Question about Citizen Office Equipment & Supplies
Citizen cl s621 whether it takes dos commands
How to reset citizen cl s521 printer to factory defaults
1. When turning the printer on press and hold the MODE/REPEAT button.
2. Press and hold the FEED button for 3 secs.
Apr 11, 2014 | Citizen CLS521 Thermal Label Printer
Tip
How to hide files using the Attrib command
Attrib is a DOS command that sets or displays various file attributes. One of those attributes is the Hidden attribute, which determines whether or not a file can be viewed in a directory under normal circumstances. With the Attrib command, you are able to hide or show any non-system file, as well as view any file's current attributes.
To use Attrib, you must be at the DOS command prompt. In Windows XP, Vista, and 7, you can open a command prompt window by either typing "cmd" into the Run bar or by browsing to the Command Prompt (Start menu > All Programs > Accessories > Command Prompt). In Vista or 7, you can also type "cmd" into the Search bar.
The syntax for using Attrib to hide a file is as follows:
attrib <path><filename> +h
If you are currently in the directory where the file is located, you can omit typing the path. And since DOS is not case sensitive, you can use either upper or lowercase letters, or both.
If you later want to make that same file visible again, just type:
attrib <path><filename> -h
To view the attributes of all of the files in the current directory (even hidden files), type "attrib" by itself. Keep in mind that hiding a file will make it harder to find, but it does not by any means make it impossible. If you have sensitive or confidential data that should not be viewed by other users, protect it using encryption, permissions, and a strong user account password.
on May 30, 2010 | Computers & Internet
My Citizen CL-S700 barcode printer prints on every second label. How do I fix it ?
Somehow the printer is set to print two labels such as a shipping label and a return label. Rich
Sep 13, 2011 | Citizen CL-S700 Thermal Label Printer
I bought a CITIZEN watch from Dubai, UAE. The model number is EZ 6918-56. It has a steel finish bracelet and white dial. As there are many 'CITIZEN -FAKES' in the market, i just want to clear my...
Most counterfeit watches are designed to fool the casual observer, and as a result, the manufacturers focus on making the outside of the watch look as much like the original as possible. However, to save money, the inside of the watch (i.e., the movement) is usually quite different from what's in the original watch.
One relatively reliable way to check whether your watch is genuine is to remove the back and see what's inside. Is the inside of the case back stamped "Citizen"? Is there a Citizen brand on the movement (note: not all Citizen movements may be branded with a Citizen logo). For greatest reliability, I would take your watch to a jeweler who sells Citizen watches and pay them a few dollars to pop open the back and examine the movement. They will be able to recognize whether you have a genuine Citizen movement in the watch, and the peace of mind you receive may be well worth the $5 or so I expect they'd charge you for this service.
In addition to the movement, counterfeit watches with steel bracelets often have cheaper quality links than the watch they are copying. However, this is not always the case; as it's become cheaper to manufacture good quality watch bracelets, some counterfeits have watch bands that are just about as good as the real thing, and it takes an expert to find the differences.
May 31, 2011 | Watches
Where i can find the controls like command button and how can i find its code ?
dos commands
click start run you have to type cmd then type something in then press enter eg: regedit will take you into the registry or chkdsk/f is the check disk utility this is called DOS there are lots of dos commands to fix a computer
in xp
hope this helps
Mar 09, 2011 | Computers & Internet
How do you wipe the phone clean of all personal info. Hard wipe clean.
To perform a master/hard reset on your HTC S621 you will need to:
1. PRESS AND HOLD BOTH SOFT KEYS (Soft keys are the ones that are the defaults for Start and Contacts near the Green calling and Red end calling keys).
2. WHILE HOLDING DOWN SOFT KEYS, PRESS AND RELEASE THE POWER BUTTON, WAIT 3-5 SEC. (PHONE SHOULD POWER ITSELF ON BY DOING THIS)
3. RELEASE THE TWO KEYS SOFT KEYS.
4. WHEN SCREEN ON DASH LOOKS LIKE IT'S IN DOS FORMAT, PRESS SEND (GREEN ANSWER KEY)
Aug 09, 2009 | HTC S621 Smartphone
For Dos Command
Download a program called Belarc Advisor. There isn't a command that will allow you get the system board number from the DOS prompt without running a 3rd party application.
Jul 11, 2009 | Computers & Internet
How can I run a dos app without using a command prompt console?
vbscript should be able to do that you can swap between wscript ( which uses the gui ) or cscript ( which uses the command prompt )
May 07, 2009 | Computers & Internet
Run dos command through vb 6.0 without showing it
visual basic, on windows, right? jumping to dos, implies a command line, no? how else would you access a command line interface, if not through cmd?
Mar 20, 2008 | Computers & Internet
43 people viewed this question
Top Citizen Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tejodhar Atreya...
Tejodhar Atreya...
Roy May
Are you a Citizen Office Equipment and Supply Expert? Answer questions, earn points and help others
