Error code E000020-03a2 on Canon ImagePress C1
  • 82 Answers
SOURCE: Canon ImagePress C1 error E000747-8000
E747 from what I remember is the connection cable from either the scanner to the print device, or scanner to the copier. Make sure that none are loose and they are in the correct slots.
Mismatching the cables may result in the error.
Posted on Dec 10, 2009
  • 71 Answers
SOURCE: error e020 0180 on canon imagepress c1 please give
getfile.asp?rid=1258 November 02, 2010 getfile.asp?rid=3215 Product : imagePRESS C1 / C1+ Title : E020 with Multiple Sub Codes for all Colors Problem :
Solution :
Check for a pinched or damaged wire harness from PS3 Patch sensor #2 from connector J426 back to the Side Driver p.c.b at connector J3415 and at PS7 ATR sensor from connector J209 back to the Rear Driver p.c.b. connector J3802.
getfile.asp?rid=33199
getfile.asp?rid=33201 Canon USA, Inc. Systems & Technical Support Division
Posted on Jan 24, 2011
  • 3 Answers
SOURCE: Hello, can you tell me
this is fixcinx releted error
Posted on Aug 22, 2011
Daniel S
  • 4323 Answers
SOURCE: Canon ImagePress C1 has error
Hi
This error is caused due to faulty thermister however; you can check the fuser unit for any jammed paper around the upper fixing roller and try to clean that area. After this is done try to clear the error by entering the service mode, to enter press Additional functions, #. Then go to #7 Printer and press OK, then go to #4 printer reset and press OK, yes= *. If the issue returns then replace the thermister. Hope this helps...please post back for further assistance.
Daniel
Posted on Sep 20, 2011
SOURCE: I have error code E000732-0001 on Canon imagepress C1
Dear Sir/Madam
My machine Error E00732-0001 Can't clear and repair.
Can help me.....very thank.
Posted on Nov 01, 2011
I have a machine canon imagepress C6011VP with error E00000-0201-05
hi if u get error E00000 as main code that's mean the heater problem
u should have to check the hater lamp and the thermal fuse in fixing unit if every things are good this is only malfunction just reset error code.
Oct 27, 2014 | Office Equipment & Supplies
Canon ir c3200 error code e0100-110
get manual here
http://www.scribd.com/doc/61327440/Canon-Irc3200-Service-Manual
Mar 23, 2014 | Canon iR C3200-C1 PS Ver1.0
When I turn on my canon ImagePress C1+ printer it stays in warmimng up state and never gets ready. what is wrong? how can I fix it?
when i turn my conon imagepress c1 printer it state and this error code come it e00001 - 001 what the problem and how can i fix it
Nov 17, 2013 | Canon Imagepress C1 Color Copier,...
Canon ImagePress C1 cannot calibrate from Windows 7
The problem is it doesn't recognize Java 7. Install Java 6 (latest version) and it will work. You can have both Java 6 and 7 installed at the same time. As well make sure if you are running a 64bit machine you install the 32bit version of Java (so you will have 4 versions installed). Java 7 32 & 64 bit, Java 6 32 & 64 bit. I had the same issue and solved it this way.
Jul 26, 2012 | Canon Imagepress C1 Color Copier,...
Waste toner canon imagepress c1
if it is the 2nd transfer cleaning waste toner, you have to clear copier-counter-misc-2TC-Box
Jun 10, 2012 | Canon Office Equipment & Supplies
Error e020 0180 on canon imagepress c1 please give me a reply
Solution :
Dec 19, 2010 | Canon CLC 1120 Color Copier
Canon imagepress c7000vp error code e000061-0481-05. what does it mean??
The laser shutter is faulty. The laser unit is faulty. The potential measure
Jan 16, 2010 | Office Equipment & Supplies
Dec 10, 2009 | Office Equipment & Supplies
Error :
E732 code
Workaround :
E732 code is a Reader communication error.
If the Reader is disconnected from the Printer a E732 code will result. Once the Reader is disconnected the logic on the MAIN-Controller is changed to a "0". The copier is now set up to be a Printer only, and will not recognize the Reader.
To correct this, you must enter service mode, COPIER>OPTION>BODY>W/SCNR and set that to "1". Then you must turn the copier off, then on.
To enter service mode: press "Additional Functions" then "2" and "8" together, then "Additional Functions".
Which User Guide? Reference, Easy Operation Guide, Printing Guide, Mailbox Guide, Sending Guide etc....
Sep 09, 2009 | Canon imageRUNNER C3200 Copier
69 people viewed this question
jasbo
jasbo
