Where is serial number on a kobo mini? - Computers & Internet
My kobo is frozen on starting sync won't turn on or off
Note: If your Kobo device has been physically damaged, it is no longer covered by Kobo's limited warranty. On a Kobo eReader, a physically damaged screen will look like it's been shattered, or you may see vertical or horizontal lines on the screen with a frozen image. If you haven't dropped or damaged your Kobo eReader, but are experiencing issues, try the steps below in the order suggested.
  • Turn your eReader off and then on again.
  • If your screen is frozen, slide the power button to the right and hold it for 10 seconds. Your eReader should turn off.
  • Turn your eReader off and charge it for at least four hours. Note: Your computer should be turned on while you are charging your Kobo eReader.
  • If your eReader isn't charging, try using a different Micro USB cable or a different USB port on your computer. Note: If your eReader's battery is completely drained it can take up to 15 minutes before it reacts to being plugged into power.
  • If you're having trouble while reading a book on your Kobo Aura H2O, Kobo Aura, Kobo Aura HD, Kobo Glo, or Kobo Mini: tap the centre of the screen to bring up the Reading Menu, tap the > Home icon to return to your Home screen, then open your book again.
  • If you're having trouble while reading a book on your Kobo Touch: press the Home button and open your book again.
  • Try a basic reset.
  • If you're still having issues, consider a factory reset.
  • If you're unable to reset your device, please contact Kobo Customer Care
Mar 14, 2015 | Kobo 6" eReader Touch Edition
Kobo mini screen images stuck in one corner
From what you say I would recommend a new unit
Aug 29, 2014 | Kobo Mini E-reader - White
Kobo mini factory reset not working
Its either the lcd is damaged or is not connected
Aug 19, 2014 | Kobo Mini E-reader - White
Why can I not download books onto my mini kobo? Chelsea
hi download a free copy of calibre e-books and use this to upload your books. if you get stuck look on youtube and there are video's that will help you. hope this helps.
May 25, 2014 | Kobo Mini E-reader - White
Kobo is frozen
I would suggest plugging it into a wall charger for at least an hour to see if it was a weak battery.
If that does not help try connecting it via it's USB cable to a PC - this sometimes sparks it into life.
If not go for the soft power reset. (Hold the power button for a slow count of 30, release. Tap to turn on.)
Jan 21, 2014 | KOBO, INC Kobo Mini
Mini usb port on kobo arc is broken. Where can I get parts?
Hi i managed fix my usb port , open the kobo and remove the usb ribbon, the usb port is glued at the rear , you will see a black blob od adhesive at back of port , this comes unstuck if it gets a knock , i gently lifted this slightly then slid some super glue underneath and then applied pressure on top of the usb port to ensure the port was contacting the ribbon again until the glue set, my kobo is back in action again , hope this helps someone
Jun 20, 2013 | Kobo Arc
How do i change font size on my kobo mini
while in a book, tap in the middle of the page, the second to last button on the bottom of the page - (looks like four directional arrows) then the bottom of the screen will change and you will now see a slider bar on the left with plus and minus sign- Tap on either to change the font size.
Jan 18, 2013 | KOBO, INC Kobo Mini
Kobo vox power supply drawing
check with pick buzzer metter & find power switch connection to usb or" headphone socket.
May 29, 2012 | Kobo Vox K080-KBO-B Reader
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
