Question about JVC RX-ES1SL Receiver
Jvc rx es1sl lva10423
Where do I buy LVA10423
2 Suggested Answers
SOURCE: JVC RX-ES1SL 5.I
1: In most cases there are two FET`s gone you can use a normal IRF 530 but cut the heat sink from the FET do it with a pincer not with a grinding machine! (static electricity!). Before you switch on the set pay attention for the following parts!
2: The two coils that are mounted under the metal housing on the main board look of they have a other color if so they are burnt Check also the SMD parts under the main PCB.
3: The two SMD Elco`s that are mounted on the little PCB they have in most cases a high ESR. The value must be under 1 I thing that all the troubles you can have with this set are coming from this two elco`s (100uF 16 volt.)
4: look for a short cut on this little PCB pay attention to the two SMD gates. Measure the S/C over the +5 and +12 volt lines and check both PCB visual.
5: You must bring in a lot of heat to remove the both IRF`s use a good flux and do not fear the heat they can have it.
Because you must use a big Iron there is the danger to damage this aluminum layer check visual after you have solder the two FET`s all the connection with the smaller parts measure them with a Ohm meter. This was the fault in mine case there was a open connection to one of the gates of the FET`s
Posted on Jun 03, 2008
Where can buy jvc Rx-r75 remote control and if there any other model that would fix
http://www.jvc.newremotecontrol.com/catalog_item.php?catnum=RM-SR75U&refnum=RX-R75
May 16, 2017 | JVC Audio Players & Recorders
JVC RX-ES1SL 5.I
Feb 10, 2008 | JVC RX-ES1SL Receiver
Home theater reciever
Check the internal fuses havn't burnt out. Remove the main cover. There are 4 glass fuses.
Jan 20, 2008 | JVC RX-ES1SL Receiver
What leads to buy and how to connect them up
if it is all hi def use fiberoptic cable if not u can use digital coaxial or just straight rc cables. if u need any more info post again
Dec 27, 2007 | JVC RX-6042 Receiver
Very noisy power transformer
most transformers are bolted but some are just screwed you could probably check to see if teghtening is needed.
Aug 09, 2007 | JVC RX-ES1SL Receiver
JVC RX-ES1SL Receiver Logo
168 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
