Question about Gateway Dx4850-45 Desktop Pc
Replace power supply
I was going to replace the power supply on this machine and when doing so I noticed that there is a little plug coming out of the power supply that when pulled apart looks like it has two little clear prongs coming out of it and it seems to lead to the blue ray drive I don't see one on the replacement power suppy or where I could hook this in to the power supply I was wondering if you could tell me what this plug is Thank you
2 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: I need to connect motheerboard to HDand optical drives
This WEB site will guide you in building a computer.
http://www.makeuseof.com/tag/the-idiots-guide-to-building-your-own-computer/
Posted on May 23, 2012
Hello all, My Problem: Tonight I went to turn on my PC and the machine was "dead" so to speak. No fans/drives attempting to boot up or anything, even momentarily, just a completely dead...
Most motherboards come have reset buttons on them, unplug and press the reset botton. Your power supply may be gone. Try replacing the power supply.
Jan 23, 2011 | HP Compaq d530 SFF PC Desktop
My e-machine will not turn on....I have put in a new power source, tried a different turn on switch, the power light on the mother board comes on but its as if it is just plain dead...no fans run when youi...
My sister had the same issue with hers. She said one day it died. I replaced the power supply, the little lights on the mobo came on, but the computer did not power up. Come to find out, when the "best-tec" power supply fried, it surged the motherboard and fried that as well. I replaced the motherboard and it works like a charm.
Feb 15, 2010 | E-Machines eMachines Desktop PC
The start green light on our dell dimension 9100 is blinking amber. I can turn off the machine and back on but machine won't boot up. Any ideas? span.jajahWrapper { font-size:1em; color:#B11196;...
If you see the boot screen, then it is a problem with your operating system (windows)
If you do not see the boot screen, then it is the power supply or the motherboard isn't working.
If it turns green but you never see the screen come on, then it may be the video or the monitor.
If it does go directly to blinking amber, it is probabbly the power supply. It should only take a little while for a computer person to plug in another power supply and test it.
You can actually take a power supply out of someone elses computer and plug it in (don't even have to mount it in the computer)
Plug in the motherboard plug(s) and the hard drive only, then attempt to start.
If it does work, it is your power supply, if not then it is your motherboard.
Jan 24, 2010 | Dell Dimension 9100 PC Desktop
The cord from the power supply isn't able to go into the proper place..there seem to be restrictions
Easy fix, look inside the plug on the console.
You will notice a small semi square tab right
in the midel of that plug . Take a screwdriver
and flex that square tab over and it will
break off and then you will be able to insert
the power supply plug , this little tab is simpley
to prevent the use of certain power supplys
but I snap them off all the time and plug in
my generic 175 watt power supply for testing
and never had a problem.
if you need more info ask
Rob
Dec 24, 2009 | Microsoft Xbox 360 Console
When start switch pressed, PC does not turn on.
It sounds like the power supply is going bad. I would try replacing the power supply first.
Dec 02, 2009 | Compaq Presario 5000 PC Desktop
Power light flashing
unplug the convergence yokes then try powering up the set. If it powers up the ICs are bad.
Jan 29, 2009 | Samsung HCL4715W 47" Rear Projection...
Tv wont turn on
Hi
Please go to ebay and buy your power supply board:
AKAI LCT3785TA POWER SUPPLY BOARD MLT386X
Oct 02, 2008 | Akai LCT3785TA 37 in. LCD HDTV
No start up , button lites up - cd-rom wont open , noticed no fans on for 3d card or big one on mother board
If the cpu/heatsink fan isn't turning then most pc's will shut down to avoid further damage to cpu & board. I would first replace the fan if it's the one over your cpu. Try replacing power supply. If your board has the 4 pin plug, you must have that plugged in. But keep in mind if that fan isn't running a new power supply isn't going to make it start working. You have to have that fan working. Then go from there. If once it is working & other devices like video and/or roms aren't, check your memory. The best way to troubleshoot devices are to plug one at a time in and power up until the problem starts. Hopefully you won't have to go to that step.
Aug 14, 2008 | E-Machines eMachines Desktop PC
Tried to turn it on, no powr. Replaced the power supply, little led on the mother board, but no power, no fans.
no beeps.
I tried 3 different power supplies.
I stripped out the memory and hard drive and put it in the dumpster where it belonged.
Steve
Jun 09, 2008 | E-Machines T2240 PC Desktop
Fisher and Paykel gwl11 want power on
Start of by replacing your drain pump. if there is still no response to the electroncs you will need another power supply. the pump took the electronics out. ???
Aug 02, 2007 | Fisher and Paykel GWL11 Top Load Washer
Gateway Dx4850-45 Desktop Pc Logo
27 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
