Question about Dryers
Maytag dryer MED9800TQ0
When I hit start it just reads sensing and nothing happens
SOURCE: Whrilpool Duet Dryer - Model GEW9200LW0
The repairman just took the front off my dryer and cleaned the dust from the components, now it works just fine, and I had the same problem as you.
Posted on Jul 18, 2008
ginko
  • 19396 Answers
SOURCE: Maytag Dryer #MDE4000AYW
Try first unplugging power cord from the appliance, this will drain power from circuits and reset it.
Check the door latch sensor, if that is stuck the door sensor will not let the machine start.
Keep pressed start button for 10 seconds or so, on some dryer this reset the machine.
If it still does not work then there is an internal fault , probably the timer assembly must be replaced.
If you need to call a technician you can use the number listed on the owner manual.
If you want to do it yourself, test the timer control, then if it is faulty replace it.
You find replacement here.
Posted on Sep 18, 2008
SOURCE: Whirlpool Cabrio dryer won't start - the "sensing" light is on
where are the answers on those stupid site
Posted on Oct 21, 2009
SOURCE: G.E. WHIRLPOOL DUET DRYER MOD.# GEW9200LW0
for gew9200lwo the problem control locked
Posted on Jul 06, 2010
SOURCE: Another Whirlpool Cabrio Sensing issue
Hi-- none of the solutions I've read here are working. Same problem, dryer not starting, it says "Sensing..." and then "Wet" and does nothing. It worked fine on the last load, except I noticed it read 11 minutes for a very, very long time (I think it got stuck). New load? "Sensing..." etc.
Posted on Aug 02, 2010
Maytag Epic dryer model MED9800TQ0. Dryer was running fine, changed loads, held the start button down, it beeped and attempted to turn the drum, clicked and nothing. All the controls light up, timer...
does the element come on at this point ?
I'm not sure if you tried this already or not, but i would unplug the unit and wait a min and plug it back in and see if it resets and then works again . you could have had a power surge .
Nov 05, 2013 | Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size...
Dryer only runs while holding start button in
We have a Maytag Epic dryer with the same problem (Model MED9800TQ0). Pulled out the control board yesterday and saw that the weld had been blown right at the motor relay (burnt marks surrounding the area on the flip side of the board where the relay attaches). Do you suggest we replace the motor relay or just try to re-soder that part on the board? Also - should we be concerned as to how this happened (that it was something elsewhere that caused it to blow)?
Jan 16, 2013 | GE Dryers
I Have a Maytag Legacy MED5570TQ0 electric dryer.. The dryer will not start.. I turn the dial and hit the start button, but nothing happens.. I believe it is either the swich at the door or the start...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 20, 2011 | Dryers
Maytag dryer wont turn on i hit the push button and nothing happens i have light on in drum when i open the door any ideas of what it can be
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 11, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
PF reading - wont run when hit start/pause pad
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jul 08, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer will not start cycle
Feb 18, 2010 | Whirlpool GEW9250 Electric Dryer
Mar 29, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
GE W9200LW0
I would check the door switch first, I have seen the wires come unplugged, or ohm the switch
Jan 20, 2009 | Whirlpool GEW9250 Electric Dryer
My Maytag dryer won't start when I hit the start button
My dryer light comes on for my Maytag SDE4606AYW dryer when you open the door and I can hear the timer clicking but when I hit start the motor doesn't even attempt to start but there is obviously power. My dad just installed a new power cord to the dryer but this is a seperate issue as we were obviously unable to check the motor before we got a cord for it. He has years of electrical experience so I'm assuming he connected the new cord right. Any ideas on fuses in the dryer or why it may not be getting power?
Jan 15, 2008 | Maytag PYE2300AY Electric Dryer
Dryers Logo
62 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
