Question about Panasonic Televison & Video
Panasonic vcr hs 830 the rewind speeds up then slows down too much and takes ages to rewind the rest of the tape like 15 mins before the beginning of the tape
  • Panasonic Master
  • 1,511 Answers
Use an external winder.
Posted on Jan 22, 2015
5 Suggested Answers
  • 130 Answers
SOURCE: Tape is stuck in VCR- Fast rewind and forward
It may need to be cleaned. Mechanical problems are one of the big problems with VCRs they use alot of mechanical moving parts and play for so long they fail. Plastic parts dont help much either. The pinch roller takes up the slack and is usualy the part that fails first because it constantly runs along the tape and builds a coating on the rubber so it doesnt grip the tape and pull it back into the cassette. If its not pulling the tape back in then it hangs up inside and you cant get the tape out. Fastforward uses the reels to pull the tape not so much the roller. Try and stop 2 times then fast forward then eject the tape. Try and eject the tape while its fastforwarding so it doesnt do anything else. Sometimes machines will unload after its been in fastforwad a while then it will eject. You will hear a change in the sound when it unloads, you can hear the mechanical arms move the tape in and out of the cassette. Thats when you eject it. You cant really clean it till you get the tape out. YOu can clean the pinch roller with fingernail polish or paint remover. It is a wheel inside it looks like a black tire. It pinches the tape against the capstan arm this is why it developes a film or a shine on the rubber making it slip.
Posted on Apr 04, 2006
techman
  • 3130 Answers
SOURCE: Video tape gets eaten on rewind
Or the braking/tension mechanism is defective. Or the rewind clutch is defective.
Posted on Sep 01, 2006
dodgecharger
  • 254 Answers
SOURCE: VCR eats tape when rewinding
A couple of possibilities: 1. Braking problems: When VCR goes from FFWD, REW, Play to stop, there are a pair of "brake pads" engaged to stop the reels, and prevent tape spillage out into the machine. These pads, often rubber like, are on levers which contact one side of each reel. If you take the cover off the VCR, and look down where the tape is loaded, you will like see these brake assemblies. If the rubber pad is missing, or lever pivot points gummied up, then this is your issue. 2. Take up reel isn't being engaged to take up the tape on tape eject. When a tape is loaded into the machine, tape is pulled from the cartridge and threaded into play ready position. When eject mode is engaged, the tape must be pulled back into the cartridge, or you will have tape hanging out the front end of the cartridge, and may get caught on the VCR internals, or at least be mangled by the cartridge door. The often issue here is likely the idler assembly pivot point is sticky. This idler pivots, moving from the take-up reel (right reel) to the supply reel reel (left one), depending on what mode is selected. FFWD & play to the right, left for REW. If this idler is gummed up at it's pivot point, movement will be sluggish at best, and might not be engaging the right reel quickly enough to pull tape in before tape eject. This idler is sitting right between the reels down where the tape sits. A little light oil on the pivot point may be enough to loosen it up. Otherwise it might need to be removed and the old grease removed, and a drop or two of light oil applied.
Posted on Jul 10, 2007
sharcnet
  • 2130 Answers
SOURCE: VCR started eating tapes.
When a VCR eats a tape, it can be cause by a couple things.
1. There is a rubber wheel called a "pincher wheel" that compresses the tape against the "capstan". The capstan is a shiny metal spindle connected to a motor. The pincher wheel can become worn and/or dirty (slick) from the oxide coating off of the tape. You can try cleaning the pincher wheel and capstan with alcohol or try using a re-grip solution on the pincher wheel. Last thing to do is replace the pincher wheel. Look to see that the pincher wheel is doing its job by pulling the tape through.
2. There is a small tire wheel called an idler tire. This tire pivots between the sending and pickup reels of the player. Its also used during fast forward & rewind as well as play. If the tire is worn, the tape won't be wound up as fast on the take-up reel as the sending reel during play. This means more tape is coming out of the cassette than can be wound up on the takeup reel. You can try using a re-grip solution on the idler tire or replace it.
Let me know if you need more information as to where to purchase these parts.
Yes - There are cassettes available that are made out of clear plastic that allow you see what's happening. You can also trick the player into thinking there is a tape. There are sensors (mechanical & infrared sensors) that you can bypass.
- Jim
Posted on Jan 30, 2008
WHEN INSERT THE VHS TAPE TO VCR IT EJECTS BACK... WHAT MAY BE THE PROBLEM?
Hi, depending on the age, chances r that some components r worn out or the eye sensor needs cleaning or sdjusting.....
Jun 21, 2014 | Panasonic Televison & Video
E-2 error what does that mean
E2 means: Loading motor locked in the unload direction. Usually(not always) happens with a going bad VCR tape on the rewind. Tape is becoming too difficult to rewind and/or VCR is getting tired. Eject tape. Discard tape as soon as practical, new tapes are cheap. To clear: Hold power on/off button for 8 seconds.
May 09, 2011 | Mitsubishi HS-U575 VCR
How many motors are in the VCR section? example 1 motor for play, 1 motor for hi-speed rewind, 1 motor for hi-speed forward.
There are only 2 motors on the VCR sections.1 motor for the rewind backward and speed foward.1 motor for take in the VHS tape and eject the tape.The play button also used the same rewind backward and speed forward motor to push the film foward to the VCR play head head drums to play the tape.
Nov 24, 2010 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Getting E2 error flashing on vcr and can't rewind tape or anything.Don't have user manual to see what that error means.
Aug 28, 2009 | Mitsubishi HS-U445 VHS VCR
Tape will not play rewind or foward
in the vcr there are clutch disk pads in the gearing that wears down and or the belt is slipping or broke , it will need repair
Oct 11, 2008 | Mitsubishi HS-U447 VHS VCR
Mitsubishi vcr HS-U770
More likley it's not the little white thingy but the belt that drives it. Take the bottom off and get that broken belt out and runn down to the VCR / Tv repair shop and see if they have a new belt
Mar 07, 2008 | Mitsubishi HS-U770 S-VHS VCR
Loud noise on rewind
You may have an idler gear wheel which has been damaged- perhaps broken/worn gear teeth or something afoul in it's drive mechanisms. Check this idler which sits down in between the supply and take-up spindles. You should be able to see this with no tape loaded. This idler should also move freely from supply to takeup- if it is sticky in movement this could be the problem. If your idler is broken, you may be able to replace it. Check with a service center- or a parts supplier. MCM electronics is one such supplier- there are others.
Oct 01, 2007 | JVC HR-S3901 S-VHS VCR
Jul 09, 2007 | Mitsubishi HS-U781 S-VHS VCR
Commercial Advance feature shuts off vcr.
You need to clean the video tape path my freind, or the machine needs an alighnment. you can try to clean it with a head cleaner, and it might work, but most of the time you need to have it professionall cleaned. If you want open this http://www.bealecorner.com/trv900/trouble/cleaning.html, and it is about the same proceedture with a camcorder to clean a VCR, just take off the top cover of the VCR. Good Luck Please do not forget to rate this thread.
Nov 27, 2006 | RCA VR555 VCR
REWINDING PROBLEM
It could be that there is a separate motor for the rewind function, and it may be in need of replacement. Also you should check the belts for stretching/wear, as they have a direct impact on the speed. Also, most new VCRs have a function that the tape rewind slows considerably when it senses that its close to the beginning of the tape. Its very possibly that your VCR has a defect in that sensing mechanism. Good luck
Jan 24, 2006 | Emerson EV787 VHS VCR
Televison & Video Logo
37 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
