Question about Hotpoint 6.67 cu. ft. / 189 liter Chest Freezer RC32
Orange light on my norfrost freezer - Hotpoint 6.67 cu. ft. / 189 liter Chest Freezer RC32
Hi we have a norfrost chest freezer it is freezing everything but bread on superfreeze when we take it off of superfreeze it defrosted the bread
sounds like the thermostat is at fault or more than likely the refridgerant gas has partially escaped due to a leak, check te seals on the doors first. hope this helps.
Oct 09, 2016 | Freezers
Norfrost c4bew chest freezer
Goggle to find out the company that built it and see if they will send you a copy or if its available for download. This is a common problem with private sales without all the manuals that come with it. Sometimes you have to look up each appliance or model. Start with a phone number to the manufacturer and work from there. Also you can find someone that is selling one like yours and call them to see if they can send you a copy from their manuals.
Oct 16, 2013 | Freezers
Norfrost c6aew chest freezer compressor wiring
What is the make and model of this freezer?
Mar 14, 2013 | Freezers
My norfrost chest freezer hardly opens.until a couple of hours?is there any timing for norfrost chest freezers?
switch of your freezer. and turn it on after half an hour. may be it works.
Dec 13, 2011 | Freezers
My Norfrost chest freezer has stopped working will only freeze when the turbo button is switched on. Please help
which means that it is operating manualy...could be the thermostat needs replacing...
Feb 28, 2010 | Freezers
I have a Norfrost 100ltr chest freezer that is defrosting on normal setting but the fast freeze and compressor run when switched on. Any suggestions as to the problem
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 07, 2010 | Freezers
Freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
freezer not working on ariston... Solve freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every... (More) freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
Sep 13, 2009 | Freezers
Freezer not freezing
it would apear the stat is the fault. the thermostat is monitoring the temperature of the inner liner and tubing. if the compresor isnt actuly staying on the only part controling it is the stat. if you have the knoledge i would sugest you bypass the contol with the unit unpluged and the plug it in to conferm the fault was the control. p/s you may have a friend who has some knoledge . the control is a simple switch. just enshure the unit is unpluged. hope this helped
Oct 19, 2008 | Freezers
Hotpoint 6.67 cu. ft. / 189 liter Chest Freezer RC32 Logo
329 people viewed this question
Top Hotpoint Freezers Experts
AJMAL KHAN
Victor Nwachukwu
Victor Nwachukwu
Gerard Curran
Are you a Hotpoint Freezer Expert? Answer questions, earn points and help others
