Question about Miller matic 140 Mig Welding Package W/As 907335
Wire feed motor will not come on. contactors pull in but motor does not turn.miller matic135
5 Suggested Answers
luxur4
  • 92 Answers
SOURCE: need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
Posted on Jan 23, 2009
SOURCE: Miller 130XP won't feed wire
need a replacement wire feed motor for a millermatic 130xp
Posted on Mar 21, 2010
luis_david
  • 407 Answers
SOURCE: Wire feed motor is not
Check wire speed potentiometer.
Posted on Dec 18, 2010
jyackle5
  • 8197 Answers
SOURCE: Miller S-22A wire feed.
Would like to know if you still need help. If you do not please do not reply to this post
Posted on Dec 20, 2010
My miller 175 wire feed does not feed wire at low number settings
Usually, the drive motor voltage is derived from the weld voltage, so if you lose, the weld voltage, the motor will not turn. Feed some wire out in a setting that works, then switch to one that doesn't feed, and see if the wire will arc. If you have a voltmeter, check for DC voltage at the polarity changover. Might be a bad voltage range switch.
Mar 30, 2017 | Miller Welding Tools
Miller deltaweld 652. Turn main switch on and you here a humming sound and the main contactor does not pull in??
Sounds like low voltage to the contactor. Reasons could be wrong input jumper settings for input power. Weak input three phase power. Bad control transformer (supplies power to contactor coil through the power switch). Just need to "dig" with a voltmeter.
Jul 09, 2015 | Miller Welding Tools
I have a 250 bobcat that stick welds just fine but when you go to wire feed and plug in suitcase box wire feed unit wire feeds but it doesn't get hot enough to melt the wire. LF299725
What model of suitcase? Could be the contactor in the suitcase, could be the mig gun. Are you using the CV setting on the Bobcat, instead of CC? Is the Bobcat on the high CV setting and the dial most of the way?
Apr 30, 2012 | Miller Bobcat 3 Phase Welder Generator...
Miller cricket 115 volt wire welder stock #909071. plug it in, it starts feeding wire...even when switch is off. where do i look?
The contactor is stuck closed, the trigger wiring in the cabinet is shorted together or trigger switch stuck closed.
Jan 09, 2012 | Miller Welding Tools
Dec 28, 2009 | Miller Welding Tools
Im working on a old Rheem pac unit with a faded model and serial number! When I arrived the condencer fan was running real slow and nothing else! One fuse was burned out in the pull box! The contactor was...
Fan motor is going out or the capacitor to the fan is bad I suggest replacement of both the fan motor and the capacitor which should always be done any time you replace the motor. Also check your wiring again you have a wire connected to the fan that is feeding voltege straight through to the motor. Your motor should have 1 black wire that goes to on side of the contactor 2nd wire should be white and it should go to the common side of the contactor (oppisite of the black) there should be 2 brown wires both of these should go to the capacitor. One of the brown wires may have a stripe on it if so it goes to the side of the capacitor that is marked if no stripe then it does't matter which side of the capacitor it connects to. Also check the contactor to see that the following hook up is proper. First the contactor has L-1 L-2 marking These are the voltage leads into the system from the power supply. Each side L-1 and L-2 should have 110 to 120 volts on each. Second on the top of the contactor there should be T-1 T-2 these are your terminal feeds the should feed the power to the unit and should have 110 to 120 volts respectivly. There should be 2 terminals at either side of the contactor that are your 24 volt feed from your transformer one connects to the left side of the contactor and one connects to the right side. This is the feed from the thermostat that signal the unit to come on. Good Luck on your repairs hope this helped you in some way
dave
Oct 20, 2009 | Heating & Cooling
Millermatic 200 won't weld
first check on the plate that tells imfo of unit ,there is what is called duty cycle.If the duty cycle says per say 30%,that means you can weld full power for 3 minuets before unit will shut down to cool.if it says 100% duty cycle there is no limit on weld time.this is the first thing to understand,if that is not the case check the main contactor where the power imput wires go,pull the gun trigger see if the contactor is pulling in , it should if not no welding amperage.
Jul 11, 2009 | Miller Welding Tools
Lincoln Electric Mig Welder-Fuse question
dont know what unit your uncle has but here is a easy test,open unit go to feed motor unplg the connector have unit running pull gun trigger check for voltage at plug ,if no voltage trace wires back (with the unit unplug , for your safety)probably will go to one side of main contactor.restart unit being careful for this is main input power.if no power main contactor is bad .if you have power at motor plug(wire feed motor) the motor is bad. hope this helps your uncle.
Jul 11, 2009 | Lincoln Electric LINK2400-+2 CV-305 MIG...
Renegase 180
This fault is typical in most MIG/MAG Units. the feed roller/s need slackening off, pull the trigger so the rollers spin wire the wire not moving, turn the tensioning 1 turn check to see if the wire feeds, if not give a half turn on the tentioner repeat this half turn untill the wire feeds, bend the wire to the torch and pull the trigger, If the wire feeds then thats the correct setting. be awear of all safety rules. use gloves
Nov 01, 2008 | Miller RENEGADE 180 WELDER GENERATOR MIG...
Miller matic 140 Mig Welding Package W/As 907335 Logo
53 people viewed this question
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
