Question about Canon PIXMA iP1800 InkJet Photo Printer
Paper not feeding through properly - Canon PIXMA iP1800 InkJet Photo Printer
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 67 Answers
If paper ream was humid or the paper stick to each other then there can be a feeding problem. Loosen the sheets by ruffling the sides and put in the feeder, adjust the side aligners to fit paper snugly but not very tight
Posted on Oct 20, 2013
Paper won't feed properly- feeds at angle and jams. Printer indicates that it is out of paper.
"paper won't feed properly- feeds at angle and jams. Printer indicates that it is out of paper."
I am having the same trouble, what was the solution?
Oct 15, 2009 | Canon PIXMA MX330 Multifunction InkJet...
Paper not feeding thru properly
please the dumping roll and paper feeding pad is very celing and
who do use paper ? this paper is very glose papre ? if yes,
when one by one give up and second time
the paper is regulary use the friently paper and out of air in paper
and put the paper trey and use regulary ok.
Sep 25, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Getting u6-00 on arc172 checked all conectors switched m/c off/on no joy
the error code is for paper miss feed or tray not set properly make sure you have the paper cassette is put in properly and that the paper guide plates at the sides of the paper are set properly and the guide at the back is holding paper in tray correctly o-pen the paper tray take it out and check this and then reset open the side door and close it correctly and this should help reset youcan check the paper feed rollers as well as sometimes they get dirty and will not feed properly you can clean these with a little glass cleaner and a soft cloth good luck A
Jun 28, 2009 | Sharp Office Equipment & Supplies
Paper feed not working properly
1. first check to see if there is any bits and pieces of paper in any place in the paper carriage -- look very carefully in front access and rear access
2. if this is not the problem, then disconnect printer from computer -- turn off printer, unplug power cord, unplug printer cable from printer
3. gain access to paper roller assembly, usually in rear
4. using lint free cloth, dampened with distilled water clean rollers -- read manual to determine direction of rotation (usually clockwise)
5. keep rotating rollers until all is wiped clean of paper dust
6. reassumble and try a test print as your printer manual directs
Apr 22, 2009 | Office Equipment & Supplies
Paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper not feeding in order to print
make sure the input tray is properly setup and aligned, the tab is pushed against the paper.
Dec 12, 2008 | HP LaserJet 1018 Printer
On a Canon MP 460 printer, the paper will not feed in straight causing constant paper jams.
If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit.Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary and no more than three (3) times.
  1. Ensure that the printer is powered on and remove any paper from the Auto Sheet Feeder (ASF).
  2. Press the <Menu> button.
  3. Use the right / left cursor button to select [Maintenance/settings], then press <OK>.
  4. Use the right / left cursor button to select [Maintenance], then press <OK>.
  5. Perform the paper feed roller cleaning three times.
    1. Use the up / down cursor button to select [Roller cleaning], then press <OK>.
    2. When prompted to start roller cleaning, use the up / down cursor button to select [Yes], then press <OK>. (The paper feed roller cleaning starts.)
  6. Check if the paper feed roller cleaning procedure resolved the issue.
    1. Load a sheet of letter-sized plain paper in the ASF and open the paper output tray.
    2. Use the up / down cursor button to select [Roller cleaning], then press <OK>.
    3. Use the up / down cursor button to select [Yes], then press the OK button. (Paper will be fed.)
  7. If paper is not fed properly, repeat step 6 up to three times.
Oct 21, 2008 | Office Equipment & Supplies
Sharp EL-2196BL
Make sure that it is installed properly ... going under not OVER. Does the paper feed when the paper feed key is depressed ??
1. Lift the paper holder up.
2. Fold the leading edge of the paper roll 3 to 5 cm. (Do not fold it slantwise.)
3. Insert the paper roll from the left side of the paper holder and make sure the paper
roll is set in the proper direction (with the paper feeding from the bottom).
4. Insert the leading edge of the paper into the opening directly behind the print
mechanism.
5. Press the paper feed key and feed the paper under the edge of the paper cutter.
Dec 07, 2007 | Sharp EL-2196BL Calculator
Canon PIXMA  iP1800 InkJet Photo Printer Logo
old marine
old marine
