Question about GE Washing Machines
GTWN2800D1WW mattress cover caught under agitator
triplett
SOURCE: Sheet caught under agitator
the agitator comes out..... by simply taking off the cup that holds fabric softner, just pull upward if needed wiggle and pull. under that you will see a raised plastic piece the raised plastic pc is pulled of by using a pliers pull upward under this you will find a bolt 1/2 or 9/16 socket remove bolt and pull out agitator same way by wiggling and pulling upward
Posted on Jan 15, 2008
jumptrout51
  • 3361 Answers
SOURCE: shirt caught in the agitator
The top of the agitator should unscrew then pull off.
Posted on Feb 21, 2009
  • 2920 Answers
SOURCE: towel caught under agitator
remove the top part of the agitator and inside youll see a nut that will have to be taken loose so tht you can get the agitator to raise up high enough to get the towel out
Posted on Feb 25, 2009
mrfixit3667
  • 262 Answers
SOURCE: Clothes are caught under the agitator. How can I
Remove the top part of the agitator or the cap and you should find a bolt in the center. Remove the bolt and pull up on agitator.
98702 is not the model # of the machine. you should find the model # either on top of the machine or in the dryer door area around the frame.
Posted on Jan 11, 2010
  • 157 Answers
SOURCE: clothes get caught under
Check the rubber gasket around the agitator is not worn. If it is get a replacement and insert it in snugy.
Posted on Aug 16, 2010
My mattress cover is stuck under the agittor un my GE washing machine
We should branded products then we feel comfortable.
Sep 13, 2014 | GE Washing Machines
How do I get a mattress cover stuck under agitator out?
On the older machines, the cap on top of the agitator unscrewed & then the agitator could then be raised.
Sep 13, 2014 | Washing Machines
Item caught under agitator
The top of the washer pulls up. IT may be hard to do. This will expose the whole drum so that you can see around it. If you need to remove the agitator, there is a cap on the top of the center, take it off and you should see a nut and some lock washers, Remove the nut and lift the agitator out.
Dec 19, 2013 | GE Washing Machines
Fine garment caught under centralrotor has black mark on it , is this grease?
It is not grease. Under the agitator there will be a sticky buildup of detergent and dirt that has stuck to it. Overtime this buildup can become quite a lot. When your garment became caught up under the agitator, it was becoming stained with this buildup.
Jan 09, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Apron string caught under the rod the agitator sits on. How do I take it off to remove the apron string
Is it a top loader if it is.
You can remove the agitator.
Remove the dispenser pops out, you might need a flat screw driver. After that remove the cover in the agitator.
There should be a bolt. remove the bolt and now you can pull out the agitator.
Now you can get the apron string right out.
http://www.pdxappliance.com
Feb 27, 2010 | Washing Machines
Jan 11, 2010 | Kenmore 98702 Stacked Washer/Dryer
Towel caught under agitator
Feb 25, 2009 | Kenmore 98702 Stacked Washer/Dryer
Shirt caught in the agitator
Feb 21, 2009 | GE Spacemaker Washer and Dryer Electric...
Apron caught under wringer
Hi Karen,
That is a real pain when that happens, but let me see if I can help.
First on the top of the agitator or wringer you will see a small cover. You will need to pop that off to reveal the screw hidden underneath. Remove the screw and then the agitator will pull upward and off. The agitator on the hotpoint washing machine is really hard to pull off so you will really have to pull. When the agitator comes loose you will ofter be pulling so hard that you could hurt your arm on the top of the tub so be extra careful or get some guy to get hurt for you. Once removed I am sure the apron can be easily removed and all will be well again. Good luck to you and please dont forget to rate me. Have a nice day.
Mike Anderson
Anderson Appliance Repair
(865)945-3808
Oct 28, 2008 | Hotpoint Washing Machines
Washing Machines Logo
144 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
