Bush hw60 1460d
The machine is only using a small amount of the fabric softner after the cycle most of it is still in the drawer.
zeusfaber
  • 247 Answers
SOURCE: Fabric Softner Drawer
Usual cause is old conditioner blocking the siphon (built into the drawer) which is there to suck the stuff out. Try taking the drawer right out, and giving it a thorough wash in very hot water. The siphon is often made in two parts - if you can get the top off, then do so, giving the inside of the cap and the tube which goes through the bottom of the drawer a good wash too. A.
Posted on Feb 11, 2007
  • 116 Answers
SOURCE: Tricity Bendix washer won't take fabric softner in rinsing cycle
Your machine possibly has a defective water inlet valve which is preventing water from entering the dispenser channel to flush the fabric softner into the machine. The inlet valve in inside of your machine right where the washer hoses attach. the solenoid valves on the inlet will need to be checked with a multimeter to verify if they are working properly.
Posted on Mar 11, 2007
SOURCE: whirlpool duet fabric softner problem
According to the whirlpool FAQ's page, that is normal. They stated that at the end of the cycle, fresh water is used to clean the detergent holders. Not sure that I believe them though.
Posted on Dec 28, 2007
  • 220 Answers
SOURCE: fabric softner does not empty
I had a similar problem and removed the complete dispenser drawer and washed it in with hot water. The small inner cups for the fabric softener and bleach should be removed and the hot water directed into the small "stand pipes" on the back side of the covers. It appears the fluids in the cups are siphoned out and if the pipes are clogged at the bottom there will be no flow. Also is the plate is not fully seated, the siphon effect is will not work.
Also, my wife said she does not use the cheaper brands of fabric softener anymore because we think that might have caused some of the clogging.
As a side note, if you remove the top of the washer, there is an adjustable dial where you can fine tune the amount of liquid dispenced. You can try adjusting that too. I think my final fix was to clean the back side of the face plates inside the dispenser and ensure they are fully seated to allow the proper siphon effect.
Posted on Jan 15, 2009
  • 19 Answers
SOURCE: Softner drawer fills with water
Hi, this is a not to uncommon fault on washing machines, but is easy to fix. What has happened is that the softener has built up in the outlet tube (it's actualy part of a small siphon system which ensures that the softener part of the drawer empties fully). Just take out the drawer, you will find a small resistance to withdrawing it but dont worry! You can now lift off the cover of the softener section and you will see the tube. Clean out the tube and wash everything in hot, NOT BOILING! water. Put it all back and that should be that...........Hope this helps....Let me know?.....Regards.....Cornwellnet (UK)
Posted on Jul 09, 2009
Fabric softner does not empty into washer during rinse cycle
Hi not sure how these work as we dont have them in the UK. With UK machines the soap and fabric softner are put into a drawer that pulls out the front of the machine. When softner and soap arnt going into machine properly we take drawer out and wash it in warm water, you usually find a lot of gunk built up blocking it, perhaps you have a similar problem. Hope this helps
Jul 27, 2011 | Kenmore 43052 Front Load Washer
I would like to know what laundry detergent and softner to use in my front load, and the right amount to use. I buy the H E products and some of them are really sudsy in the wash sink and I have this awful...
You should use HE detergent following the directions for that detergent. You can add liquid fabric softener. Make sure to fill the appropriate compartment to the Min line if you are doing a small load.
I've never used a washer that drained into a sink (always had a stand pipe). However, I suspect that the gummy residue is the excess softener that was removed in the rinse cycle. Try rinsing the sink with hot water after a laundry. This is part of the procedure to clean the inserts and detergent/bleach/fabric softener drawer when you get a build up in the drawer. In the future, use less fabric softener in the washer. Alternately, skip the fabric softener in the washer but use a dryer fabric softener.
The manuals for most Frigidaire appliances are available from http://www.frigidaire.com/manuals .
The direct link for the manual (in English) for the is: http://manuals.frigidaire.com/prodinfo_pdf/Webster/134609000een.pdf .
I hope this helps.
Jun 05, 2011 | Frigidaire ATF6000ES Front Load Washer
Despite cleaning out the drawer, the fabric softner is still there at the end of the wash. Have cleaned the drawer several times, but to no avail. Any suggestions?
Remove drawer/ look inside opening of washer ( at the top of opening inside) there is small little holes for the water to come through to fill the fabric softner spot and also bleach spot and detrgent spot. Holes may be pluged use a old tooth bush or some item to clean holes..Hope that helps thanks for voting.
Mar 18, 2011 | Washing Machines
The fabric softner is not draining during the cycle
Normally caused by undissolved soap residue. Switch off machine from mains, Remove detergent drawer from washing machine, there might be a small plastic clip that need to be levered by hand before the drawer can come out completely. Soak detergent drawer in a tub of water, rinse under tap and wash thoroughly until all soap residue has been washed away. Replace drawer.
Jan 15, 2011 | Frigidaire ATF6000ES Front Load Washer
Fabric conditioner compartment will not empty when in cycle
FJS1225W Front Load Washer This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
May 17, 2010 | Zanussi FJS1225W Front Load Washer
My washing machine fabric drawer is blocked have cleaned complete drawer but still fabric softner is in the drawer at the end of cycle .
Pull the little 'hat' off it's post in the fabric softener compartment. Clean off any softener residue and return.
Mar 17, 2010 | Hotpoint Washing Machines
Will not take softner?
clean the dispenser drawer, then using thin pipe cleaner clean the two outlets that fall over the softner drawer, its easier if water is flowing from them, to do this switch on the servvice cycle (no clothes in the machine) as u swtich it on, hold the start pause and skip button down and then press the fabric button repeatedly until the water comes through the outlets over the softener compartment.
to exit service cycle u must swtich the machine on and off twice
Dec 28, 2009 | Zanussi FJS1225W Front Load Washer
The fabric softner release has stopped working
Most likely the fabric soft dispenser is clogged . this happens when you wash alot in cold water the left over fabric softner get very pasty and can clog it up. You can try filling the dispenser with hot water and run a cycle with hot water this should unclog the dispenser .
Nov 26, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Dispenser tray removal
hi, nikoltheis! i'm not sure if we have exactly the same model, but it should be pretty close. here's what my user's manual says:
Detergent and fabric softner may build up in the dispenser drawer. Residue should be removed once or twice a month
- Remove the drawer by first sliding the safety latch to the right, then pulling the drawer out until it stops.
- Reach back into the left rear corner or the drawer cavity and press down firmly on the lock tab (left rear portion of the drawer). Pull out the drawer.
- Remove the insert from the bleach and fabric softner compartments.
- Rinse the drawer and inserts with hot tap water to remove traces of accumulated powders and liquids. Large amounts of fabric softner residue may indicate improper dilution or that more frequent cleaning is required.
- To clean the drawer opening (the empty area left behind when you remove the drawer) use a small brush to clean the recess. Remove all the residue from the upper and lower parts of the recess. (The picture shows this being done with a tooth brush.)
- Replace the insert pressing "X" to lock it in place. Return the dispenser drawer.
Jan 18, 2009 | Frigidaire GLTF2940ES Front Load Washer
Jan 15, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
