Question about Oki Electric Industry C8600n Led Printer
Oki c8600 HOW TO CALIBRATE - Oki Electric Industry C8600n Led Printer
2 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: OKI C8600 Replace Image Drum - 563: K Drum Life
Solution:
  • Power on printer while holding both the + & - buttons simultaneously; release when “OKIUSER” is displayed.
  • Press either the + or – button until “ENGINE DIAG MODE” is displayed; press the Enter button and “DIAGNOSTIC MODE xx.xx.xx” will be displayed.
  • Press and hold both the - & On-line buttons simultaneously until “ENG DIAG LEVEL2” is displayed.
  • Press either the + or – button until “CONSUMABLE COUNTER SET” is displayed, press the Enter button; you are now in the menu to set various consumables.
  • Press either the + or – buttons to scroll through the various consumables, at the desired consumable press the Enter button and the last digit of the count will start flashing.
  • Press the Cancel button to decrease the digit amount or press the On-line button to increase the digit amount; press the + or – buttons to move along individual digits in the count.
  • Once the count is at the level you desire, press and hold the On-line, Cancel, & Back buttons simultaneously until the “*” reappears next to the count; consumable’s count are reseted to the number you specified.
  • Press the + or – buttons to move to the next consumable and repeat at step 5.
  • Once all consumable counts have been set to desired amounts that are below their end-of-life thresholds, you can use the Back, +, & - buttons to exit through the menus
  • until “INITIALIZING” is displayed.
Posted on Jan 30, 2010
HOW DO I FIX EPSON C8600 E520 ERROR?
This site:
Thread Epson Aculaser C8600 Service Req E520
says, "If you're not a technician, I'd suggest doing what the error says and calling a qualified service organization."
Feb 26, 2015 | Epson Stylus C86 InkJet Printer
Oki c8600 registration error 3
Registration Error 3
When a color registration error is detected with coarse
adjustment, or with the main-scan line adjustment.
PU firmware does not notify this warning to CU firmware
at the time of Shipping Mode. Therefore, this status
does not occur in a user environment.
n
2 = Yellow
3 = Magenta
4 = Cyan
Dens Shutter Error 2
DENS SHUTTER ERR
Check 3: Check to see whether the sensor shutter opens and closes normally, by the
MOTOR & CLUTCH TEST of the self-diagnostic function. If the shutter operates
imperfectly, replace the shutter unit.
May 06, 2014 | Oki Electric Industry C8600n Led Printer
Resetting drum life c8600
Go to
menu>Configure Device>Print Quality>select Full calibrate now
once it's completed then run following action:
Menu>Configure Device>Reset>Reset Supplies>New transfer kit>yes
you are done but it works if there still remaining bit transfer kit if its run out then not gonna work.
I Hope You resolve Your Printer Issue,
OR
In case You Need Online Assistance Then follow Us For ON: Epson Printer Support
Feb 04, 2014 | Epson Office Equipment & Supplies
Fatal Error 121
Hi and welcome to Fixya!
"Fatal Error" on your printer display or status monitor simply means a problem has occurred requiring action to clear. Fatal Error explanations are not usually found in the manual. You can check the list of error codes from the link below:
http://www.c8600.co.uk/index.asp?printername=C8600&menumode=0&content=errorcodes
RECOMMENDED STEPS:
First, try turning off your printer then turning it back on. If you're still getting the same error message, make sure the printer is plugged directly into the wall. Often, the issue is power-related.
If the problem persists, write down the message including the 3-digit error code number and send an email to "support@okidata.com" or call Oki Data Customer Support (1-800-654-3282) for assistance.
NOTE: If you see a series of letters and numbers scrolling across the display after the 3-digit error code, write it down and report them when calling or emailing Customer Support.
Jun 29, 2011 | OKI C5800Ldn Led Printer
Epson aculaser c8600 error message E833
my codebook said that in this particular printer service request e833 point to mis-assy ...
i do not know where are you located but in germany this bit cost over 300euro... bit can be exchanged on site by yourself, it is front part of the side feeder assy...
if you find my answer helpful, please do not hesitate to vote4 for me, thanx!
Aug 01, 2010 | Epson AcuLaser C8600 Printer
Solution:
Oct 14, 2009 | Oki Electric Industry C8600n Led Printer
OKI C8600 service manual.
http://safemanuals.com/user-guide-instructions-owner-manual/OKI/C8600N-_M
I don't know if it is this but i hope it helps
Cheers
Jun 21, 2009 | Oki Electric Industry C8600n Led Printer
K image drum
Go to
Good luck and rate all answers.
Mar 31, 2009 | OKI B4600 Printer
OKI C8600 Printer Toner Sensor Reset
I've had two toners that have done this, they register as used as soon as you turn the dial to open the toner compartment. So if they don't work properly, as soon as you remove them.. you can no longer use them. (they empty contents into the drum).
I got in contact with my supplier and sent them back as faulty cartridges.
Sep 30, 2008 | Office Equipment & Supplies
Oki C8600 control panel detached when delivered...
nope..i'd send or take it back, myself..could be a loose ribbon cable underneath, too, eh?
Mar 06, 2008 | Office Equipment & Supplies
Oki Electric Industry C8600n Led Printer Logo
Top Oki Electric Industry Office Equipment & Supplies Experts
Tony
Roger Binsfeld
Victorman
Victorman
Are you an Oki Electric Industry Office Equipment and Supply Expert? Answer questions, earn points and help others
