Wt 102 indesit
Reset machine
4 Suggested Answers
jaylex
  • 417 Answers
SOURCE: Indesit widl 102 extra rinse button always on!
Check that the button isn't stuck it if not remove top lid and check the PCB and see if the switch hasn't collapsed causing it to be on all the time. Also if you hold in the go button for about 5 seconds this resets the program try this.
Thanks J
Posted on Feb 10, 2008
SOURCE: Trouble with Indesit WI 102 washing machine
I had trhe same problem and was going deaf!!! I know this is probably too late for your machine but it may be usefull to someone else with this model.
Originally thought the bearings had gone but had great trouble trying to source some through UK websites so decided to strip the machine. Did this by touch (no manual!) and eventually found that the bolts holding the bottom weight to the drum had all come loose (all 3!). Trying to access them to tighten was the biggest problem as the front of the machine is welded on.
Managed the above by removing the rubber door seal from the door only and tightening two of the bolts from inside the door. The third I managed to access from beneath the machine. All were tightened using 10mm socket on a bar with extension (curtain pole!) slid over the end.
During this process I had the machine on its side, removed the securing brackets, top weight + springs and wedged the drum from beneath and the side as much towards the rear of the machine as possible to aid access.
Good Luck!
Posted on Feb 22, 2009
ronald_kate_
  • 111 Answers
SOURCE: hI WHEN I TURN ON MY MACHINE ALL THE LEDS KEEP
Hello, this usually is signaling that there is a problem in your machine. You will need to get a service technician in to diagnose the problem for you. I hope this is somewhat helpful.
Posted on Nov 04, 2009
Indesit witp 102 - the engine is not starting - a click sound can be heard every time it tries to spin. if i use a hair dryer to warm the engine and the parts inside it starts and works fine :) can this be...
Check the capacitor, but be careful, they store a good charge, like a tazer! Once removed and safely discharged, check it for damage and function. A dent will ruin it.
One check is to connect an ohm meter to the tabs, the needle should swing over and come back. Reverse the leads and do it again, the needle should swing again. If so, it's usually good.
Also check the motor bearings. With the belt off, the pulley should not be able to move side to side, and the motor should spin freely and quietly.
Nov 25, 2013 | Indesit Washing Machines
Indesit Widl 102 Flashing lights, wont turn on
Hi
Thanks for using FixYa. It seems to be the issue with the Thermal Fuse going bad and/or its panel that is going bad. To start with check the Thermal fuse which is mounted to the exhaust duct inside the back cover panel. Please do accept the solution if the issue is resolved or post a comment with a more detailed question including the manufacturers name and model no# for your dryer so that I can further assist you.
Thanks
Rylee
Jun 14, 2010 | Indesit Dryers
I need to reset my delay timer on my wil133
how do i reset my indesit wil 133 machine as it wont start on any programme
Nov 27, 2009 | Indesit W 123 Front Load Washer
HI WHEN I TURN ON MY MACHINE ALL THE LEDS KEEP FLASHING. IT IS A INDESIT WIDL 102 WASHER DRYER.
Nov 04, 2009 | Indesit WA 115 Front Load Washer
Indesit WIA102 keeps draining, even when washing
Try lifting the drain outlet higher than it is, if it is too low the water will syphon out as it is filling, there by causing the problem you are experiencing, if that does not solve the prob, then it sounds like the pump is on all the time, this being the case, then it would appear that it has a faulty programmer.
Plz rate my solution.
Thanks.
Jan 22, 2009 | Indesit W 123 Front Load Washer
Indesit WIDL 102
almost certainly a new module and eprom. these modules have given a lot of problems.
not really worth doing
Jun 25, 2008 | Indesit W 123 Front Load Washer
Good Luck!
Mar 09, 2008 | Indesit Washing Machines
Dishwasher indesit DI62
green light 2 flashing sounds like machines doing something switched of at mains & back on to same flashing green light
Mar 01, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Thanks J
Feb 07, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
