Tr3100 thermostat problems
I have programmed my tr3100. In accordance with the instructions but ithe heating does not come on at all.
2 Suggested Answers
sbraddo129
  • 27 Answers
SOURCE: Do I have a wiring or other easy to fix problem or must I replace thermostat? My Totaline 0441 thermostat (installed in 2004) turns fan on as programed but just suddenly stopped producing HEAT.
It is possible that it is the Thermostat but more likely the heat source the thermostat is connected to. Set the thermostat to heat to as high as it can go. If the heat source does not come on in a few minutes you likely have a problem at the heater which may be a simple loose or burnt connection in the wiring or something more serious.
Posted on Jan 02, 2015
Testimonial: "Thank you Steve for your immediate & informed response. Unfortunately, the suggestion to turn Thermostat to highest heat did not work. I have two of the exact same thermostats and on one side of the house everything is heating perfectly. Does this mean I do have a heater connection problem & need a professional to repair? Thank you again for your expertise."
Tip
Thermostat Problems - How to Change the Thermostat for Heating or Cooling
You have a thermostat problem or you want one of those fancy new digital programmable thermostats and wonder if you can replace it yourself or if you need to have the HVAC Guy come and do it for you. The good news is that it really is not all that hard. With a bit of guidance you can easily do the job yourself. Here are some pointers that will help you to get the job done.
One of the most important things that you need to do is to make sure that you get the right thermostat for the system that you have. Find out what voltage your system is before you got to get a thermostat. Also know whether your system is a heat only or a heating and air conditioning system. If your system is a heat pump system then you need to know that also. Hybrid systems that use both the heat pump and a fossil fuel heater are much harder but that can be handled if you know it up front and plan accordingly.
Taking note of all of this information you can now go shopping for you new thermostat.
There are many choices to chose from and you usually will want to be in the mid price range. That will get you a good quality thermostat for a great price. If you are vision impaired you may want to look for a digital unit that has a back light. These make seeing the numbers much easier.
Once you find the thermostat that you want make sure to read all of the instructions that come with it. Reading these instructions will save you a lot of time and make your life a lot easier. Mark all the wires with the letter of the terminal that you removed the wire from. You will reinstall the wire under the same letter terminal on the new thermostat.
However before you remove any of the wires make sure that you turn off the power to your heating unit or air conditioner first. If you have both then it would be a good idea to kill the power to both to make sure you have the low voltage all dead. The wires to the thermostat are 24V AC usually and that will not hurt you but you could burn up a transformer if you are not careful.
Carefully remove and mark all the wires, and remove the old thermostat. Securely fasten the new thermostat to the wall and reconnect the wires to the new thermostat, if you are installing a programmable thermostat you may want to pre-program it before placing it on the wall. By inserting the batteries into the thermostat most of them will let you program them in your hands rather then trying to look at it on the wall.
That’s really all there is to changing your thermostat. If you can follow some simple instructions telling you how to read some letters and match wires than you can change your own thermostat.
http://www.fixya.com/support/r3869033-replacing_thermostat
http://www.fixya.com/support/r3892721-programmable_honeywell
http://www.fixya.com/support/r3902153-honeywell_rth7500d_thermostat
http://www.fixya.com/support/r3623083-thermostat_wiring_terminal_designations
http://www.fixya.com/support/r3894275-manual_honeywell_find_honeywell_manuals
on Dec 06, 2009 | Heating & Cooling
Jan 02, 2015 | Heating & Cooling
Installed a new Filtrete thermostat on a new Carrier high-efficiency furnace. I followed instructions exactly. It doesn't work. What did I do wrong? Furnace was installed in December. Broom handle...
Hi smargyle,
Welcome to fixya!
I can provide you with diagrams for the old Carrier therm and for the new Filtrete therm. But, I would need to know what the model numbers are for each therm plus how many speeds AC you have.
Please reply back with that information and we will get your AC back in working order.
Thanks,
Handie Andie
Jul 22, 2011 | Heating & Cooling
I put a new thermistat o a/c heat but only the fan is turning on the colors where white yellow red blue I did not put the blue on the O/b screw
your thermostat may need to be programmed according to the heating system you have. that'll be in the installer instructions. For the wiring, open up your heater to see a circuit board. coming to it are the thermostat wires, match your thermostat accordingly.
Normally the installer would do red - R, White - W, Yellow - G, and Blue - C.
It varies, so to be sure, check the furnace.
May 06, 2011 | Heating & Cooling
Thermostat was replaced on a 99 ford explorer sport but now ithe heat gauge on the car not coming on ???
the temp sending unit is located close to the thermostat. check to see if it came unplugged or clean the connector it may have corrosion inside causing it to lose contact othertwise u may need to replace the sending unit. leave comment
Jun 27, 2010 | 1999 Ford Explorer
I install new RTH7500D thermostat Honeywell, when I set for Cool it blowes heat when I set for a Heat nothing works I wire per instruction have two stage system
It sounds like the t-stat is programmed for a heat pump or you have a heat pump and the t-stat is programmed for a regular furnace....
Check out the manuals in the tip and go into the installer setup to change the t-stat to the proper programming for your system..
heatman101
Apr 24, 2010 | Honeywell Programmable Thermostat Heater
Y1 W1 Wire from older Honeywell to new RTH honeywell
Y1 means for cool and W1 means for heat. Connect accordingly.
Aug 11, 2008 | Honeywell Programmable Thermostat Heater
Thermostat does not stop heat pump unit
Most of these problems are the program settings on these way overcomplicated thermostats. You will need to re-read the instructions on setting the programs. Or bite the bullet and buy a cheaper and simpler one. If you installed it yourself, make sure the settings on the inside are correct, like gas/electric heat, and 24 volts, stuff like that.
Jan 22, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
95 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
