Question about Cfm 802 Ecofan Table
Determine what is wrong with my ecofan, motor or teg module
Heater fan runs when heater is off.06 ford expoler
Automatic or manual climate control ?
  • The blower motor does not operate correctly - manual climate control
  • Circuitry short
  • A/C blower motor resistor
  • A/C blower motor switch
  • Blower motor high speed relay
  • Go To Pinpoint Test O .
  • The blower motor does not operate correctly - EATC
  • Circuitry short/open
  • A/C blower motor speed control
  • EATC module
  • Go To Pinpoint Test Q .
Pinpoint Test Q: The Blower Motor Does Not Operate Correctly - EATC
Normal Operation Under normal operation, the blower motor control module receives a 1-2 volt signal from the EATC module through circuit CH218 (GN/VT) to determine the desired blower motor speed. The EATC module receives a feedback voltage from the blower motor control module through circuit VH219 (GY) to determine actual blower motor speed. When the highest blower motor setting is selected, the EATC module sends 12 volts to the blower control module through circuit CH217 (BN).
    Possible Causes
  • An open, short to voltage, ground or together in circuits CH218 (GN/VT), VH219 (GY) or circuit CH217 (BN)
  • Blower motor control module
  • EATC module
  • If automatic HVAC system i would suspect Blower motor control module .
Oct 27, 2016 | 2006 Ford Explorer
Ecofan not working
The problem is most likely a bad TEG module or possibly a bad fan motor. The most common problem is a failed TEG module. Caframo will not sell replacement TEG modules as they require you to return the fan to them for rebuild but the repair is quite easy. You can find the exact replacement on eBay or directly through Thermal Enterprises. They even have a troubleshooting and repair guide for the fan.
Feb 24, 2014 | Cfm 802 Ecofan Table
I forget my ip of TEG-S2600i 24-Port Ethernet
At the back on your switch there is a reset button. Press and hold it down for 10 seconds to reset it.
Default ip address of this switch is 192.168.0.1
May 07, 2010 | Trendware TEG-S2600i 24-Port Ethernet...
What is the power system for ecofans - these are the fans / motors which run on electricity generated by temperature differentials in two different and adjacent metals. I would likt to build my own if...
The power source is a thermoelectric module (TEG). Failure of this module is the most frequent cause for fan problems. You can get replacement modules for these fans on eBay.
Mar 13, 2010 | Cfm 802 Ecofan Table
Have had this for 4 years, works great. Blades have stopped moving though still rotate smoothly by hand.
The problem could be with the thermoelectric module. You can easily test if this is the case by trying to run the fan off of any household battery. If the fan works off the battery then the problem is definitely with the thermoelectric module.
They are easily replaced by taking the two halves of the fan body apart. Just be sure to use CPU heat sink compound (thermal grease) on both sides of the new module before you reassemble the fan.
You can get the peltier modules from Thermal Enterprises by contacting them through email to thermoelectrics@aol.com or searching for Ecofan Repair on eBay. The CPU heat sink compound (thermal grease) is available at any "Best Buy", "Radio Shack" or electronics store.
Hope this helps.
Dec 13, 2009 | Cfm 802 Ecofan Table
Fan just stopped turning, even if the fire is going good, what could be wrong?
Bushings dried out at rotating shaft. Clean and Lubricate with a high temp. dry film lubricant.
Dec 07, 2009 | Cfm 802 Ecofan Table
The metal strip on the bottom, can it be replaced?
There are no replacement parts for this fan available, however I managed to get mine spinning like new after it had died. I took the two halves of the fan body apart, and scraped the heat sink compound off either side of the power plate. I then applied CPU heat sink compound that can be found at any computer or electronics store liberally to either side, and put it back together. The fan spins like new, spread the word!
Sep 27, 2009 | Cfm 802 Ecofan Table
Ecofan.going.slow
The most likely problem is either mechanical binding (lack of lubrication) or a bad thermoelectric module. You can get replacement modules for these fans on eBay.
Feb 02, 2009 | Cfm 802 Ecofan Table
My ecofan quit working. Blades rotate rough
Sounds like a bad thermoelectric module. This module is what generates the power to run the fan. You can get replacement modules for these fans on eBay.
Dec 14, 2008 | Cfm 802 Ecofan Table
Ecofan only turns slowly
These fans can be rebuilt! Like many others, our fan died after being placed in the center of the stove top. I took the two halves of the fan body apart, and scraped the heat sink compound off either side of the power plate. I then applied CPU heat sink compound that can be found at any computer or electronics store liberally to either side, and put it back together. The fan spins like new, spread the word!
Nov 28, 2007 | Cfm 802 Ecofan Table
Cfm 802 Ecofan Table Logo
Top Cfm Dryers Experts
Are you a Cfm Dryer Expert? Answer questions, earn points and help others
