Question about Panasonic SC-HTB770
Sa-btx70 no power. How do I open the main unit .
Unit doesn't open with remote or on the unit Panasonic sa-pt467
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
Dec 24, 2015 | Panasonic Audio Players & Recorders
Panasonic sa-pt770 will not power on
When power is applied do you get any LED light or display that shows?
Dec 27, 2014 | Panasonic Sa-pt770 Receiver
My SA HT 730 displays INIT on main unit and tray will not open. Can you help me? I love my panasonic.
INIT = Initiate, reason why you cannot open it is because it is having an error starting up and it is not completing
Oct 20, 2014 | Audio Players & Recorders
Panasonic dvd home theatre system SA-HT520. My 2 year old was playing with buttons on dvd player and now when i press open/close button it is saying locked and won't open, is there anything i can try...
The system has a locked / unlocked toggle sequence on the main unit by holding down stop (or Play) and then tapping the power button. Use this sequence lock or unlock the DVD / CD drawer.
Sep 29, 2011 | Panasonic Home Theater System System
Home theatre (panasonic SA-PT460) drive wont open makes some noise when i press the open/close button as its closing. I unscrewed the device and removed the dvd tray from its case as i pressed the...
I also have a problem with the drawer. It opens when I switch the unit on and when I close it - it opens again!
If I switch off at the mains the drawer remains open - to prevent dust ingress I have resolved to holding the drawer in whilst shutting down the power until I get a solution.
If anyone has a solution I would be grateful.
Sep 08, 2011 | Panasonic SA-PT460
HI i have Panasonic SB-WA330 sub woofer & speakers(no main unite) can i use this sub woofer & speakers with any other DVD player.thanx.
Not unless it's a similar Panasonic main unite. There's that pesky special connector "A" (so common on all-in-one products) to deal with.
The picture here http://www.forodvd.com/tema/97518-duda-usar-nuevo-ampli-con-altavoces-antiguos/ shows it requiring an SA-HT810 or SA-ST1 source.
Even beyond that speed bump, most stand-alone DVD players have no facilities for on-the-fly adjustment of volume. That is one reason why they make main units.
Sep 02, 2011 | Audio Players & Recorders
I cant eject cd/dvd changer.
there may be a lock/unlock selection in the menu somewhere, something like a parental lock on tv sets, this is just a thought on my part.
Mar 25, 2009 | Panasonic sa-ht930 Home Theater Audio...
Panasonic SA-HT520 error message
Sep 20, 2008 | Panasonic SC-HT520 System
Error f-61 on SA-AK640
F61 Power Amp IC output abnormal
Upon power on,
PCONT=HIGH,
DCDET=L after checking
LSI.
For power.
Press [STOP] on main unit for
next error.
Aug 23, 2008 | Panasonic SC-AK640 Shelf System
SA-21will not pull film strip into chamber
Put the film in after it is powered up. The unit needs to run through a power-up and calibrate cycle first. Once powered up, the until will feed the film in once it reaches a certain point into the machine.
The unit is supposed to kick the film back out when you close down the scanning software. If your film ever gets stuck try this to get it out. DO NOT force the SA-21 out of the machine with film stuck in it.
Aug 13, 2008 | Nikon COOLSCAN IV ED LS40
Panasonic SC-HTB770 Logo
91 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
