Whirlpool fully automatic
E1 error code displaying in whitemagic
3 Suggested Answers
  • 833 Answers
SOURCE: water is not flowing into the machine
There are a couple of possibilities:
  1. Are the hot and cold valves open?
  2. If there are filter screens in the lines, are they clogged?
  3. If set to warm, does any water flow at all?
  4. If there is no water flow, first check the water level switch to see if it is working...this is located on the bottom of the machine...it is generally round and has a tube running to the tub and two or more wires.  It should have closed contacts to let the water valve work.
  5. If there is some water flow, the valve is likely bad or the supply is clogged.
  6. If the switch is continuous, the problem may be the timer.
  7. Is the water temp switch good?...unlikely.
Posted on Dec 12, 2008
mohankumar63
  • 223 Answers
SOURCE: I get a "PE" error
As you said in the question you are washing machine is showing error "PE" it's not a big problem you are washing machine is just fine.PE means error signal due to low voltage .Machine resumes functioning after the voltage comes back to normal.Thanks for your question.
Posted on Jun 19, 2011
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    My air conditioner showing on the display is E1
    The E1 Error Code The most common reason for an E1 error code to be displayed on your air conditioner's front panel is to remind you that the unit's air filter needs to be cleaned. Many models will automatically notify you of this via an E1 error code display after the unit has been operated for a predetermined number of hours. For example, many Sharp models will display an E1 code after 720 hours of use. Alternatively, you could have dirt or moisture in your front button controls, causing them to stick or not function properly. This can be a common problem with many models of Haier air conditioners, but the issue is not restricted to any one manufacturer. Your air conditioner could also have a defective thermistor, which is part of the thermostat.
    For Samsung, the room thermistor needs replacing. This is a device that senses the temperature in the room.
    How to Fix an Air Conditioner When It Gives You an E1 Code eHow
    Jan 24, 2016 | Heating & Cooling
    I replaced circuit board in whirlpool combo microwave / oven, shows fault code F2, error code E1.
    Did you get the circuit board from a trustworthy place?
    It is a circuit board error. Did you install it correctly - right wires to right connections?
    Control displaying F2 E1:
    There may be a problem with the User Interface (Touchpad), or the associated wire connectors.
    Power unit down by turning off the circuit breaker(s) for one (1) minute.
    Power unit up by turning on the circuit breaker(s).
    Monitor the oven for one (1) minute to ensure the error code does not display again.
    Verify oven operation
    Have to go the long way to bring up the link by first:
    e1 f2 whirlpool oven Google Search
    and then click on https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjprvf2_7nJAhXKVRoKHe7zAmMQFggdMAA&url=http%3A%2F%2Fwww.whirlpool.com%2Fproduct-help%2Ferror-code-oven-f2-error-code-f2-e1%2FPH7389%2F&usg=AFQjCNFoDK8E-zgNHF3Kp4EoihGu1tbyEw
    Dec 01, 2015 | Whirlpool Ovens
    Error e1 during running
    try google with model# and the error code
    Jul 21, 2015 | Whirlpool Washing Machines
    I am having whirlpool washing machine model-whitemagic FSAN652 during washing machine suddenly stopped working and an error PE is displayed pl give me suggestion to rectify
    whirlpool have a good fault code list on the net
    go google and type in whirlpool top loader model------ and look for pdf version of manual or fault codes.
    Jun 28, 2015 | Whirlpool Washing Machines
    Whirlpool whitemagic pro 700h
    The model no is Whirpool whitemagic pro 700H fully automatic top load
    Dec 19, 2013 | Washing Machines
    I get a PE error code
    I get PE error code in whirlpool white magic F65
    Aug 12, 2012 | Washing Machines
    Code E1
    E1 or E2 Thermistor Failure
    The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
    When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
    When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
    Normal thermistor resistance values:
    60 degrees F. - 15.3K ohms.
    70 degrees F. - 11.9K ohms.
    80 degrees F. - 9.2K ohms.
    Take the top off the dryer and inside you'll find the "tech sheet." It has instructions for removing the front panel and locating the thermistor.
    Apr 21, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
    WP Touchpad does not work.
    The error code of F2 and E1 on your gas range is indicating a keypad failure or an Electronic Range Control (ERC) board failure. The ribbon connector on the keypad could be damaged or shorted. One of the buttons could be stuck or shorted on the keypad. There is a good possibility of a failed (ERC) board as well.
    I recommend having a service technician come out and diagnose which part failed and repair your range.
    Dec 18, 2008 | Whirlpool GS470LEM Gas Kitchen Range
    Display
    This is an error code, the error E1-F1 indicates that the Electronic Range Control/Clock has been blown. You have to get it replaced.
    Sgt 48
    Jun 04, 2008 | Whirlpool GR399LXHS Electric Kitchen Range
    Washing Machines Logo
    10 people viewed this question
    Top Washing Machines Experts
