Question about Acer Aspire SA20 PC Desktop
Motherboard password i have formatted the hard drive on a different pc. there was a password into windows and my son had forgot it. When I go into the bios on the acer it asks for a password so the password bios information is stored on the motherboard please tell me what the default motherboard password is. Then I can install windows. Please please help
  • 2 more comments
  • oliverchurch Sep 27, 2007
    I have tried various passwords into the bios. I cant get into the bios. However i will try again and think up a new password does it have to be numbers? Ta
    thanyou very much Im sure that will work. I had taken battery out so I was close. Your a star
    Thankyou very much. taking the battery out of the mother board and shorting the contacts solved the poblem. Windows is now installed. Sincere thanks god bless you.
  • Anonymous Mar 30, 2014
    i do not know the motherboard and therefor i cannot find the bypass password
    Novelist:
    Scholar:
  • 167 Answers
This password is stored in the somewhere in the BIOS. It is backed up by a battery. If you can open the system cabinet, try this: Find a small coin shaped battery(button cell), remove from its socket carefully. Now short the socket leads with a srew driver or something metal-like. After a few minutes (5) put the battery back in position. Start the system....you will see some error meaasge .... Something like "CMOS Checksum bad Press F1 to continue" Press the F1 key. It will load default values & cintinue automatically. The password is gone. If something goes wrong come back here.
Posted on Sep 27, 2007
    Genius:
  • 2,985 Answers
The password your sone has forgooton exists in a window set up only as long as it it operative. When a drive is formatted and the data expunged the password goes with it. Reinstalling windows and you need to create a new password if you feel that need at all. The Monther board has not password need via the Bios unless you choose to create one. It youignore the request for a pss word and it keeps coming back - think up a new one.
  • john ash
    john ash Sep 27, 2007
    Blue Hammer is right something I did not think off
    removing the battery leave out a while replace will put the board back to default and you can start over.
    Moreover unless you have a security situation
    Passwords are not actually a requirement in the Bios or operating system
    Merely an option if a need is fealt.
SOURCE:
Reset bios Toshiba Satellite C655-sp600l
Password on Hard Drive: you bricked the computer.
Password on Bios: you need to remove the battery (motherboard battery) for 30 seconds and place it again.
Password of Windows: You need to get a software tool designed to recover or reset/delete your Windows password
Jan 27, 2015 | Toshiba Satellite Computers & Internet
Wrong password
You Got to re-install the windows.
It will fix the problem but you may loose your data.
If you want to save that data you may install the new copy of the windows in another drive. You may get access to you previous's windows data in C:\users\<your username of previous windows>
You may copy that data in another drive and can format it after completely making the backup of that..
The Either of the above ways can be followed.
Jan 02, 2014 | HP Mini 1000 Netbook
Can't get past first screen
If you got Bitlocker enabled you need emergency USB to restore Hard drive password and if you have desktop PC you just need to reset BIOS jumper found on motherboard of PC and it will clear old password but if you have laptop BIOS password then it will be trouble to reset because laptops have Builtin chip of BIOS which need to be replaced by same model. Hope this will help you
Mar 12, 2013 | Computers & Internet
My disk D says me when I try to open it do you want to format? how Ican solve this
u have to install window 7 again in ur pc , If u install window 7 than bit locker again give u option to unlock the disk using password but if u forget ur password of bit locker then it give u another option to open it, and this opition is to fill the recovery key into bit locker if u saved it and it is different to all driver ,if u also do'nt have this than there i s no method to open the hard drive without formatting it
Jan 15, 2013 | Computers & Internet
How do i undo my system password?
System Password? No Such Thing!!!
The Three Types of Passwords are:
Bios Password - which is a password the comes up before the machine will even start booting. If you set this password, you should know it. The only way to remove a Bios Password if the take the laptop apart and remove the CMOS battery that is on the motherboard and let it sit for an hour or so until the computer completely loses memory of everything including the date, time, passwords.
Hard Drive Password - The hard drive password is set by the owner of the laptop to prevent thieves from getting to sensitive data if the laptop is stolen. 99% of the time if someone don't know the Hard Drive Password, then the laptop is stolen. If you're smart enough to set the hard drive password, then you should be smart enough to remember it. The real owner can sometimes set the password remotely once the laptop is stolen. The only way to remove the hard drive password is type in the correct password.
Windows Password - This password is associated with a user id that shows up once windows has completely booted up. If you forgot this password, it can be reset depending on the operating system.
Windows 7 requires a Password Reset Disc that everyone should take the time to create if they want to use a password on their user account. Without the disc that was created on that computer you won't be able to get in.
Windows XP and Vista - Turn off the computer, then turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Select Safe Mode and let the computer boot. When it comes to the login screen it will show the Administrator account and the user account for which you forgot the password. Click on the Administrator account and just click ok or enter for the password (hopefully you didn't create an Administrator's password and forgot it too). When you see the windows desktop in safe mode it will look differently. The icons will be bigger and the screen darker, but that is normal in safe mode. Click Start/Control Panel/User Accounts and select the user account for which you forgot the password, then select REMOVE PASSWORD, click OK and reboot your machine. This time let the computer boot up as it normally would.
Mar 25, 2012 | Toshiba Computers & Internet
Forgot pasword proteccion
hello
-password protection
there are different password protection in the computer BIOS password Hard drive password User password for windows
BIOS password: -you need to bring it to a local tech to have BIOS password removed
Hard drive password: -there is no solution for that and if there is it is very expensive
User password for windows: -you can follow the steps on the link below for different windows version.
"http://4sysops.com/archives/three-ways-to-reset-a-windows-vista-admin-password/"
Cheers.
Feb 24, 2011 | Computers & Internet
When i power on the laptop ask HDD PASSWORD SIR PLZ HOW CAN I REMOVE SIR
How to remove and unlock hard drive password? Is there any software to recover hard drive disk password? Where to download hard drive password cracker? Is it possible to reset the hard drive password?
According to Lenovo and many other manufacturers' website, if you forget your hard drive or hard disk password, there is no possible way to reset your password or recover data in the hard disk drive. Basically the hard drive is unusable. Scary right? However, this is often not true.
Most people are not aware that most hard disk drives have the ability to set a hardware password, just like the Bios password for motherboards, thus making the drive completely inaccessible unless a correct password is provided during the BIOS POST test. Usually these features can only be found in laptops, this is when you set a password on your notebook, the hard drive together with the motherboard becomes locked.
Most experts would say if you forget the original HDD or Bios password, there is no way of restoring it by generic system tools. Unlike the Bios password where there is a master key or with the removal of the bios battery, the password is erased from the flash memory thus the settings is restored to factory settings without the password, however, this does not applies to hard disk.
Jan 21, 2011 | Acer Computers & Internet
My son locked the hhd drive and he forgot password how do i unlock it
You can't unlock it without the password. Removing the hard drive and putting it into another computer will not work.
This feature is used to prevent unauthorized access to data on the hard drive.
The hard drive password is set from the Security setting in the BIOS configuration and you need the password to disable the password on the hard drive.
Nov 21, 2009 | Compaq Evo N610C Notebook
7020CT HDD2143B HARD DRIVE RE FORMAT
You may use a licence key to install a copy of windows on any pc as long as you own it and have destroyed the last installation.
so as long as you don't have either your win98se or ME product keys used on another installation then you can use whichever you choose to install on the pc you were given.
erch.
Mar 15, 2008 | Toshiba Portege 7020CT (P000272180)...
Acer Aspire SA20 PC Desktop Logo
108 people viewed this question
Ekse
Alun Cox
