Electrolux EWX14450W Hi. have one of those elux built in washing machines EWX14450W that annoyingly just gone a couple of weeks beyond the warranty. now, if anyone could point me in the right direction i would be most greatful. When turning a program on it fills up and keeps filling until water comes out everywhere. And randomly it works too but keeps filling and never seem to get to the empty itself and just keeps going to it burst so to speak. Filter is clean, drain pump working fine when doing it on separate program. Error code those time when running display E10. doesnt make sense to me as e10 appears to be about not having water supply ( quite the opposite here). great if someone one here have any idea where to look to solve the issue. cheers nick
Krazytech
  • 725 Answers
SOURCE: I have a whirlpool front load washing machine model WFW8300SW00
Hay Crab.
what I have found is that the washer thinks it is not pumping out .. if your drain pump is clearly removing the all the water in a good time... then the problem is your pressure switch...it is telling the computer that it still has water in the machine...
replace the pressure switch and it will solve your f21 error.
It is a round unit on the right hand side on top...with a tube and wires going to it...let me know if it helps
Posted on Apr 05, 2008
SOURCE: AEG 16810 UPGRADE WASHER DRYER E10 ERROR
This is worth posting in case anyone else has the problem. The mechanic was stumped and then around 3 days later a Zanussi gave the same problem - steam emitting from the drum. He changed the valve - the entire unit. Problem solved. Zanussi and AEG have identical internals. He changed our valve - problem solved.
Posted on Aug 03, 2008
SOURCE: zanussi washing machine won't start E10, E40 & E50 at times
It was suggested that the pump had failed and taken out the programmer with it - expensive! Wife wouldn't wait, and bought new machine. Problem almost solved - anyone want an out of order washing machine?
Posted on Feb 04, 2009
abhishek33
  • 1239 Answers
SOURCE: E10 error code. I have to keep hitting the start
hi
it is water pump error ,,please check it thank u,,
please rate it
Posted on Jul 04, 2009
  • 497 Answers
SOURCE: Hotpoint Aquarius WT540 washing machine. will not fill with water
Sounds like a timer switch malfunction.
Posted on Sep 06, 2009
Who is the maker. Motor gone and warranty expired. Help
I think Admiral is part of the Frigidaire company (Electrolux Corp).
Most parts stores should be able to get parts for your machine.
Mar 07, 2015 | Admiral Washing Machines
My washing machine just turns white light on display but nothing to display and white background light also comes when i turn it 2 times on n off
Good Morning Friend,
I understand you are having trouble with the display on your Electrolux washer, model# EWX14450W. In researching your model number, I have determined that it was manufactured in the UK. I suggest contacting the manufacturer for further assistance. They should be able to point you in the right direction for having your display repaired. Hope this is helpful.
-Best Regards-
WP
Jul 06, 2014 | Electrolux Washing Machines
Error on Zanussi Electrolux Jetsystem Turbo XC FJR 1254W
Your Washing Machine is starting to have more movement and is doing an Auto Stop, you need to get new mounts to get rid of the Excess Movement.
Apr 08, 2013 | Washing Machines
Electrolux EWF 1074 - How do I turn off the annoying beeps at the end of every wash
I have touchscreen! Doesnt work. Any suggestions? Hate having to get up middle of night to turn off this )%(/₪/#&/₪(" beep!
Feb 29, 2012 | Electrolux EW1000i Front Load Washer
It get to hot, and the heating element stays on and melts plastics. Way to hot.
STOP USING THE DISHWASHER IMMEDIATELY.
It's dangerous and using it will cause further damage. It's likely that considerable damage has been done already if plastics have melted.
Your thermostat has failed and will need replacing but it's unlikely that the thermostat is the only part that will need to replaced. Your washer may even be damaged beyond economic repair.
You need to call an engineer. Your machine needs to be professionally inspected and assessed for damage before further use. If the washer is still under warranty, please contact Electrolux
customer support - the phone number for your region will be in your user manual.
Nov 03, 2010 | Electrolux 24 in. EDW5505EPS Stainless...
Hi i have a simpson EZI sensor top loader washing machine 12 months old and the lid lock alarm keeps peeping afther 10 mins into the load. How do i solve this problem and im also geting electric shocks...
We had the same problem. Electrolux repairman came last week and replaced the lid switch parts with a new designed part. Told me the original part was subject to recall because of a problem with the design, was getting wet and stopping the maching operating correctly, and causing shocks. Ring Electrolux, should be covered under the two year warranty (but because the fault was there when the machine was bought, shouldn't matter even if warranty period had expired)
Oct 15, 2010 | Washing Machines
Is the memory board gone in my electrolux washing
Sad to say, yes "Replace the board". Quote no. on the board as there are newer updates as models change.
May 23, 2010 | Electrolux EW1000i Front Load Washer
Error code E20 electrolux washing machine EW1280F
• E10 = there is no water filling • E20 = the water is not drained • E40 = door open
Download Manual - http://laundry.manualsonline.com/manuals/mfg/electrolux/ew_1280f.html
Feb 04, 2010 | Electrolux Washing Machines
Machine started making a quick tapping noise during wash after it had been almost silent since installation. Then noticed it appear the machine is not putting out spray or the spray amount decreased over a...
The vario motor may be at fault.
The motor switcher the spray from top to bottom.
It is part of the sump assy.
You can tell if it is working if you start the unit and when it is in the wash cycle you can hear the water spraying change from top to bottom every few minutes.
D/W has a full 1 yr warranty and most have a 5 yr part warranty on the sump.
Check your owners guide.
Jan 13, 2010 | LG LDF6810 Built-in Dishwasher
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
