Question about GE GSH25JSTSS Stainless Steel Side by Side Refrigerator
Ge tcd18pad top part wont stay cool - GE GSH25JSTSS Stainless Steel Side by Side Refrigerator
How do I fix a switch on ge profile stove that stays on even though the element has cooled down.
how long did you wait as the elements sensors are below the top cover , and that will cool to touch first , but lower element is still warm , ive seen elements take up to 30 min to cool completely down after a full power use
if your looking to see how its wired then go to sears parts .com to see an exploded view of parts and were they lay
Mar 18, 2016 | GE Kitchen Ranges
What causes the coils behind the panel in the freezer to freeze up and stop the freezer fan? top half of freezer defrosts, lower half stays cold.Fridge is side by side and freezer fan keeps turning of
When the evaporator fan motor stops running the top half of the back wall of the freezer will frost over and the the only reason the lower portion stays cool is because cold air falls. More than likely you have a a dc motor fan and its bad, but be wary with ge, the main control board could also go bad causing the fan not to run.
Sep 05, 2012 | GE Refrigerators
The fridge is running and the freezer is keeping cold but the fridge part wont stay cold?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 27, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Its making a clicking noise from the control board in the back of the fridge. It wont stay cool any advise would be nice ty.
When the GE control boards start clicking they have gone bad and must be replaced.
Board cost approximately $150.00.
Sep 06, 2010 | GE Profile Arctica Stainless Steel Top...
My ge washer wont spin by itself. i have to take
it sounds to me like your motor is defective, maybe, just the start switch, but best to replace motor...Bruce
Oct 10, 2009 | GE WDSR2080D Top Load Washer
GE EVOLUTION Glass top. The hot surface(Glass top)
Individual burners, located directly under the cooktop glass, contain a temp sensor which lights up the hot surface lamp when they sense a hot condition. If the light stays on after all burners are cool, one of the sensors has shorted out. The sensors are an integral part of the burner, so the offending burner must be replaced to solve your constant on hot light.
Jul 01, 2009 | GE Kitchen Ranges
GE GMR04HASCS Problem staying cool
Your off/on thermostat control is sticking. Next time do not turn it off then on.
Take your hand a bump the control a couple times.
If it comes on, replace the thermostat.
Mar 11, 2009 | GE GMR04HASCS Compact Top Freezer...
Ge true temp stove top burner wont stay on
dont know how old unit is or how familiar you arewiththe unit, but the burner will need to heat up and cycle off/on. no matter how high or low you set the setting it will heat to a specific temp and cycle off, if hte burner remained RED all the time the glass would crak( so dont go by appearnce of burner, the glass should dictate the temp
Nov 10, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Fridge wont stay cold in the bottom.
Your frost free is not defrosting properly. There should be no ice buildup in the freezer section. Frost in the freezer section stops air circulation to the refrigerator section.
Jun 28, 2008 | GE Refrigerators
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSH25JSTSS Stainless Steel Side by Side Refrigerator Logo
29 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
