Question about Boating
Where is idle control adjustment on 8hp mercury outboard motor. I believe 1994.
2 Suggested Answers
Fame_Guru
  • 483 Answers
SOURCE: Yamaha outboard motor manual
You got it :
http://www.yamaha-motor.com/outboard/service/viewmanuals/outboard_manuals.aspx
here !
Posted on Mar 20, 2009
I have a 1978 merc 85 hp outboard with a bad pump i purchased a used one that works mine has 4 hoses
Mercury Outboard Fuel Pump - Mercury Outboard Forums
forums.iboats.com/Mercury-Outboards/Fuel-Pump
5, 2004 Mercury 225 four-stroke EFI no power to Low Pressure fuel pump. Why please help · Mercury & Mariner Outboards. 13, Mercury 850 (85hp) - Gas pumps through the top carb - Failed fuel pump? ... 1, 1969 7.5 H.P. Mercury (Bad fuel Pump)? ... 1971 · 1972 · 1973 · 1974 · 1975 · 1976 · 1977 · 1978 · 1979 · 1980 · 1981 ...
Fuel Pump Diaphragm replacement Mercury outboard 110 ...
? 4:18
https://www.youtube.com/watch?v=vufekxTVZd8
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel pumpissues...so in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
How to remove the lower unit on a Mercury outboard motor ...
Dec 01, 2015 | Boating
Why does my mercury outboard idle perfectly but stall out under load?
Your carbs are probably dirty. Remove the carbs and clean out all jets and passages with carbcleaner and compressed air.
Nov 13, 2014 | Clymer Mercury/Mariner 75-275 Hp...
Water got into the engine oil of my 8 hp 4 stroke when on the boat only as troller
Water gets in your engine through the exhaust with the boat speed! Lift that engine when not in use!
Oct 16, 2014 | Mercury Marine 8hp & 9.9hp 4 Stroke...
Does my 1979 johnson outboard charge the battery thru the powerpack?
Some models charged through a Magneto, but see if you can find the 1979 Year Manual. I have a 1979 engine myself in a 15Hp which is a Manual start(no battery) and I have a Sailhorse Johnson 8HP which has an electric port and is Manual start. I believe the 8HP would charge a battery as on a Sailboat the running lights needed power. The 8HP could power the lights directly.
Johnson offered options for electric start in lower HP units and options in charging systems to contain costs. You might get a better answer from someone by listing the HP of your motor. I was the original owner of the 15HP and remember the 9.9HP and others in the same Sales brochure. The Sales brochure may advertise more about the charging systems.
Jul 21, 2014 | Light Outboard Motor Boat Bass Fishing...
Have 115 Hp mercury outboard motor missing at full throttle and on idle. At mid throttle it is running fine. Any Idea what the problem could be. Thanks, Milton
Have your spark plugs changed AND carbs cleaned and adjusted.
Usually that can also be caused by a seized advance system ( plate under the flywheel, commanded to turn with the throttle linkage... )
Aug 16, 2013 | Seloc Mercury Outboard Repair Manual, 1965...
8hp johnson, 1999,plugs good, wires good,have put in new gasoline 50.1 mix, runs great at higher rpms. When cold start, it will idle at slow rpm. Once warmed up or a hot day, it will not idle when the...
have u tried to adjust you timming linkage? its on the side of the motor where the shifter linkage is try to turn the bolt in or out while running you may get it to idle better if the power pack was bad the engine would cut out at all speeds
Apr 16, 2009 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
23 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
