Question about Dryers
I need a pole for the holmes floor stand #hsf1610a
2 Suggested Answers
male_28_cam
  • 1555 Answers
SOURCE: I just bought a Holmes 16 inch stand fan HSF1610A
First smell the fan, If you get burning smell then you need to send it for warranty repairs or to a repair shop. If no burning smell then check the electric cable for connectivity. Most probably it has gone bad and it's easy to repair. For checking it you need a electrical tester or multimeter.
Posted on May 02, 2011
I need a 3-speed fan switch for a Holmes stand fan #HASF1522
Just a thought
If you find a junker fan try the switch off of it. Quite often they will work. Sometimes different makes the switches are interchangeable.
Jan 31, 2015 | Holmes Products Dryers
I had a holmes HPF 650 MCU outdoor pedestal fan which worked great for five years and then abruptly stopped working. Rather than repair it, I tossed it out thinking I could purchase another one. ...
Hi Bill.
Holmes makes a very good fan.
You can buy a new one here:
http://www.overstock.com/Home-Garden/Holmes-HPF650-U-Oscillating-3-speed-Stand-Fan/3473589/product.html
Good luck from Detroit, MI.
Sep 18, 2011 | Holmes Products (HPF650MCU) Stand...
I need an owners manual for my Holmes fan, serial # HPF-650
Go to the Holmes Group web site and type in your model. Then you can download a PDF copy of the original manual.
Aug 20, 2011 | Holmes Products HPF650-U Stand (Pedestal)...
Hello. I have a stand (pedestal) Holmes fan, model number HASF-1516, that is not working when plugged in to the electrical socket. How do I go about troubleshooting?
Firstly please make sure that you connecting wire in not cut at any where and connection is good.
If your connection is ok then also it doesn't rotates then might be your coil has been burned and you need to replace its wiring and check the starter
Aug 18, 2011 | Holmes Products HASF1516 Stand (Pedestal)...
I just bought a Holmes 16 inch stand fan HSF1610A I only use it to sleep. Only have had it for about 2-3 weeks. I have not had a problem with it til I woke up this morning to it not working. It still...
May 02, 2011 | Holmes Products Holmes& Standing Fan
How to assemble the hawaiian breeze oscillating floor fan
I cannot find exact instructions but I did find a general guide to assembly. they are usually very easy to assemble.
A standing fan is a portable fan that has a set of three oscillating blades on a long neck. The neck, also called the pole or the leg, is mounted on the floor. Standing fans have evolved from their origins as noisy accessories that blew away papers in their vicinity to silent fans whose direction can be controlled remotely. When placed at a convenient location, a standing fan can distribute air evenly to the entire room. Its speed can be controlled, and many standing fans can be programmed to stop at a set time.
  1. Installation Requirements
    • The only requirement for installing a standing fan is making sure it is near a power source. The entire unit can be assembled manually with only a screwdriver. A single standing fan, either an oscillating or pedestal fan, is very simple to assemble for basic home use.
    Pole and Base
    • The first step is to lay the parts on a floor. Then assemble the pole on the base of the stand. This is very simple, because the grooves for the screws are already drilled, so the screws just need to be inserted and screwed in. Screwing the pole into the base of the fan is required on some models; on others, the pole and the base are molded together and no screws are needed.
    Motor and Fan Installation
    • One some fans, you have to install the motor and oscillating arm to the pole. This again is done by screwing screws into predrilled holes. Grooves for long screws are at the top end of the pole, where they attach to the motor of the fan. Once the motor is placed on the top of the pole, insert the screws in the predrilled holes and tighten the screws. The next step is to wire the three blades. This is done by taking the wires from the motor and joining them to the sockets in the pole. This finishes the assembly procedure.
      To turn the fan on, ensure that the wires fit securely together. A loose connection cannot not only hamper the performance of the fan, it can also lead to problems such as electrical shocks or burning wires.
I hope this helps
good luck
Please rate FIXYA
Apr 07, 2011 | Vacuums
Misassembled black 18" Holmes stand fan with remote (HSF1809R)
Hello cdelune. Glad to see you fixed the problem but Im having the exact same issue with the fan! Not sure what to do with the pole with the frayed ends and how to connect it with the plastic falanges. Ive been at it a while now so do you think you could help me out and post exactly what you did to fix it? Thanks.
Jul 25, 2010 | Holmes Products Dryers
Dryers Logo
26 people viewed this question
Top Dryers Experts
