Question about Westinghouse 46W1HD 46 in. LCD TV
Dish 40.0 ufh 2g will not turn on my vizio tv
How do i program dish remote to a vizio tv
Please follow the link below or using the second link below select your remote. If you don't know what model you have you may cycle through the list and it will provide you a picture of the remote. Just make sure you match it to the best of your abilities. Or you may contact Dish and ask what model your remote is.
By Scan
Tech Remotes Remote Codes MyDISH Customer Support
Please note that if the codes are not available or if they are not working then Dish nor Vizio does not have any working codes. Please understand that these codes are not universal for every remote nor is Dish and Vizio responsible to provide you with a fully working code.
Sep 19, 2014 | Vizio 39" E390VL Full HD LCD TV, Black
I have a Vizio SV48OM. It is hooked up to Dish. this morning I couldn't change channels or anything with my dish remote but could turn the tv on and off. Called dish and was trying to see what the...
About the only thing you could try would be to reset both the dish receiver and the tv. Disconnect both from electrical power source, (unplug) after a minute or so, plug them back in and try again. if neither works then you may have had some type of power surge.
Be certain your tv is in the right source, however the tv has been connected to your receiver.
Oct 29, 2013 | Vizio SV470M LCD TV
I am trying to readdress remote tv2 21.0 IR/UFH PRO but to receiver DISH network VIP 222k. we have tried every way and it always switches remote address tv1. we tried all the steps from the handbook b
Hello, German Quinchia!
I would be happy to provide assistance on this. It sounds like the remote itself may need to be setup correctly. Since this is going to be the second TV, on the bottom of the remote, make sure there is a blue 2 at the bottom instead of a green 1. Once you have the blue 2 showing, try addressing the remote again.
If the problem persists, remove the battery cover. Inside will be a switch. Make sure the switch is toggled to UHF rather than IR. Let me know here if the problem still continues after that.
Tommy Faust
DISH Social Media Representative
Feb 12, 2013 | DISH Network Televison & Video
Cant change channels on my new Vizio HDTV with the dish network remote
There is no setup codes for Vizio TV with Dish Remote control.
Jul 25, 2012 | DISH Network IR Remote Control
I just bought a Vizio E421VA last week. When trying to change the picture settings (brightness/contrast) using the Vizio remote, sometimes it just turns off all of a sudden. This also happened while I...
Hello, my name is Dan Busa with DISH Network. I happen to have seen this with other Vizio TV sets and would be very interested in taking a look into this. Even if you have resolved this please e-mail me at: daniel.busa@dishnetwork.com
Daniel Busa
DISH Network
Customer Service
Mar 21, 2011 | Vizio E421VA 42 in. LCD TV
Bought new Vizio 55"
Had same problem - turned off Adaptive Lumina, Backlight control, and Ambient light sensors on the Vizio advanced picture settings and the Dish remote now works. Vizio was emitting an infared signal that interfered with the Dish remote signals with these settings on. TV still works and looks just fine... But best of all Dish remote works too.
Nov 08, 2010 | DISH Network IR Remote Control
Need the codes to program my dish network remote ???
We're happy to help you with getting your DISH Network remote addressed to your TV. We're going to start by pressing and holding the TV button on the top of your remote until all mode button back lights come on, and then release. Use the number buttons to enter the codes for your Vizio TV; here are some of the codes we currently have: 505, 598, 627, 520, and 627. Press the pound (#) button to save the code in your remote. To check that the code works try several different functions on the remote to make sure it will properly operate the TV. Remember that some codes may not be compatible with your equipment. If this is the case, try the other codes listed for your Vizio TV until you find one that is compatible with it.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Feb 05, 2010 | Vizio L32 32 in. LCD HDTV
Vizio won't turn off
This could be a mainboard problem. Sometimes one of the fuses may be bad and may freeze up causing the TV to not be able to power off.
Mar 31, 2009 | Vizio GV42L 42 in. LCD Television
Programing Dish Network Remote to control a Vizio Tv.
Try 627 for Vizio TVs - that should work on the Dish remote.
Dec 22, 2008 | DISH Network IR Remote Control
I just got a Vizio 37" TV from Walmart.When I turn it on, I get a blue screen that says No Signal. Help.I have Dish Network. What am I doing wrong?
Check that the connection where the dish box is connected to the TV is the selected input on your TV.
You should have either a component connection (5 cables) or HDMI (1 cable) connecting the dish box to your TV. The VX37 has two component inputs and two HDMI inputs (if I remember correctly). Use the INPUT button on your remote to select the correct input.
Once you confirm this and still have problems, post a response and I will follow-up.
Dec 21, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Westinghouse 46W1HD 46 in. LCD TV Logo
26 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
