Question about Raymarine Raynav 300 GPS Receiver
Navyex is the Raymarine Raynav 300 GPS Receiver capable of recieving Navtex. bert
  • 16 Answers
No.
This unit was GPS with WAAS only.
No Navtex capability whatsoever.
Posted on Dec 28, 2007
SOURCE:
What is the connection path from Garmin 72 to raymarine c80, using NMEA 1083
I'm taking this as you want to send the gps information to your C80 not receive from the C80? If this is the case the brown wire on the garmin is the nmea data out +. The Black wire is considered nmea out neg (-) of the garmin. So hook the garmin brown to the white on the raymarine. Hook the black from the garmin to the green on the raymarine. That means you are outputting lat/long info to the raymarine from the garmin.
Jan 14, 2012 | Raymarine C80 GPS Receiver
I bought a RayNav 300 GPS on ebay and it came without a power cord. Can you help me locate one?
You are looking for part number e32024 (fits raynav 300 and raychart 320). What kind of jack does the power cable plug into? You may be able to have one made. A good marine electronics shop should be able to help you out.
Apr 20, 2011 | Raymarine Raynav 300 GPS Receiver
Manual for e 120 raymarine
You can download manuals for Raymarine E120 GPS free of charge here (click on 'Manuals & Docs' tab at that page).
Jun 24, 2010 | Raymarine E120 GPS Receiver
Cut antenna wire raymarine 300waas gps
That unit uses a TNC connector. Just have someone install a new one on the end of the cable. IT's a little more difficult than a F connector for a TV but not rocket science. You can also send it in to Mid-Shore Electronics. Just google them and get their number. They have alot of experience with the older stuff.
Oct 27, 2009 | Raymarine Raynav 300 GPS Receiver
I need a manuel in french
Hi!
You can free download the manual for Raymarine C80 GPS Receiver from the following link---
Raymarine C80 GPS Receiver Manual
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jul 08, 2009 | Raymarine C80 GPS Receiver
Can a Raymarine SL70 screen be replaced, mine has
You may be able to send it in to Raymarine however you need to call to be sure. The older models are often abandoned and they may not work on them any longer.
May 10, 2009 | Raymarine RL70CRC GPS Receiver
Raynav 300 the gps is not working
The GPS antenna with the 300 is not a GPS receiver unit like all the later Raymarine units and is no longer made. However the unit will accept input from a GPS receiver with Seatalk output. So you could use a 112, 120 or 125 receiver.
May 02, 2009 | Raymarine Raynav 300 GPS Receiver
Wiring of seatalk instruments
OK, you are confused. Seatalk is a bus system, using 3 wires , (power +, power-, and Data.) red, bare and yellow repectively. So Red and Bare are 12V and ground. Since the 125 shows a green light, it is getting power and outputting data. but is it seatalk?? to make a 125 Seatalk, you must hook red and green together to 12 V, so check that first. if green is grounded or not connected, that is the problem (or one of them)
Next divide system to its' simplest terms, so hook the GPS straight to the display ST60, and see if it works red to rd, yell to yell and bare to bare (sometimes black) One by one hook the others into the chain until they all work or failed device takes down Seatalk network. If you are missing 12V on a seatalk leg, check 5A fuse in course computer. If you have a pilot, you have a course computer, unless it is ST4000 wheel pilot, and then the brain is the display (course computer is built in to ST4000 display)
Sep 01, 2008 | Raymarine RL70CRC GPS Receiver
Internal chip
C-Map (chart) cartridges
Aug 08, 2008 | Raymarine Raynav 300 GPS Receiver
Open Questions:
Raymarine Raynav 300 GPS Receiver Logo
112 people viewed this question
Top Raymarine GPS Experts
gerd butler
Level 1 Expert
Goldi Kunal
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
