Question about PreciseFit 4000 PSI Pressure Washer Gun Kit SGY-PWA57
Where can I buy the washer gun kit SGY PWA57 - PreciseFit 4000 PSI Pressure Washer Gun Kit SGY-PWA57
Kobalt gravity spray gun and I have a little air that comes out constantly. Why is that and how do I stop it? Thanks
You must be using a "turbin" which is different and better than a compressor however a turbin runs all the time and air must escape from it unlike a compressor with an airtank the shuts off after the desired pressure is reached it shuts it self off then turns back on with tank pressure drops below what you have set it at- a turbin reaches the pressure you set the regulater at and maintains it constantly NEVER STOP THE AIR FROM PASSING THRU IT in fact a lot of times i do this to remove any dust i may have missed so evrything is working like it should on yr sprayrig..
perry tradesman
Oct 19, 2014 | Kobalt Large Gravity Feed HVLP Spray Gun...
How to repair a deadbooth android cellphone
There might be possibility of hardware faluer,if the device is not booting.
If you are able to switch ON the mobile by pressing Volume UP key + power button +Home button, it will open in Download mode.
Here you can connect your device to computer via USB cable and use the Odin Flash tool for SGY GT-S5360, and flush the ROM.
You can easly get the Odin over internet and stock ROM for SGY.
In case you have any query, revert me back.
Jun 18, 2014 | Samsung Galaxy Y Gt-s5360 - Black unlocked...
How do I open the CRT guns to add/replace coolant?
Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a complete kit to replaces all three R,G,B CRTS guns coolant chemical replacement the kit also have a tutoring dvd,websites also sell the tutoring dvd alone too.
Apr 02, 2011 | Hitachi 57F500 57" Rear Projection...
The handle is broken on my 1200superllube grease gun. where can i buy a new handle
online is a good place to check. i would try manufacture's website 1st.
Nov 04, 2010 | Lincoln 1242 Cordless Grease Gun Kit
Engine runs , not getting any water flow when trigger pressed.
Disconnect hoses.
Look for kink in water hose.
Check incoming water connection for filter washer
Replace filter washer
If you don't have a filter washer, put one in.
Hook up water, and turn on
Water should come out other side of pump.
Turn on machine.
Do you get pressured water out of pump.
If no pressure, then pump is suspect
Hook up washer hose without gun
Does pressure come out of washer hose
Finally, the gun trigger may be bad.
We had to buy guns now and then.
Search for pressure washer guns
Following link shows guns we used:
http://www.ultimatewasher.com/pressure-washer-trigger-guns.htm
Oct 25, 2010 | Karcher G2650HHR Gas Pressure Washer
My Honda GCV160 Pressure washer runs great, but isn't creating any pressure out of the nozzle. Not even a drop out of the wand. Its been on hiatus while I've been recovering from an injury for 3mos. It...
Take hose and gun off pump.
Start engine.
See if pressure comes out of pump.
Next, remove water hose and look at filter washer.
Clean or replace filter washer.
Turn on water and it should come out of pump on other side.
These steps will tell you if problem is water supply or pump.
Sometimes the problems happen because the gun lever is bad.
Hook up hose but not the gun
See if pressure comes out hous.
These steps will tell you if problem is gun or hose.
Oct 25, 2010 | Honda Garden
Hi! Our gun trigger is not working right on Model
Lowes and home depot sell replacement guns for most smaller pressure washers.
Jul 29, 2010 | Coleman Powermate DuraBuilt 1400 PSI...
Gun leaks dont know if i lost a chek valve when dissasembledcan you buy a kit for troy built gun model 020208 what parts are installed insise of gun
you probably can get a kit, but before you do check out northerntool.com. it might be easier and cheaper to just replace the handle
Jan 15, 2010 | Honda Pressure Washer PSI 3000
Need rebuilding kit for air gun
you can buy repair kit on the snap-on web-site.
www.snap-on .com
Jan 03, 2009 | Air Tools & Compressors
PreciseFit 4000 PSI Pressure Washer Gun Kit SGY-PWA57 Logo
76 people viewed this question
Top PreciseFit Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a PreciseFit Garden Expert? Answer questions, earn points and help others
