Digihome LCD19913HD flashing blue and orange light on startup and shut down
SOURCE: Power is shutting down with orange light flashing on t
Hi, This is na very common problem with these Dell machines. I have found one of two things are the cause of this.
1. Your memory warms up once system is on for a while and fails to make proper contact on all pins, focing system shut down (after which only a power disconnect will restart system).
Solution. Carefully remove memory moduls and wipe copper contacts gently with a damp cloth after which you can replace the modules firmly. make sure power to the system is uplugged during the entire peocedure and give the system 5 minutes after putting modules back (just in case moisture from wiping remains).
2. Your PSU (main power supply) is failing. Replace PSU (cost around $50 at local IT shop).
cheers
Posted on Jan 13, 2009
SOURCE: WB 1TB blu light flashes but wont startup
1TB wb mybook just flashes a blue light when plugged in (upper light once a second)
Posted on Mar 22, 2010
SOURCE: Monitor power light startup blue
ou have a problem with your video card, take a look if is correctly connected and turn off the computer.
try to use your BIOS to reset it to the factory settings
Posted on Aug 11, 2010
walesarumi
  • 6993 Answers
SOURCE: Digihome 1996wd tv blue standby light flashing and
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Regards.
Posted on Jan 04, 2012
pjhislay1
  • 822 Answers
SOURCE: digihome 32822 blue standby light flashes but no piture tried all buttons and opened it up cant see any immediate problems
bad caps on power board.......
either repair caps or replace the board......
cheers
Posted on Nov 03, 2016
My gateway laptop N214 will not turn on. The orange light at the bottom of the screen flashes but it will not turn on.
Unplug the power cord. Remove the battery and hold the power button for 30 to 60 seconds. Re-connect the power and attempt a boot. Shut down, put the battery back in and you're good to go. This advice was on another site, but helped me with a computer startup issue once
Nov 16, 2013 | Gateway Computers & Internet
Laptop battery light flashing orange green
You can find a User Manual here: http://www.asus.com/Notebooks_Ultrabooks/U56E/#support_Download_30 For a explanation on the Battery issue. It sound like it's charging? As for the slowing down, If you don't do regular maintenance , your computer will slow. Also the more programs that Start up at boot will slow it down. If your Internet Browser is slowing down that another problem. There are many freeware programs to clean your Machine. 1, CCLEANER: http://www.filehippo.com/download_ccleaner/ This freeware program has many useful tools, the cleaner and registry will remove junk and free up HDD space. In the TOOLS section, select STARTUP, disable ALL unnecessary startup programs to speedup starts and running. 2, MALWAREBYTES: http://www.filehippo.com/download_malwarebytes_anti_malware/ In the install, UNCHECK the TRIAL PRO version, you want the freeware version, run a FULL scan, delete ALL results, reboot. Here are more tips: http://www.techrepublic.com/blog/10things/10-ways-to-speed-up-windows-7/3332
Apr 30, 2013 | ASUS U56E-BBL5 15.6in Laptop i5 2.3GHz 6GB...
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
The my book world has 3 different kinds of flashes.
1. Fast flashing (every 3 seconds) - Which means it's going into standby mode.
2. Slow flashing (every 5 seconds) - Which means it's in standby mode.
3. Alternative flashing between inner and outer ring - Means RAID failure (this only applies if you have the RAID compatible version [dual drive my book world])
4. Simultaneous flashing - Means the drive is overheating and the drive needs to be shut down.
Try resetting the drive, using the link below for guidance (this will not effect your data). If the drive does power-up, you will need to change the IP to static, if you had it that way before and you will need to login with the following login details: Username: admin | Password: 123456
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=1521&p_created=1172595028&p_sid=UhG4a-Sj&p_accessibility=0&p_redirect=&p_srch=1&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MSwxJnBfcHJvZHM9JnBfY2F0cz0mcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD0xNTIx&p_li=&p_topview=1
Jan 19, 2010 | Western Digital 500GB My Book World...
Problem on a canon 3100
The Power Light Flashes Orange - Error Codes When an error occurs, the power light flashes orange. The number of orange flashes followed by a long green flash indicates the cause of the problem.
Two orange flashes: Out of paper, paper jam, or paper feed error
If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing.
Three orange flashes: Paper jam
If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing.
Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink
Replace the empty BJ tank and press the Resume button to continue printing.
Five orange flashes: BJ cartridge is not installed properly
Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely.
Six orange flashes: BJ cartridge (printhead) is not installed
Seven orange flashes: BJ cartridge (printhead) is defective
Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge.
Eight orange flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing.
The POWER light flashes orange and green alternately: Service error
A service error means the printer requires the attention of a qualified technician. Count the number of flashes. (You may be asked this information.)
Feb 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Printer ripair
The BJC 3000 will flash two different colored lights in a pattern to signal several different errors. From the documentation I have the two colors are orange and green, could those be the colors you see? At any rate here is the code: Two orange flashes: Out of paper, paper jam, or paper feed error. If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing. Three orange flashes: Paper jam. If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing. Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink. Replace the empty BJ tank and press the Resume button to continue printing. Five orange flashes: BJ cartridge is not installed properly. Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely. Six orange flashes: BJ cartridge (printhead) is not installed. Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely. Seven orange flashes: BJ cartridge (printhead) is defective. Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge. Eight orange flashes: Waste ink absorber almost full. The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing. The POWER light flashes orange and green alternately: Service error. A service error means the printer requires the attention of a qualified technician. If you have any more questions let us know otherwise please don't forget to rate this post.
Feb 20, 2007 | Canon BJC 3000 InkJet Printer
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
