Question about Neff Microwave Ovens
Neff microwave H 5574.0. Won't heat, and shows H95 message after about 2 seconds
SOURCE: Neff 5474.0/gb. When microwave time
After a bit of digging, it appears to be an issue with the door not being closed correctly (or at least the it thinks is isn't.
Ref:http://www.sampfordixl.com.au/gaggenau/upload/BM221130_instr.pdf
I know its a different model but the functionality is identical...
Posted on Jun 12, 2008
SOURCE: bosch micro wave error code h95
How to deal with error h95 code?
Posted on Nov 18, 2009
SOURCE: microwave starts as normal but cuts out after
This is happening due to either the magnetron, or the Power Diode, or both, is breaking down, under load, then the unit detects the fault condition, & then, for safety reasons, to avoid a fire or explosion, shuts down the system. You need to take it in to be looked at please obtain a "Quote" before proceeding with any work. This way you can decide to repair or replace.
Posted on Mar 24, 2010
Testimonial: "Excellent. Thanks so much for your very quick and valued help! Will do as you suggest and give further feed back on outcome. Again, Many Thanks. "
SOURCE: switching off after 23 seconds without heating
Hi Paul, did you get any answer for that?? My neff is giving me same problem.. if you know what is the solution can you please e-mail me to alinaseer1@hotmail.com? Regards
Posted on Nov 07, 2010
  • 8909 Answers
SOURCE: hi i have a neff
The magnetron is probably not working and the main board senses that.
Call an authorised repairer to fix it for you. There are no user serviceable parts in that section of the machine.
Posted on Feb 18, 2011
Panasonic microwave default code H95? What does this mean?
The magnetron has failed. Likely the inverter needs to be replaced as well. Best to just replace the entire microwave oven with a new one.
May 06, 2015 | Panasonic Microwave Ovens
The oven cuts out after counting down from 1 minute at 38 seconds and no heat
No heat is typically failed micro switch's that act as the door safety interlock. Remove the cabinet to find the tiny switches. Test them for proper action. Should show open or short depending on whether the door is open or closed.
May 14, 2011 | Neff H5642 Convection / Microwave Oven
Hi i have a neff microwave h5642nogb/02 when i switch it on to heat up food it cuts out after about 10 seconds can you please help
Feb 18, 2011 | Neff H5642 Convection / Microwave Oven
My Neff 900 is not working and displaying the H95 code .... what's the problem ?
It's nothing more than the door catch, remove the outer cover and adjust the switch. it's on a slot and that moves out of position. just pull it back in position ans nip it back up. simples!!
May 29, 2010 | Neff H5470 Microwave Oven
Microwave starts as normal but cuts out after
Mar 24, 2010 | Neff H5642 Convection / Microwave Oven
Switching off after 23 seconds without heating
Oct 31, 2009 | Neff H5470 Microwave Oven
Neff microwave oven not heating
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Sep 22, 2009 | Microwave Ovens
Bosch micro wave error code h95
Mar 28, 2009 | Bosch Microwave Ovens
Panasonic microwave no working at all
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
In Canada, you can find an authorized Panasonic servicer here.
Dec 27, 2008 | Maytag MMV4205 Microwave Oven
Error code H95
I would assume this is a Panasonic oven?
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Nov 24, 2008 | Neff Microwave Ovens
Microwave Ovens Logo
21 people viewed this question
Top Neff Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
