Question about Bauknecht Dishwashers
Bauknecht wak 1600 ex/03 f07 - Bauknecht Dishwashers
2 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: Bauknecht washing machine WAK 1400 ex. Loud rattle
Have the drain pump connected off line and tested, if there is the nosie then open and clean well try to back flush by using a water from the reverse direction.
If the noise has susbsided then reconnect to cirruit and test with load.
If there is play in the impeller it can makea noise , you remove and grease the shaft to set it in, if noise is absent then might need to put in worn bearings.
Posted on Sep 19, 2010
Bauknecht wak 7508
There is a filter on the drain pump. You should clean it out and see if that is the problem. You can take the bottom panel off the front if this is a front loading machine. If not you need to lay the washer down so that you can see the bottom. Be ready for lots of water! The drain plug is large and it unscrews.
Apr 11, 2014 | Washing Machines
BAUKNECHT WA 709 SC
my BAUKNECHT WA 709 709 SC washing machine doesn't work what should I do? no one could fix it
Aug 27, 2012 | Washing Machines
What does f23 mean on the bauknecht wak 7310 washing machine?
It was being showing f12 before I disconnecte the wire on elements now is writing f23 and showing spans
Feb 04, 2012 | Washing Machines
Bauknecht washing machine WAK 1400 ex. Loud rattle in drain pump, but clean filter and no blockage. Impeller looks OK, spins fine dry. No odd sounds from motor without impeller. Is there a guide for the...
Sep 19, 2010 | Washing Machines
Hi, on my WAE8987 Washing machine, the fault code 'F07' keeps coming up, can anyone help please? thanks
Bauknecht are built by Whirlpool.
F7 on Whirlpool means flow meter failure.
Check water inlet, check the pressure switch, and check the sump filter at the bottom of the dishwasher.
To reset try turning on the power and holding the start button and the + and - buttons at the same time.
Dec 01, 2009 | Bauknecht Dishwashers
Bauknecht washing machine fault
Had the same problem myslef yesterday. Have rung whirlpool this morning and they advise that the code F7 refers to a short circuit.
May 27, 2008 | Washing Machines
Dishwashers Logo
24 people viewed this question
Top Bauknecht Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Andrew Taylor
Andrew Taylor
Are you a Bauknecht Dishwasher Expert? Answer questions, earn points and help others
