Question about HP LaserJet 2420 Printer
Usb My printer usb port is not working with any pc.
  • Anonymous Nov 02, 2007
    USB connection is not being recognized by any computer
  • 163 Answers
Please change the usb conector may be it is faulty inside
Posted on Sep 27, 2007
SOURCE:
I cant install printer usb port is damage
Which USB port Damage because there are two USB port available.
One is Printer USB port or Sec is PC USB port.
If you are say PC USB port not working first you check it USB driver installed or not, or USB connect to motherboard or not. PC there are two side USB available one is front side and sec is back side. You connect only back side, because this USB connect to main board. So you connect only back side. If not working removed driver or installed driver.
Or if you are say printer USB then change cable or port or not solved only change option.
Read More Help.. If you have USB or Network Printer and are having trouble printing and HP Tech Support
Jun 27, 2014 | HP PSC 1315 All-In-One InkJet Printer
Usb light link
HP LaserJet 1022 is a "host-based" printer so it must be connected to a PC. Load the driver on PC first and connect the USB cable when software tells you to do so.
Will not work on a Linksys print server.
LaserJet 1022N & LaserJet 1022NW have "special" HP print servers that can support HP host based printers.
Nov 27, 2013 | Linksys Wireless-G WPS54GU2 Print Server
Unable to get message from computer to printer. Message always appears : "Does not recognize USB port " I have tried all ports. Printer works as I tested on another computer.
Go to BIOS .For BIOS please press del or F2 button on your computer POST .After enter in the BIOS select on board devices or Integrated devices.select USB option and select AUTO option in Legacy USB devices if more than one USB Port then enable all USB port in BIOS.After that if printer not working then pls re-install the printer driver again.
Nov 16, 2009 | Compaq Presario S6000NX (DQ178A#ABA) PC...
Usb ports quit working on my hp netbook 1151nr mini
Recheck bios and verify usb ports are turned on.not sure how?just let me know ican walk you through this.RICHARDM69
Aug 24, 2009 | HP Mini Notebook
My pc won't detect my printer, my printer is brother dcp 150-c
have you connected the printer's USB port to your CPU? If not, then do so. If after doing it, still your PC don't detect your printer, make sure you have a functional USB port. To check it, try using a USB Flash drive if it works with your PC. If it won't, you might have to "Enable" your USB at your BIOS.
Regards!
Jul 09, 2009 | Office Equipment & Supplies
Trying to connect from USB laptop to parallel printer
You can't have a double hook up to it,When the parallel port is used the usb port is disabled and when you use the usb port the parallel port is disable.This is done to prevent damage to the printer.You can network the laptop with the pc and print that way though
Jun 04, 2009 | Brother MFC 7420 All-In-One Laser Printer
Printer is not working with my new a6742p pc
Yes. It should work fine, but there are a few IFs:
IF the printer is still good...you said it's an older printer. Also, does the printer have a USB port, or is it so old, it only has a parallel port? Some newer computers do not have serial or parallel ports.
IF you don't have a parallel port on the PC, and you have no USB port on the printer, you can purchase a parallel to USB adapter.
You also may have to go the manufacturer's web site to download the drivers for the printer.
IF there are no printer drivers for your newer Operating System, you are up the proverbial ******* creek. I have a hunch you are concerned about how to hook it up because of the above mentioned parallel - USB port issue. The adapter will fix that.
Good Luck!
Apr 07, 2009 | HP PSC 1350v All-In-One InkJet Printer
USB port problems with hp printer
use 2.0 ports and not less than that.if still nothing works out,check your port connections or that of ur printer.
Jan 03, 2009 | HP DeskJet 3745 Printer
Computer won't recognize USB ports
If you are plugging a USB device into a different port it takes some time to recognize and install it - it re-installs for every port. There could be cable and/or port issues as well. Plug the printer into a USB port that the mouse does work on and allow several minutes for it to detect install it.
Dec 18, 2008 | Dell Dimension E521 PC Desktop
HP LaserJet 2420 Printer Logo
47 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
