
Check instructions in the user manual available at this site.
http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/90563741,GH700.pdf
Sep 02, 2014 | Garden
My B&D GrassHog CST2000 doesn't hold a charge very
Battery cases are usually welded closed and must be cut open to access the cells. The cells are also spot welded together to make up the battery voltage.
Jun 01, 2011 | Black & Decker Garden
May 04, 2010 | Black & Decker 14" Grass Hog Xp...
B&D grasshog XP motor squeeled and spin rate slowed. repairable?
I just saw your post. Check the area between the housing and the head, along the shaft. Fibrous debris (in my area, this loosely translates into "lilly leaves") gets wound around the shaft, and will slow the universe down to a crawl. The only way to get it loose is to cut it loose, or unwind it.
Best regards, --W/D--
Aug 18, 2009 | Black & Decker 14" Grass Hog Xp...
I need directions to replace string on black and decker cordless 18v grasshog
Go to home depot. look at the floor model and the replacement spools they sell there. Reverse engineer the stringing process or but a pre-loaded spool.
Otherwise,
1. Squeeze the tabs on the side of the head of the unit to remove the spool cover.
2. remove spool.
3. place end of string in small hole in center ring of spool.
4. wide spool with string in the direction of the arrows printed on the spool. DO NOT OVERLOAD!.
5. snap string into notch on spool and cut string leaving 6" exposed.
6. thread 6" of string through hole in side of unit head, replace spool, and replace cover.
7. go cut grass.
Jul 07, 2009 | Black & Decker String Trimmer Cordless 12"...
My grasshog has no power when it is spinning.
A pluged air filter will cause that. Depends on what altitude you are at, the carb needs to be adjusted per the altitude, see if it runs at a half choke, this tells you if it is getting to much air. The fuel mixture screw should out 3/4 to 1&1/4 turn out from bottom. Also if your oil mixture is to rich it will power out, 50:1 is 3.2oz. to a Gal. of gas. Also dependes on how old the machine is. Might have to go 80:1
May 30, 2009 | Hand Tools
The motor runs but the base doesn't spin.
The nylon Gear in the head has theeth missing. I need a parts break down and a source for part.
this is for a Grasshog. NST 2018 Trimmer
May 25, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
Can't remove casing for B&D Cordelss Grasshog (NST2018 Type 2)
These are the steps to open the clamshell/motor housing for the Black and Decker 18V Cordless Trimmer Model NST2018. The orange clamshell has two plastic clips that engage two recesses inside the black plastic ring. You use two screwdrivers to disengage the clips and seperate the black plastic ring from the orange clamshell. Follow these steps: Wrap tube assembly in a small towel and mount in a large bench vice securely. You will notice two small openings at the top of the black plastic ring at the top of the orange clamshell. The next steps require two people. Person one inserts a flat-bladed screwdriver into into each of the small openings at the top of the black plastic ring (two screwdrivers). Using the tube assembly for leverage, pry the black plastic ring from the orange clamshell with enough force to disengage the orange plastic clips from the black plastic ring. Person two pulls the orange clamshell/motor housing away from the black plastic ring/tube assembly along a straight line (same axis as the tube assembly). After you've separated the motor/clamshell housing from the black plastic ring, remove the six screws and open the clamshells.
Jul 24, 2008 | Black & Decker String Trimmer Cordless 12"...
Black & Decker 14" Grass Hog Xp Trimmer/Edger Logo
62 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
