Question about Cuisinart Brew Central 12-cup Coffee Maker
Tube on dcc 2400 cousin art is plugged? How do I clean it out?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Insert coat hanger wire in tube , .
Posted on Nov 02, 2013
I bought a cuisinart DCC2600 as a display model. The instructions weren't available. The only thing I can't figure out is the cleaning button. How will I know when to clean the unit and exactly how do I...
The Instruction Booklet for the Cuisinart DCC-2600 Brew Central 14-Cup Programmable Coffeemaker is available here:
http://www.cuisinart.ca/pdf/ibs/en/DCC-2600C_en.pdf
See page 9 of the booklet for Cleaning and Maintenace and use of the clean button.
Mar 18, 2011 | Cuisinart Dcc-2600 14-Cup Coffee Maker
My problem is delayed brewing with my DCC 2000. Sometimes when I turn it on to brew it does so right away, but usually it delays for up to 45 minutes.
Hello judgemgj,
I think I can help you. This is a really common problem with the cuisinarts. I am most familiar with the DCC-1200, but you may be able to solve the problem. The may be an indication that something is plugged up. Open the top of the unit and in one of the corners you should find a water filter stick or column that is removable. Pull it out and open it up to clean out the clogged up carbon filter in there. (You can later buy a new filter on Amazon.) Clean out the debris from the bottom of the cavity. Replace the stick into the cavity once cleaned. Now it's time to run through a solution of 2 parts water and 1 part vinegar. Do this once or twice with fresh solutions, then with a pot of fresh water. When the filter stick is plugged up the sensor says its time to clean it or shuts the unit down or the unit brews too slowly, but many people don't know about this fix. I hope this is helpful to you, judgemgj. Positive feedback is appreciated. Good luck. NormanZ
Jul 04, 2009 | Cuisinart DCC-1200 Coffee Maker
Star Wars Battlefront 2 for PS2wont work
if its not new clean and if it is or isnt try asking lucas arts or get a new one from them
Jul 01, 2009 | Star WARS: BATTLEFRONT II PlayStation 2...
Cuisinart DCC-1150 series coffee pot how to clean reservoir
Hello dhubert14,
This is a really common problem with the cuisinarts. I am most familiar with the DCC-1200, but you may be able to solve the problem. This an indication that something is plugged up. Open the top of the unit and in one of the corners you should find a filter stick or column that is removable. Pull it out and open it up to clean out the clogged up carbon filter in there. (You can later buy a new filter on Amazon.) Clean out the debris from the bottom of the cavity. Replace the stick into the cavity once cleaned. Now it's time to run through a solution of 2 parts water and 1 part vinegar. Do this once or twice with fresh solutions, then with a pot of fresh water. When the filter stick is plugged up the sensor says its time to clean it, but most people don't know about this fix. I hope this is really helpful to you, dhubert14. Positive feedback is appreciated. Good luck. NormanZ
Apr 01, 2009 | Cuisinart DCC-1200 Coffee Maker
Clean light will not off after cleaning cycle performed 4 times
Unplug the machine for 20 minutes or longer - don't skimp on the amount of time, or it won't work. After 20 minutes, plug the coffeemaker back in, and you will see that the self-clean light is now off.
Mar 29, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Dcc-1200 not working
Probably dead, but:
Here is the basic troubleshooting for the Cuisinart coffee makers:
Make sure all baskets are in proper place – especially if unit is beeping.
Do not use a paper and a gold-tone or other permanent filter at the same time.
Unplug for LONGER THAN 15 full minutes to reset.
Clean by brewing 2 oz of distilled white vinegar/2 oz water.
If these methods fail, the unit probably requires replacement – call Cuisinart as they have a longer-than-standard warranty.
-Tha Mp3 Doctor
Nov 10, 2008 | Cuisinart DCC-1200 Coffee Maker
See post on Cuisinart customer service. The tube can be purchased at Lowes. Clear vinyl 1/2" O.D., 3/8" I.D. The compression clamp will have to be replaced as well.
I used a 1/2" hose clamp available at any auto parts store.
Aug 19, 2008 | Cuisinart DCC-1200 Coffee Maker
Xerox 2400 Driver
you are using the right software or the operatuing system is not compatible with the software
Mar 02, 2008 | Xerox One Touch 2400 Flatbed Scanner
Cuisinart Coffee Maker DCC 2200
The user manual is a free pdf download from the cuisinart web site.
Dec 26, 2007 | Cuisinart DCC-1200 Coffee Maker
Open Questions:
See all Cuisinart Brew Central 12-cup Coffee Maker Questions
Cuisinart Brew Central 12-cup Coffee Maker Logo
26 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
