Plasma picture flickers then goes black? After I turn it off and on, it works again, but 5 minutes later it does the same thing.
    Top Expert:
  • Televison & ... Master
  • 74,243 Answers
Sounds like a power supply regulator board fault. check it. If Va or Vs voltages are not correct, this kind of fault can occur. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Posted on Oct 20, 2013
  • 155 Answers
SOURCE: Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Posted on Oct 26, 2008
  • 80 Answers
SOURCE: Screen lower half goes black/blank
The lower "Y Buffer" board is defective. Best repaired by a technician, or contact Phillips support for the part if you think you are able to replace a small circuit board on your own.
Posted on May 21, 2009
  • 556 Answers
SOURCE: Sony kdfe60a20 - The TV turns on but after a
classic Sony telling you the lamp is going bad. Replace lamp yourself it is consumer replacable.
Posted on Aug 11, 2009
maatmartin7
  • 1210 Answers
SOURCE: 47in Phillips-tv picture goes black still has
Could be the signal board has a bad cap, in this case it sounds like you are getting intermitten power to the inverters....when the tv goes down and of course you have audio....Shine a flashlight on to screen and see if you have a picture...look carefully. If this is the case..you have the above problem!
Posted on Nov 23, 2009
  • 19 Answers
SOURCE: Picture great then goes black
has to do with the main board like the other guy said go to www.shopjimmy.com way cheap and its that one cuz was told to me by the manufacturer you call tv repair man they give you all this **** it can be the power supply or the main board bring it so we can tell you just to get the money for checking it out go to this site get it but be real careful with the screen you can do it your self i did mines aint no science.
Posted on Apr 17, 2010
My Maxent mx-50x3 has a intermitten problem, when I turn it on, it does not have a picture, 5 minutes later it will flicker than a couple minutes more it has a picture while flickering, another ten minutes...
i had the similar problem. i'm not a tech but like to take stuff apart to find the problem. on my tv i took the back completely off. do not touch the boards. if you follow the power supply from the plug up two boards i found a small white adjustment screw. it was just up and to the right slightly from the plug. with a small screw driver i turned it slightly to the right and the flickering and delayed picture went away. couldn't tell you why it worked but it did. hope this helps, saved us $800 to buy a new tv.
Aug 20, 2011 | Maxent MX-50X3 50 in. HD-Ready Plasma...
Plasma tv takes time to start then picture flickers really badly then picture returns as normaal for a few hours then goes black but still has sound i turn off tv for a number of hours & repeat the...
This tv seem to have two problems.The problems that the tv take a long time the tv to turn on,the tv power supply board have dying capacitors most likely.That the board where the power a/c cord plug into it.The picture flickers badly this problems is harder to determine because this causes by two backlight buffers boards X,Z buffers boards could be either one it is dying.This tv should get an estamate by a shop or shops and repair it by them,bcause the tv must have to be doing replacing x munbers capacitors components to the tv power supply board and alot more work to trouble shoot and to detrmine which of the buffers boards it is the causes of to the picture screen to be badly flickers and replacing it.
Jun 10, 2011 | LG 42PX8DC Plasma TV
Toshiba tv screen goes black every 5 minutes with sound still on
Is it ok when you watch regular TV thru the cable or sat?
Jun 16, 2009 | Toshiba 46HM95 46" HDTV
TV Picture problems
My samsung did the same thing right before my color wheel went out. Can't be sure but that is what was wrong with mine. hope this helps.
Jan 25, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
My tv picture is dark and flickers
is there any spar, u observed inside the tv when it do like this.
Jul 05, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
BLACK SCREEN, AUDIO OK
I have samsung 40" LCD tv and it's happening the same thing. I turned it on and it last for 5 minutes and the screen went back but the audio is fine. I turned off and turned it back on it worked fine but an hour later it happen again.
Aug 27, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
LG LCD Tv picture goes black but the sound still works
Next time it goes dark do a flash light test to see if your inverter board is fubar.
May 03, 2017 | LG M4200C 42 in. HDTV-Ready LCD Television
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
