Question about Maytag Neptune MAH5500B Front Load Washer
Problem with samsung wf365btbgwr/a2 washer with nF code
Nf code and donnot continue to next cycle
Samsung Washer Error Code NF (Fixed ...
www.appliancerepairlesson.com/.../samsung-washer-error-code-nf-fixed/
Jan 11, 2014 - What does the error code NF mean on a Samsung washer? ... You can set the washer to any cycle and test each solenoid for proper voltage. ... Next would be to check the screens on the back where the water hoses connect. ..... Hi, you don'thave any power to the water valve wires when it should be filling?
Dec 15, 2015 | Frigidaire Affinity ATF7000E Front Load...
What is Nf code
Dits a no fill error so you probably need to replace the water inlet valve. The link below goes into it in more detail. Samsung Washer Error Code NF Fixed
Oct 24, 2015 | Samsung SW62ASP Top Load Washer
None or very little water filling drum, why?
You need to check your water inlet, hoses and filters for debris build up. If you live in an area that has hard water or you have older plumbing pipes in your house, chances are that you have a build up blockage. You want to clear all the debris first and see if you can replace the gaskets on the hoses with the type that have screens on them that will help protect the washing machine. If the problem persists after you clean the debris, you may have a blockage in the machine and will have to call a service professional. Hope this helps.
Oct 02, 2014 | Samsung 3.6 cu ft Front-Load Washer White...
FRONT LOAD WASHER samsung model WF338AAW/xaa
you need to sort this part out level sensor located near to the door switch and main board.
samsung boardpng-vn1wiordb5lxotmqu1or3lil-1-4.png wiring will be similar to this. might have a blocked air feed from the drum don't blow into the sensor take the clear pipe off and blow down that to make sure its not blocked, washing powered and stuff can block the line.
Jan 13, 2018 | Washing Machines
please see the cause and proceed to test the water inlet valve can be defective and replace it.use the common sense,see the diagram
God bless you
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
Sep 19, 2012 | Washing Machines
The code nf keeps coming up what does that stand for
NF(No Fill) code indicates that the washer is not getting enough water supply. Check if wwater supply is turned On and water is coming through the pipe. Then the fill valave can be clogged. t can become clogged with sediment over time
Stop the water supply and then remove the hose and then check for any clogs and if they are fine then in your case most probably your fill valve must have gone bad for this problem.Replacing it must solve the issue.
Jan 14, 2011 | Samsung WF337AA Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
