Question about Samsung i70 Digital Camera
MEMORY FULL My new camera is saying memory full after just 1 photo. I have not inserted a memory card yet or downloaded the software, do I need to do this first before the internal memory becomes active?
  • 2,985 Answers
Talking about the Camera only here Check the manual for internal memory use. Put the memory card in. Use the menu button to switch between internal and card If your computer is XP you do not actually need any software to read the camera. Check the manual re this
Posted on Sep 27, 2007
What if your camera says Memory full and there is no sd card in the camera and no pictures or files
Some digital cameras have a small internal memory, maybe that's the memory gone full, to download pictures from there you need the USB cable provided with camera or change photos storage location in setup, after inserting a SD card.
Nov 13, 2015 | Cameras
Why does my Olympus FE-210 says ' Card full' on the screen ?
Usually because the memory card in the camera is full and cannot record any more photos. You have to insert a new memory card, or delete some photos from the current inserted card.
Jul 12, 2014 | Olympus FE-210 Digital Camera
I cant download anything from the playstore.
If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Jan 25, 2013 | Cameras
Have a GE x500 camera. Sometimes my pictures come out white or just missing on the memory card. This will happen with several in a row. What is this and how do i fix it?
All your pictures are still stored on the memory card of camera.You can recover lost pictures from memory card with photo recovery software.
1.Stop using this memory card to avoid overwritting your pictures by new ones.
2.Insert the card into a card reader.Connect it with your computer.
2.Download a photo recovery software.Recommend this photo recovery software: Photo Recovery Software for Windows users
3.Install the program and scan your memory card to look for lost pictures.It shows you the thumbnails of your pictures.
Jul 28, 2012 | GE X500 Digital Camera
Accidentally hit reset and lost all the photos-is there some way to retrieve them or are they lost forever? This is for a Fuji Finepix F470.
I have had success with this camera photo recovery program... You can read the detail instructions from
You have to use a card reader either on your computer or an external USB card reader. Put the card in the card reader, open the recovery program, then select the drive where files are deleted, then press "Start" and wait for it to do it's magic.
Jul 02, 2011 | Fuji FinePix F470 Digital Camera
When I turn my camera on now it says "no image",A child pushed every button on every menu item I think.Before this happened I had taken about 60 pictures and most of them had the protection lock...
I had success with this:
1. Remove the memory card and then connect the memory card to computer with a card reader, or insert the memory card to card slot if there's any on computer.
2. Download asoftech photo recovery program from
3. In asoftech photo recovery program, scan the memory card and recover your photos.
Apr 04, 2011 | Cameras
I have a vivitar camera from a friend and she took her memory card out then i bought my own brand new memory card with nothing on it and new batteries too. then when i try and take a picture it says memory...
From the manual:
Installing SD Memory Card
Your camera has a memory card slot that enables you to insert any "SD" compatible memory card up to 8BG. Adding a memory card will allow you to increase the capacity of your camera before you have to transfer photos and videos to your PC. Install the SD memory card as below:
  1. Locate the Memory Card slot within the battery compartment.
  2. Insert the Memory card into the slot in the correct direction. (see the sketch below)
  1. Push the card in until you feel it "click" into position. The top of the card should be flushed with the surface of the camera. An icon will appear on the LCD screen after you turn on your camera.
  2. Once the external memory card is inserted into the camera all the images taken with the camera will be stored on the card.
  1. Limited internal memory is provided for test images. The image will be deleted when camera power is turned off. Please download the images before power off .SD memory card is required for normal use.
  2. An external memory card is required for normal use. Your camera supports any compatible SD memory card (up to 8GB).
  3. If there is a photo in the internal memory when you insert the card into your camera, a "Copy to card" message will appear on the LCD with Yes or No options. On selecting 'Yes' the photo will now be copied to your card.
  4. Formatting will delete all data on the SD memory card including protected data.
  1. Don't remove the SD card during formatting as this may damage the card and render it unusable.
  2. When your card is full, download the media on the SD card to your PC and delete the photos and videos from it in order to continue using your
Dec 24, 2010 | Vivitar ViviCam 8025 Digital Camera
Card 'full' but no files found...olympus 1040
hi, there's a problem in your memory card and you need to do first is format the memory card into camera (if its ok to you to delete all the picture save in memory card). If the problem still occur you need to buy new memory card.
thank you and good luck my friend
Jul 17, 2010 | Olympus Stylus / mju 1040 Digital Camera
Deleted the images from memory card, how to recover it??
I had success with this memory card recovery tool
1. Do not save any new file to memory card.
2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download recovery software, recommended one is asoftech photo recovery (simply because i was using it and it worked)
4. Install and open the photo recovery program, select your memory drive, and click 'Start' button to start scanning process which will find your deleted photos.
Nov 25, 2009 | Cameras
Memory card is full
Please transfer all pictures i on your laptop, format memory card by camera Menu, now memory card isl free for more pictures.
Feb 09, 2009 | Sony Cyber-shot DSC-T50 Digital Camera
Samsung i70 Digital Camera Logo
147 people viewed this question
Top Samsung Cameras Experts
Are you a Samsung Camera Expert? Answer questions, earn points and help others
