Question about Amana AMH95 - 115,000 BTU - Gas-Fired Furnace - NG - 96.1% AFUE - Two-Stage - Upflow/Horizontal - Multi-Speed
Is there an on-off switch on the furnace? - Amana AMH95 - 115,000 BTU - Gas-Fired Furnace - NG - 96.1% AFUE - Two-Stage - Upflow/Horizontal - Multi-Speed
    Master:
  • 571 Answers
Generally, if there is not a breaker within line of sight, there will be a toggle single pole switch that will shut the furnace off. The blower cabinet will also have a door switch.
Posted on Dec 05, 2014
Ever limit switch i changed in my Weatherking furnace, it breaks the switch, what could cause this?
You need the model number of the furnace to determine what the flashing light is telling you. Many times the part that looks to be at fault is not the true fault in the furnace. A slow running blower could cause the limit switch to trip. The circuit board tells you that the limit tripped, but the real cause is the motor or clogged filter.
Jan 02, 2016 | FACTORY AC PARTS Limit Switch Double Pole...
Tip
Gas Furnace Repair - How to Change the Pressure Switch
Your gas furnace is not working and you think that the pressure switch is bad. Here are some things to check and the steps to replace it. Replacing is not very difficult at all, in fact it is one of the easiest thing that you can replace yourself.
Your gas furnace purge blower runs and never shuts off but your furnace is not producing any heat. Or your igniter will glow, light the burners and then the furnace will shut right back down and try to recycle all over again. Either one of these conditions are common if the pressure switch is going bad or has failed.
You can check the switch by placing a jumper wire across the wires going to the pressure switch once the purge blower has started. If the burner lights and stays lit the pressure switch is probably your problem. Could be a weak blower, but I would try the Pressure switch first; it is much less expensive to replace.
Once you isolate that the pressure switch is faulty, then you can change it. This is very simple. For most furnaces the wiring is low voltage, so the risk of shock is minimal. You should still turn off the power to be safe. Remove the screws that secure the switch and then just switch the two wires over to the new switch and secure the screws again.
That’s all there is too it a very simple operation.
Turn the power back on to the furnace. Re-fire the furnace and check the operation of the unit. It takes a while for the unit to cycle through the lighting process but you should have a furnace that now heats your house just fine.
http://www.fixya.com/support/r4016017-find_air_conditioning_heating_furnace
on Dec 06, 2009 | Heating & Cooling
Could a limiter circuit interupt the transformer from getting 24 volts to open the furnace valve?
Transformers typically supply 24v to the circut board, controls, and safety switches. 120v supplies the fan motor. limit switch is a safety switch and is part of the startup/ignition sequence. If the limit switch is tripped then there is a problem with your furnace that should be managed by a qualified professional in your area, or risk damaging your furnace, and perhaps causing a fire. Hope this clears things up.
Jan 01, 2015 | Heating & Cooling
Fraser Johnston Furnace - Not heating
Check the furnace filter to make sure its not dirty . Dity airvfilters can cause the furnace to overheat and shut off on a high temperature limit switch when the switchs cools down it resets but the furnace has to be shut off to reset the control board. Hope this helps.
Jan 23, 2014 | Heating & Cooling
Reeeeeeeeeeeeeeeeeeeeeeeeee
  • Hey, nofarmark91
    Turn the Coleman furnace system switch to the "Off" position on the electric service panel.
  • Locate the manual reset switch near the left side of your furnace blower. Your Coleman furnace has an upper limit switch for manual reset and a lower limit switch for automatic reset.
  • Press the reset button, which you will find in the middle of the limit switch. Use this manual reset button when the furnace burner will not operate. (See Reference 1 pg 4 "The Furnace Controls and their Function/Important" & Reference 4 # 3)
  • Turn the system switch to the "On" position.
  • Good Luck
    Jul 29, 2012 | Coleman Heating & Cooling
    Bryant 340mav036080 limit switch reset time
    The primary limit switch in your furnace is an "automatic reset" switch, and should reset itself within a few minutes.
    It is a safety device designed to prevent your furnace from overheating. If the furnace does get too hot, the limit switch opens and the burners turn off. The blower should continue to run until the furnace cools down again. The limit switch should then reset itself (usually less than five minutes).
    If it will not reset, try tapping on the switch with a screwdriver or other tool. This will often un-stick it. If this does not work, the switch has failed and must be replaced.
    A furnace will overheat for many reasons, but the most common are a dirty air filter (should be changed every 1-3 months), or a dirty evaporator coil (only if you also have central air). Make sure everything is clean and all your vents are open to help avoid this problem in the future!
    There are other limit switches in the furnace as well, which are "manual reset". They will not reset unless the little red button on them is pressed. If one of these switches opens, it is best to call a contractor to evaluate your furnace, as an unsafe condition may exist.
    Mar 02, 2011 | Heating & Cooling
    My furnace light is telling me that the limit swich is open so what can I do it is starting to get cold in here. Help please?
    on most furnaces the limit switch will reset its self.not knowing which furnace you have i will guess that there is maybe a resetable switch in the fan compartment or the roll out switch at the burner opening. either of these problems need your furnace looked at. the limit switch is over heating,bad motor dirty filter blocked air return, and the roll out switch would mean something is wrong in the combustion chamber
    Jan 08, 2011 | Dayton Gas Furnace Heater
    Furnace blower won't stop running
    Usually when the furnace blower motor runs all the time
    The limit switch or rollout switch is usually open or bad.
    The furnace board is seeing that one of those switches is open, so it brings the blower on to try to get the heat out of the combustion chamber area, so the switch will close. But if the switch is bad and won’t close, the furnace board will keep the blower running continuously.
    Jan 04, 2010 | Amana Comfort Zone 12M32PBEH Air...
    Coleman furnace -- fan runs, ingniter won't light,
    The chances are that the furnace was running when the power went out. This will cause the high limit switch to cutout and needs to be manually reset.
    You will find that switch in the blower compartment near the blower. Usually somewher near the highest point of the cabinet.
    Push the little red button firmly till it clicks.
    When the power goes out while the furnace is running the heat builds up because the blower shuts down immediately and causes this limit switch to cut out.
    If you have a electric tester you can also follow the low voltage circuit till you find the open switch. Ther is usually a wiring schematic on the door cover of most furnaces.
    I hope that this will help you to solve your problem!
    Thanks for using Fixya!!
    Heatman101
    Dec 09, 2009 | Coleman Propane Forced Air Heater...
    My gas forced air furnace is shutting itself off after 2-3 cycles
    there is a thermo-sensor switch next to the circuit board that tells the fan switch to turn on when the plenum is hot enough. this needs to be replaced.
    Dec 01, 2008 | Coleman Propane Forced Air Heater...
    Amana AMH95 - 115,000 BTU - Gas-Fired Furnace - NG - 96.1% AFUE - Two-Stage - Upflow/Horizontal - Multi-Speed Logo
    160 people viewed this question
    Top Amana Heating & Cooling Experts
    Bill Long
    Pete Norton
    Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
