Maytag epic z (mhwz400tq02) F-21 Error
I'm getting this error code on a washer I just purchased used. In the research I've done it appears to be related to a slow drain time, which could be the pump/lines or any number of things causing it to not drain. Well, I took the pump apart and there was gunk built up, put it back together and it worked for a few days, but now it's getting the error again. When I put a shop-vac to the drain line, it sucks the water out no problem, which is leading me to believe it's the pump, I just don't want to replace it with as pricey as it is, if there's another potential issue. Any thoughts?
Krazytech
  • 725 Answers
SOURCE: I have a whirlpool front load washing machine model WFW8300SW00
Hay Crab.
what I have found is that the washer thinks it is not pumping out .. if your drain pump is clearly removing the all the water in a good time... then the problem is your pressure switch...it is telling the computer that it still has water in the machine...
replace the pressure switch and it will solve your f21 error.
It is a round unit on the right hand side on top...with a tube and wires going to it...let me know if it helps
Posted on Apr 05, 2008
sivaranjini
  • 241 Answers
SOURCE: Maytag Epic giving F11 error code!
ths.gardenweb.com/forums/load/.../msg1012004912002.html
Posted on Jun 22, 2009
  • 12 Answers
SOURCE: Maytag Epic-Z F-28 error code
F28 is a misc error,
most of the time it is because the washer is NOT LEVEL.
1. Unplug waher,
2. Relevel washer. (make sure all legs are equally distributing weight, so as to ensure no shaking). See owner's manual.
3. Plug in, and use.
Hope this helps.
Jay
Posted on Oct 04, 2009
milten1
  • 1304 Answers
SOURCE: Why won't the washer drain? Pump appears to be
if this issue is because you hear water in the machine when the tub spins......
thats normal, its called the balance ring
centrifical force, pushes the water in the lid, outward helping to use the sling weight, as a counter balance
its 100 percent normal to hear sloshing when turning the tub by hand
Posted on Oct 13, 2009
  • 50 Answers
SOURCE: My Maytoag Bravos Top load washer drains really
Is the drain hose kinked or clogged? Is the drain hose installed properly? look in the installation Instructions, Press POWER/CANCEL to clear display........ hope this helps.....
Posted on Jan 08, 2010
GWL11 - Error 37 - Faulty Pump only or Computer/Controller too?
Hi just read your posting.If you are getting error code 37 then the fault is definitely your drain pump.If the pump is getting very hot, it is faulty.What happens is when the pump gets hot the thermal fuse that is part of the windings on the pump opens to stop it burning.I have seen this fault many times and always changed the pump.Hope this helps but please reply for further help.Looking forward to your reply.
Jun 24, 2012 | Fisher and Paykel GWL11 Top Load Washer
Maytag washer throwing fault code 21
An "F21" or "F02" error code is indicative of a slow draining cycle, normally caused by a clogged or kinked drain hose. If an "F21" or "F02" error code appears, check the drain hose on the back of your washer to ensure that it is not clogged or bent. Once the drain hose has been unblocked, the error code should disappear and the machine drain properly. However, if you have a high efficiency washing machine and the error code continues to appear, make sure you are using the correct detergent; because high efficiency machines use much less water than traditional washing machines, they require the use of a low sudsing detergent. Traditional detergents may produce too many suds, which can block the machine's drain hose and lead to slower draining cycles.
May 20, 2012 | Maytag Washing Machines
I have a WTW6400SW2. Always get 5d code if we use high spin speed or do large load. Also seems to take forever for tub to drain. Related problems? In the past have epoxied exterior of drain pump due to...
Hi
Error code SD/5d means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump. Hope this helps...please post back for further assistance.
Daniel
Aug 15, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My Zanussi Jetsystem Timeline washer/dryer starts its wash cycle, but when it comes to draining, it wont drain and flashes E20.
Have you taken the filter out at the front of the washer and cleaned it. Mine wouldn't drain but once I did that it worked ok.
Mar 04, 2011 | Zanussi ZWD1680W Front Load Washer / Dryer
Sd error display. Not slow draining
Hi
Error code SD means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump.
Hope this helps... Please post back if you need more information.
Daniel
Dec 15, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My new Whirlpool Cabrio stops repeatedly with the UL flashing it never finishes a wash load, do you have a step by step CD explaining the use of this washer? I am about to return it to the store and get a...
I believe this model has a defective control board under the control panel. The new control board has longer times between the drain and the spin. Eliminating the unbalance when it tries to spin with water still left in it. Also check for slow drain this will enhance the problem. The control board is a warrany repair if covered.
Mar 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore elite front loader washer:door locked after repair
If you have cleaned the drain pump and checked ALL the drain lines (this includes the drain line that runs from the bottom of the wash tub to the inlet side of the drain pump), then you may have to replace the pump.
Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and cannot pump at the correct volume to complete the drain cycle, the error code will continue to appear until the pump is replaced.
The following link explains how to replace the drain pump (if required):
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I hjave listed also have helpful exploded view parts illustrations to assist you in locating and properly identifying the parts you need.
If you are having problems with unlocking the washer, there is a manual release you can use to get the door open: http://www.fixya.com/support/r3576511-door_jam_on_kenmore_elite_and_whirlpool_ The problem may just be a momentary glitch in programming related to the "F02" error code you are receiving. If there are any error codes present, the washer will not complete a cycle and will shut down. I would recommend double checking the drainage system one more time to ensure there's nothing caught in the pump impeller or any of the drain lines (you may have overlooked something), followed by replacement of the pump if the problem continues. This will hopefully cure any others issues you may be experiencing with the washer. If you have any questions, please post back and let me know. I hope this helps you.
Feb 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Oasis Ld code
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question !!!!
Jun 02, 2009 | Kenmore Oasis 27042 Top Load Washer
Not rinsing 5d code appears oasis washer
It is likely Sd.
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
Apr 01, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
65 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
