Question about OKI B930n Laser Printer
Initializing over and over - OKI B930n Laser Printer
I have a problem Taskalfa 250ci eror code c0640 I think at Hdd problem. But I don't know how to hdd format
Maintenance
item No.
U021
Memory initializing
Description
Initializes all settings, except those pertinent to the type of machine, namely each counter, service call history
and mode setting. Also initializes backup RAM according to region specification selected in maintenance item
U252 Setting the destination.
Refer to *1 of the maintenance mode item list about the item initialized.
Purpose
To return the machine settings to their factory default.
Method
1. Press the start key.
2. Press [EXECUTE] on the touch panel.
3. Press the start key. All data other than that for adjustments due to variations between machines is initial-
ized based on the destination setting.
4. Turn the main power switch off and on.
For errors occurred, turn main power switch off then on, and execute initialization.
Error codes
U024
HDD formatting
Description
Initializes the hard disk.
In addition, the following settings are also initialized by initializing the hard disk.
System menu (user login administration, job accounting, address book, one-touch keys and document box
etc.), shortcuts and panel programs
Purpose
To initialize the hard disk when replacing the hard disk after shipping.
Method
3. Press the start key to initialize the hard disk.
Description
Codes Description
01 Configuration initialization error
02 Counter initialization error
20 Engine initialization error
40 Scanner initialization error
2JZ/2JX/2JV/2H7-5
1-3-23
Apr 15, 2013 | Kyocera Taskalfa 250ci Color Copier...
Tip
How to Format an HP Recovery Drive
How to Format an HP Recovery DriveThe HP Recovery Drive is a partition HP puts on its hard drives for use in case the primary partition becomes corrupt or unusable. The recovery partition contains system files and the ability to boot and repair, format and reinstall the operating system if needed. For those who prefer recovery disks or who don't feel the need for the insurance of the HP Recovery drive, it can be formatted by following the steps below.
Instructions1 Open Disk Management by Right Clicking "My Computer" and selecting "Manage."
2 Click on "Storage" and "Disk Management."
3 Find the Recovery Drive partition. There are usually two partitions: the "C: partition" and the "HP_RECOVERY D: partition."
4 Right-click on "HP_RECOVERY D:" and select "Format."
5 Choose the File system and Allocation Unit Size and click "OK." The HP Recovery Drive partition will format and be available for your specified use
Tips & Warnings
Be very careful to not format the C: drive by accident.
on Dec 15, 2011 | HP Computers & Internet
Tip
How To Find Motherboard Drivers
How To Find Motherboard Drivers:
Here is a real world example on Fixya.com of some one having a problem getting drivers:
Question:
I need drivers for my FC GIGABYTE 8vm533m-rz motherboad
That is a some what a perfect question, the brand has been given and the motherboard modal number has also been given, so finding the drivers will be a peace of cake !
First of all, always go to the makers brand website, in this case we would go to Gigabyte's official website located here
Next, go to support & downloads;
Then copy and paste the motherboard modal number ( in this case is 8vm533m-rz )
From there we can get the drivers, located : HERE
locate the bios update: HERE
and that crucial mobo manual we all seem to lose: HERE
And that's the very basics, the same method would be used for every motherboard. Mostly all manufactures are happy to provide the drivers and support software on there websites.
Hope this helps some one out there.
on Jul 02, 2011 | Computers & Internet
Code to initialize ami rowe jukebox
For full initialization, in service mode, press 3 to enter init. sub menu, type 0 for full initialization. Press popular, then put switch in normal position and initialization will begin. You can still select and play discs while initialization is in progress, providing you select from cd's already finished. The machine will continue initialization after selections are finished playing.
Feb 02, 2013 | Wurlitzer Jukebox CD Player
Tekan tournament
Alternate Mokujin sounds
To hear different hit sounds for Mokujin, hold DOWN on the D-Pad or joystick before a match in which you are controlling him. Mokujin will now sound like a block of wood when damaged.
Arcade History Dip Switches
While at the Press Start screen for any of the Arcade History games, hold the select button and you will be given a list of dip switches. You can use these for such things as changing number of rounds or unlocking hidden characters, such as Baek in Tekken 2.
Choose Victory Animation
After winning a round and you see the replay showing, pressing each button( [X], [O], etc...) will result in a different victory animation. This also works when the opponent wins.
Play in 'Devil' mode in 'Devil Within' mini-game
This allows the player to play as Jin in permernent Devil mode without having his life bar drained out. The devil bar will be considered as his laser bar. The downside of this code is that it kills of you opponents faster thus unable to reach a higher combo rate.
Note: You must clear Devil Within under Medium difficulty. Then start a new Devil Within or Stage Select.
FOR THE BEST VISIT THIS SITE:
http://tinyurl.com/ydeuw6k
Nov 11, 2009 | Video Game Consoles & Games
Tip
Unlock Your Nokia mobile phone with Code Calculator
What is Unlocking?
Unlocking a mobile phone is the procss of removing any SIM Card or Network restrictions set on the phone by either the manufacturer of the phone or by the mobile phone's service provider. After unlocking a mobile phone, you can still use it with it's existing network or switch over to any other supported network.
Get free unlocking codes here
on Jan 10, 2009 | Nokia N95 Cellular Phone
SamsungX05 ınternet problem
Windows XP Latest Drivers Windows XP Previous Drivers Windows 2000 Drivers
May 15, 2008 | Samsung X05 Notebook
OKI B930n Laser Printer Logo
44 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
