Question about Grohe Plumbing
Ladylux pro splashing problems - Grohe Plumbing
I have Grohe Ladylux and the flow will arbitrarily switch from stream to spray on its own.
Mine would stick in the spray setting. I soaked the whole head in vinegar to clean it and the problem went away.
Oct 05, 2014 | Grohe Ladylux Cafe Faucet with PullOut...
Clean lime scale from Ladylux cafe pullout
get a bottle of CLR and mix a batch then soak the head in it for awhile . Calcium Lime and Rust Remover
LOW PRESSURE ON HOT WATER ONLY
Same problem in other taps in the house or just there?
Feb 01, 2014 | Grohe 46309IF0 Ladylux Plus/Ladylux CafZ...
When replacing the hose on a Grohe ladylux, which end needs the gasket?
Need to replace Ladylux cafe 33755 hose, can't reach water line. How can they be removed?
Oct 25, 2012 | Grohe Ladylux Cafe Faucet with PullOut...
My new Ladylux appears to have an aerator, but it's doesn't work worth a hoot! All other brands of taps have properly functioning aerators that keep the water from splashing , but this one splashes...
if its new you should,nt have had to have spare parts fitted,sounds like the tap is faulty,take it back and have it replaced.if you change it and theres still a problem it looks like you might have to change the model
Nov 08, 2011 | Grohe Ladylux Cafe Faucet with PullOut...
I need a parts list and assebly instructions for a ladylux cafe
Hi. There are 6 different types of LadyLux Cafe. If you go to http://www.grohecatalog.com/line/LadyLux-Cafe you can choose your product and they have a parts list and an exploded diagram of each product. This should help and at least get you going.
Regards, Myles
Dec 31, 2010 | Grohe Plumbing
I've removed the screw but can't get the handle off my Grohe Ladylux single handle faucet.
many times the handles will corrode on tightly....
A sharp rap from a rubber mallet will sometimes work, but most of the time you will ruin the faucet when getting the handle off...
heatman101
Jul 09, 2010 | Grohe Model 28 206 OOO: Ladylux Plus...
How to change spray hose on grohe kitchen sink ladylux model
I have the Ladylux plus. I was confused on how to remove this as well. There is a quick release plastic piece, just pull down on the yellow part on the connector under the sink. Disconnect the plastic connector from the hose and pull it right out of the faucet. Very easy to remove in this case.
Jul 07, 2010 | Grohe Model 28 206 OOO: Ladylux Plus...
Grohe Ladylux slow to turn off
Your Grohe Ladylux should be under warranty. Call the company at 630-582-7711. Their customer service was great when they replaced my quick coupling after it broke.
Good luck
Jan 14, 2009 | Grohe Plumbing
Plumbing Logo
26 people viewed this question
Top Grohe Plumbing Experts
Donni Steen
john h
Mike
Are you a Grohe Plumbing Expert? Answer questions, earn points and help others
