Question about Kitchen Appliances - Others
Kenwood SJM 100 does not switch off automatically
Hi . I have a Kenwood receiver V-3080 that on start up it comes on for a few sec. the turns off like you switched it off then after several time it stays on without any further problems.
The wiring of a speaker has back feed to a safety shut off because a wire is touching or the polarity has been switched. The volume may be turned up to high to and will cause it to do the same. It is an overload feature, so that you don't blow your speakers with a 100 watts of power surging to it. Changing positive to negitive of the speakerswire to speaker may help.
Dec 01, 2010 | Kenwood VR-3080
ARE THE SX SJM-62 GUITARS ANY GOOD. IT HAS P90 PICKUPS
Here is one review:http://www.guitarplayer.com/article/2007-sx-sjm/may-08/35307 Whether they are any good is always a personal choice. Some things to consider are: Does it have good action? Does it stay in tune? Does it sound good through your amp? Can you adjust the parts( pickup height, bridge , neck etc.) Some people have been buying them and then modding them with better parts. They seem to be a reasonable bargain for the price. Notice the link I recommended was for a different model. Look on the net on some guitar forums to see what other players have to say. If you can, find someone who has one that will let you try it out. Here is a video:http://www.youtube.com/watch?v=k1CQWi8orqA Hope this helps.
Oct 22, 2009 | Sx Guitars SX SST SE CAR + GA1065 STCAD...
The subs aren't pushing out bass.
Hello crobins2,
The Kenwood KAC-6202 2-channel is only rated for 60 watts RMS per channel into a 4 ohm load. That just isn't much power for a pair of 12" subs. Even the bridged output is only 200 watts into 4 ohms, still at the low end for a sub, much less to share between a pair of subs.
Assuming that your subs are 4 ohm, you could probably get more sound by driving just one of them on the bridged terminals. But to get the best power with what you have, connect one sub to each channel, set the filter switch to the far right (LPF), set the operation switch to stereo (both channels driven), set the filter frequency (Hz) to 100 or lower, and adjust the input sensitivity as far clockwise as possible without causing distortion.
But, to do the subs justice, you really need at least 300-400 watts to share between them.
Hope this helps.
Sep 27, 2009 | Kenwood KAC-6202 Car Audio Amplifier
We are looking for the service manual for Kenwood model UD-100. Can you help?
here you are : http://inform3.kenwoodusa.com/manuals%5Cud100.pdf
Aug 14, 2009 | Kenwood UD-100 Shelf System
Wiper motor problem
Check the Relay in the Battery Junction box it is the 3rd one from edn oposite if 3 small fuses close to it with a 5 amr fuse in the middle. Hope this helps it realy should from the sounds of it
PLEASE RATE My ANSWER
Dec 27, 2008 | 2005 Ford Taurus
Need a brain
U CAN CALL KENWOOD GET ONE CHEAP 100
Nov 18, 2008 | Kenwood Excelon KVT815DVD Car DVD Player
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
