Whirlpool stylemaster 4214289 REV A Leaks water only when using warm and hot selections.
  • Official Brand Answer
  • 408 Answers
Http://www.whirlpool.co.uk/app.cnt/whr/en_GB/pageid/pgsrvifuhome001/ifu/home
Posted on Oct 20, 2013
4 Suggested Answers
  • 1314 Answers
SOURCE: Whirlpool ghw9100lw2 front load washer doesn't use both hot and cold
first make sure the hoses aren't reversed hot on cold or cold on hot next turn off cold water remove the hose from the washer and check to see if the screen on the washer is clogged if not get a bucket turn on cold water and see how strong the water is then let me know what you find dont rate me till we are done
Posted on Jan 10, 2008
gdmisp
  • 66 Answers
SOURCE: hot water doesnt work, switch to warm and warm comes out.
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
Posted on Jan 16, 2009
  • 151 Answers
SOURCE: washer will not fill when you select cold water
Q - My washer will not fill with cold water
A - More often than not, this is a bad fill valve. Please see the filling section.
There's no cold water Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine is not working the way it used to--or should--check the following.
  • Is the cold water turned on? If not, turn it on.
  • Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct.
  • Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
Posted on May 03, 2009
Whirlpool washer Stylemaster #4216273 REV A allows water to go out of the machine but will not go into a spin.
the motor has an issue prob brushes need replaced or timing of the pump out is too long
check out the filters or get a tech...
Dec 10, 2014 | Whirlpool Washing Machines
Whirlpool stylemaster 4217141 rev
Check the water valve for continuity. Also check the screen on the cold water side to see if it is clogged. That is what I would do.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 05, 2013 | Dryers
Water is trinkling down the bello and filling drum after wash is complete
Theres an electric water valve. You have to find out if its the hot or cold thats leaking and replace it.
Jan 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Will not drain or go into spin cycle
Definetly the lid switch has been knocked out of place or has gone bad.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Aug 26, 2009 | Whirlpool Washing Machines
Hot water doesnt work, switch to warm and warm comes out.
Jan 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Jan 10, 2008 | Whirlpool GHW9100L Front Load Washer
Washing Machines Logo
188 people viewed this question
Top Washing Machines Experts
