Question about Super Bright LEDs Thumb-Lite Flashlight, White Thumb-Lite
How to change battery in thumb lite flashlight
How do you change the batteries in a 3D cell Great Lite flashlight
You just unscrew the cap at the end of the flashlight. You will also find a spare bulb in the cap.
Surprised you would buy one of these when LED flashlights are 5 times brighter and the LED lasts forever. Take a look at this one.
https://www.amazon.com/dp/B01JZ6BKCQ?psc=1
https://www.steveswholesaletools.com/products/greatlite-3d-cell-flashlight%7CL58%7CC68%7C05-32024.html
Great Lite GREATLITE 3D CELL FLASHLIGHT
Sep 13, 2016 | Electrical Supplies
Replace batteries on flashlight
Maureen, Coleman Graphite Flashlight replace batteries. Remove bottom cap, it will be on tight, if you do not have good strength in your hands use a pair of pliers or channel locks. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to change the batteries in Mag Lite
Aug 26, 2016 | Coleman Graphite Flashlight
How to open maglite flashlight to change batteries?
At the bottom of the Flashlight where the hole for a keychain ring is, or yours may have already came with the ring attached, although it may seem to be so perfectly welded or casted that thrrs no seam, if you twist the end by the ring attached or can grip it, the end twists off to allow you to switch the AA battery. Hope this helps
Aug 23, 2011 | MagLite Mag-Lite& Flashlight
How do you change the batteries in the playskool flashlight
Welcome to Fixya.
To change batteries: remove the screw on the tab on the back of the flashlight. With thumb or coin, move the tab up to unsnap the battery holder. Slide out the battery holder and replace 2 C batteries.
Thanks for using Fixya.
Jul 01, 2011 | Playskool Toys
I could not unscrew the bottom part to change the battery. Should I use unscrew it by anti clockwise or clockwise only. I even spray WD40 beforehand.
Counter clockwise to get bottom cap off. They're usually pretty tight because cap is steel and tube is aluminum. Grab tube with pliers and try turning cap
Jan 30, 2011 | MagLite Mag LiteĀ® 2x 'd' Battery ...
Charger lite will not come on! there is power to charger and if you wiggle lite the charge lite will blink but not stay on
It sounds like the battery is completely dead. Try placing it in the freezer for a couple of hours and attempt to charge it. If that doesn't work, you will need to know the make a model of the flashlight it goes in as well as the voltage. If you have to purchase a new battery I would suggest you purchase a Nickel-Metal Hydride (NiMH). NiMH's have much higher capacity than NiCd's and don't suffer from memory effect.
May 20, 2010 | Streamlight Ultrastinger Rechargeable...
I had to change the battery 2 D and now it doesn't work. I have never had one work after I change the batterys what am I doing wrong?
Unless the bulb is burned out or you are putting the batteries in wrong there is not much that can go wrong with a flashlight.
Jan 22, 2010 | MagLite Mag Instrument Mag Lite 2 "D"...
Can't open the battery compartment.
i think you unscrew the light end of the flashlight .... not the **** end
Oct 25, 2009 | MagLite Mag-Lite& Flashlight
Super Bright LEDs Thumb-Lite Flashlight, White Thumb-Lite Logo
79 people viewed this question
Top Super Bright LEDs Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Super Bright LEDs Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
