Question about Acer Aspire SA20 PC Desktop
Password motherboard hard drive has been foramatted. Trying to install windows bios is locked with a password tryed passwords, cant get in.
  • oliverchurch Sep 29, 2007
    Yes it worked shorting the mother board. I thought i did contact you. Many thanks I'm well happy
    President:
  • 2,961 Answers
Open side panel of tower and locate the CR2032 cmos battery and remove for a few minutes then replace, try to access again. If no luck then look for a JBAT1 CLRCLK,CLRCMOS terminal and short the terminals to clear the password
Posted on Sep 27, 2007
SOURCE:
Using nexxtech 2.5
its just maybe that the device is not compatible with linux. try that to windows xp and see what happen.
CHARCOIS
Aug 27, 2008 | NexxTech Computers & Internet
I forgot my BIOS password and i can't access it becos i don't know the password.
HP Spare Key can be used to reset BIOS password. It is provided by HP Corporation. So when you forgot BIOS password on HP computer, just download it and get perfect BIOS password reset.
How to reset HP bios password with Spare Key or other ways?
Please refer to reset HP Elitebook password. In this passage, you also can learn how to reset Windows administrator password easily.
http://www.isunshare.com/windows-7-password/reset-hp-elitebook-password.html
Jun 12, 2011 | HP Compaq 6730s Notebook
Hard drive can detect on bios and start up but i cant format it or install windows on it, got more than 20 hard drives ( from a reseller) all have the same problem may be its password protected o dont...
If you are talking about problem with your password
You need to prepare:
1:A blank CD/DVD or USB flash drive
2.A computer which can link to internet
3.A program called Windows Password Recovery 6.0
Get started with this 3 simple steps:
Website: http://lost-password.net/products/windowspasswordrecoery.html
Step 1 - Download windows password recovery utility and install it.
Step 2 -Burn your Windows Password Reset CD:
To burn your CD, you'll need a blank CD-R and the .ISO file of Windows Password Reset.
Step 3 - Put in your newly created CD and remove your Windows password.
hope this helps
http://majorgeeks.com/download.php?det=5710
UBCD4Win is a bootable CD which contains software that allows you to repair, restore, or diagnose almost any computer problem also has a bios reset tool which can remove your password and bios password
you will have to burn it to a disk as an ISO then you will have to boot from the disc During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart (note after you have removed your password you will have change first boot back to your hard drive) Hope this helps
Apr 08, 2011 | Seagate Barracuda 7200.7 40 GB Hard Drive
Which co2 do i remove to reset the main passcodes
most motherboards have it printed next to the pins remove password if you still cant find it
hope this helps
you will have to burn it to a disk as an ISO then you will have to boot from the disc During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart (note after you have removed your password you will have change fist boot back to your hard drive) Hope this helps
Mar 31, 2011 | Intel D945GCCRG1 Motherboard
Purchased on Ebay an Asus which has a locked HD. I have booted it to USB stick with Knoppix. It has a 160Gb locked Western Digital drive. Is this a bios problem? Is it a HD firm ware problem. I'm not...
You have to erase the motherboard memory. However this is extremely difficult. Even if you esase the cmos memory and put in a whole new hard drive, the lock may still be there. Your best bet is to contact the seller to see if they will give you the password. If they dont want to help you then you should leave a negative feedback on their account.
Mar 21, 2011 | Computers & Internet
When i power on the laptop ask HDD PASSWORD SIR PLZ HOW CAN I REMOVE SIR
How to remove and unlock hard drive password? Is there any software to recover hard drive disk password? Where to download hard drive password cracker? Is it possible to reset the hard drive password?
According to Lenovo and many other manufacturers' website, if you forget your hard drive or hard disk password, there is no possible way to reset your password or recover data in the hard disk drive. Basically the hard drive is unusable. Scary right? However, this is often not true.
Most people are not aware that most hard disk drives have the ability to set a hardware password, just like the Bios password for motherboards, thus making the drive completely inaccessible unless a correct password is provided during the BIOS POST test. Usually these features can only be found in laptops, this is when you set a password on your notebook, the hard drive together with the motherboard becomes locked.
Most experts would say if you forget the original HDD or Bios password, there is no way of restoring it by generic system tools. Unlike the Bios password where there is a master key or with the removal of the bios battery, the password is erased from the flash memory thus the settings is restored to factory settings without the password, however, this does not applies to hard disk.
Jan 21, 2011 | Acer Computers & Internet
Hi I can not unluck my maxtor external hard driver, which requires password. May you please help?
According to Lenovo and many other manufacturers’ website, if you forget your hard drive or hard disk password, there is no possible way to reset your password or recover data in the hard disk drive. Basically the hard drive is unusable. Scary right? However, this is often not true.
unlock_recover_remove_tool_hdd_hard_disk_drive_password_software.jpgHDD Unlock Wizard is a user-friendly application which allows you to easily remove HDD password. IDE and SATA hard disk drives are supported. Both User and Master password can be removed. Please note that while unlocking, Remember HDD Unlock Wizard will erase and re-certify the drive, meaning to say all data in the disk is lost and not recoverable. HDD Unlock Wizard incorporates proprietary unlocking algorithms which allow removing an unknown HDD password and making hard drive usable again.
Download Hdd Unlock Wizard from here
http://www.hddunlock.com/download/
It may not be possible to recover the hard drive password or to unlock it; however, it is possible to remove the password together with the data, thus making your hard disk accessible and usable again.
Or Try Hiren's boot cd in this there is a operating system which boot from direct your cd/dvd rom. try it if it may open your locked external disk. And if your hard disk open in it just copy the data from the drive to any other drives and after copying your data format it. Then you see there is no password dialog box open in your normal windows log in.And for future if you use any software for password protection try to memorize the password in your mind or write it somewhere.
You can contact me or thanks me on my email id [email protected]
Aug 05, 2010 | Computers & Internet
Help clear bios
When you remove the battery from the motherboard wait after few seconds (30), reboot your computer without the battery and press the BIOS key (F1 or F10 or DELL key) will not ask you any password. Turn it off and Then put back the battery.
May 21, 2007 | HP (D5680-60001) Motherboard
Acer Aspire SA20 PC Desktop Logo
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
