Question about Dacor ER36DSCH Dual Fuel (Electric and Gas) Kitchen Range
Can the dacor range be wired to 120 volts - Dacor ER36DSCH Dual Fuel (Electric and Gas) Kitchen Range
  • 46 Answers
Sorry, 220V only.
Posted on Oct 20, 2013
The elements only work if the fan is turned on. And they do not get real hot and the fan does not go full speed why is that?
Bad wiring. I'd guess you are trying to run the elements via the fan! Double check your work. This could be a very dangerous situation if not to you, those near you.
Apr 01, 2015 | Kitchen Ranges
Dacor ERD30 oven trouble
HI,
Check if both circuit breakers for the oven are on.
The control board needs only 120V but it should be 240V for the heating elements to function properly.
Check if there is 120V coming to the thermal fuse.
when you get your meter . put the oven on bake and check your power on the bake element if you do not have 240 volts then your control board is bad. if you have 240 volts then you element is bad.
Goodluck,
Please don't forget to rate the solution.
Mar 25, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
Need arc fault breakers for a 127 volt system
If your question is in regards to a standard home panel system with a 120/240 feed the single pole arc fault breaker are rated for that installation. The 120 voltage is nominal and covers a range, usually +- 5%. So your 127 is within range for the 120 volt breaker.
Mar 05, 2014 | Electrical Supplies
My grill won't light when I turn it on. Have to use a lighter. Also light won't come on even though bulb is new and button lights up when I turn on.
Unlike most other high in gas grills, your Dacor requires 120 volts for everything that's electrical (i.e. ignitors, rotisserie, lights, etc) therefor, there are several connection blocks and transformers that may be causing the problem. The lights, for instance, use a low voltage 12 volt transformer. Nevertheless, before I say, that the transformer or circuit blocks and contact switches are bad, you need to trace all the wiring to make sure all the connections are intact. It won' t be an easy job, but it's one that is necessary. Having a multi-meter circuit tester will be a big benefit, as you can test where the power starts and where it ends and everything in between, .to see where the problem(s) lie.
To help you, I have included a link to Dacor's, Owners Manual page that has your model number listed. The Owners Manual has a schematic for everything electrical, which will be a benefit to you. You can download and print the manual, if you so desire.
http://www.dacor.com/Customer-Care/Manuals-And-Specs.aspx?TaxonomyId=155
Hope this help you solve the problem.
Mar 21, 2011 | Dacor Epicure EOG36 (LP) All-in-One Grill...
Is my PGR 30 Preference 110 or 220
in cking with breakdown this is a gas cook top and also is the oven . using all 120 volt . there is no 220 use inthis model . there is probably a power cord in the back . it will only plug to 110/120 rec . no cord is required other than the one on the range .. hope this helped ****
Dec 04, 2009 | Dacor Preference PGR30 Gas Kitchen Range
We have a twenty year old electirc jenn-air range with vented cooktop. the oven and range top both stopped working. digital clock only worked when light was turned on. repair man said it was not geting...
The problem may well be a loose NEUTRAL wire to the range. At the wire terminal on the range check for power from each supply leg(L1 to N) and (L2 to N) to neutral(should read 120 volts) and across each power leg (L1 to L2) should read 220 volts.
If you in fact have 220 volts into the range with good neutral contact the problem is a bad neutral(ground) in the wiring harness inside the range.
Sep 29, 2009 | Jenn-Air Kitchen Ranges
Does the Dacor rsd30 have an internal circuit breaker?
Hi!!!you seem to have a problem with your hi- limit switches show here they are resetable in dacor products..just press the top of the hi-limit swith and you will be fine'' they are show here.Good luck
Jan 04, 2009 | Dacor Preference RSD30 Gas Kitchen Range
Dacor duel fuel range
F1 is a Relay circuit failure . you have a bad relay PCB or wire connection.
92028 RELAY PCB, 105 C
Aug 19, 2008 | Dacor Preference RSD30 Gas Kitchen Range
Electric stove lights work but nothing else
sounds like the range is not getting 240 volts. When it only gets 120 volts lights will work but no heating element will. You need a volt meter and make sure that you have 240 volts across the black and red wires. From black to white and from red to white you should have 120. If you find you have a voltage problem you need to check your fuse box. you could have a fuse out or a circuit breaker can also be bad
Jul 24, 2007 | Whirlpool RF302 Electric Kitchen Range
Dacor ER36DSCH Dual Fuel (Electric and Gas) Kitchen Range Logo
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
240cpa
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
