Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC23 turbine head - is picking up debris and then spitting some of it back out!
SOURCE: turbine head of my Dyson DC08 does not spin
This response is likely too late coming, however for others the problen appears to be the same as the fault with my turbine head which was that the turbine fan had become loose on its spindle. With no pressure on the brushes, friction would allow the fan to turn and drive the brushes via the belt. The faulty part is not available separately however I have repaired mine using araldite glue. Other things to check is for a worn belt. Cheers.
Posted on Apr 28, 2010
  • 53 Answers
SOURCE: my dyson dc17 amimal's main turbine head is not
Right next to the power switch is a switch that will turn on/off the beater brush. Push firmly on this button and see if that turns it back on. It will turn itself off if it has too much resistance on it from getting tangled in something like a long carpet fiber that wraps itself around the beater brush. Check and make sure it's not bound up by something and then press the on/off button for the beater brush.
Posted on May 31, 2010
small6363
  • 18424 Answers
SOURCE: We have a Dyson stowaway
this link may help you
https://www.dyson.co.uk/support/help.asp?article=984&product=DC20-STOW-STD
Posted on Dec 28, 2010
DysonInfo
  • 107 Answers
SOURCE: hi how do you dismantle the head turbine for the
There are two (or is it three) plastic screws on the underside of it. This allows it to be partially split so you can clean the area around the brush roll.
To strip it further needs a Torx T15 bit, but I don't advise doing that unless you know what you are doing and are confident about the re-assembly.
Cleaning around the brush roll area is all most people need to do with these and that is a simple matter.
Posted on Jan 21, 2011
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: how many filters in the Dyson DC23 canister
    Hi Julie,
    In normal use, DC23's filter should be washed at least once every 3-6 months, as shown in the video below. Use cold water without detergent, and allow at least 24 hours for it to dry completely before replacing it.
    The HEPA post-motor filter does not need maintenance, and is designed to last the lifetime of the machine.
    If you have any further questions about using or maintaining your machine, please call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
    Best wishes,
    Jack
    Dyson Online Customer Support
    Posted on Jan 09, 2012
    How do i remove the brush bar?
    Hi there, it's Jack at Dyson.
    It's quick and easy to remove the brush bar from DC23's turbine head - there are two round catches to turn, and a slider catch to undo:
    Once you've removed the soleplate, the two brush bar sections pull out. You can then check the Turbine head for blockages, and carefully cut away any threads or hair taking care not to damage the bristle tufts.
    I hope this helps. If you'd like any further advice on using or maintaining your DC23, just give the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
    Mar 03, 2015 | Dyson DC23 Bagless Canister Cyclonic...
    How to I fix the stuck power cord on the Dyson DC23 Turbine Head Animal?
    Hi Saule, it's Jack at Dyson.
    I'm sorry to hear your DC23 Turbine Head's cord seems to be stuck. If there's an issue with the cord reel mechanism, your machine may need a repair.
    We'd be happy to help you arrange this, and will also be able to confirm if this is covered under your Dyson parts and labour warranty. Please note, we would advise against trying to repair the machine yourself in case damage is caused - if your vacuum is within our warranty period, this could also void any remaining cover.
    When you have a moment, please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU) to discuss your options with our experts.
    We'll look forward to speaking with you.
    Dec 20, 2014 | Dyson Zorb Mini Turbine Head, NEW Animal...
    How do I get a new belt to repace a broken one in a DC23 turbine head
    The Turbine head's belt is not a part we would ask a customer to fit, and therefore it's not available as an individual component. It's part of the turbine drive mechanism, and we'd advise against attempting to dismantle this as it could result in damage to the Turbine head. If the Turbine head happened to fail within the Dyson warranty period we should normally be able to replace it, as long as it's been used and maintained according to the User guide. Out of warranty, a replacement Turbine head could be chargeable.
    If you'd like some additional help or advice from our experts you're welcome to contact us directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
    Oct 07, 2014 | Dyson DC23 Turbinehead Canister Vacuum...
    Dyson DC23 canister vacuum turbine head stops spinning. Red on/off circle does not start the brush. If we cover the rubber 'u' gasket a tad, it will start spinning again normally. Putting the cover on does...
    Hi Jyn, it's Jack at Dyson.
    The rotating brush bar in DC23's Turbine head is powered by the vacuum's airflow. From what you've described, it sounds like there may be a blockage somewhere in the machine that's affecting the performance.
    To locate and remove any blockages, please take a look at our online Support guide and follow the steps shown on each of the pages: http://www.dyson.co.uk/support/dc23/dc23-animal/my-machine-is-not-working/check-telescopic-wand-step-1-turbine-head
    In normal use the pre-filter should be washed at least once every 3-6 months, using cold water without detergent. Even a filter that appears to be externally clean may still need a wash as fine dust particles may be contained within the filter material. The correct method is shown in the video attached. Make sure you allow the filter to dry completely for at least 24 hours before replacing it.
    We would advise against attempting to modify the Turbine head in any way, as this could cause damage not covered under guarantee. If you'd like some further advice from our experts please feel free to give us a call - our contact numbers are: 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
    May 23, 2014 | Dyson DC23ACTUSC Bagless Canister Cyclonic...
    Dyson DC23 canister vacuum turbine head attachment stops spinning.
    bearing inside the turbine has failed. cant be repaired you will need to buy a new one your local vac centre will have one
    May 17, 2017 | Dyson DC23ACTUSC Bagless Canister Cyclonic...
    Beater bars not turning
    I'm sorry to hear you're having difficulty with your DC23. This model doesn't include a traditional user-replaceable belt - the drive system is engineered to last for the lifetime of the machine.
    If your machine is a DC23 Motorhead, please take a look at the video above to clear any obstructions from the brush bar and cleaner head, and to reset the machine.
    If your DC23 includes an air-driven Turbine head, please follow the steps shown in our online Support guide to make sure everything is correct with your vacuum: http://www.dyson.co.uk/support/dc23/dc23-animal/my-machine-is-not-working/turbine-head-not-working-properly/check-the-plunger
    If you'd like some further advice from our experts after you've given this a try, please contact the Dyson Helpline directly - you can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
    If a repair or replacement part is needed, we'll be happy to confirm if this is covered under your vacuum's 5-year warranty.
    Best wishes,
    Jack
    Dyson Online Customer Service
    www.dyson.com
    Nov 18, 2013 | Dyson DC23 Bagless Canister Cyclonic...
    I've had my Dyson dc23 for about two years and
    The brushes wear down over time as you have noticed. they are easily ordered online. Google "Dyson dc23 replacemanet parts" there are a lot of retailers for parts. Find one that is local to you, you can either pick one up from a local retailer or order one and have it delivered. I found one for $24 here is the link for you;
    Dyson dc23. Don't know what the delivery charge would be for you as I don't know where you are. Ebay and Amazon should carry them also if you have premium account with either you may get them delivered for free. Good luck
    Oct 12, 2017 | Vacuums
    Dyson turbine head
    Hi Kevin, Alec from VacuumSpot here. Unfortunately Dyson don't actually sell individual mechanical components to their turbine heads, so even though it is probably a pretty easy repair you can't get the parts. In this case you will have to buy a complete new head.
    May 25, 2013 | Dyson Stowaway DC23 Bagless Canister...
    Our Dyson DC23 turbine head is not spinning as well as it should. We have dismantled the brush bars and they are now clean on the inside and out. And there is plenty of suction. The head does work properly...
    Call them, explain your problem and probably they will send you replacement part, at least they will describe what part is malfunctioning, and you can purchase on amazon or something, here: Amazon com Dyson DC23 parts I hope this was helpful. Have a nice day
    Aug 15, 2011 | Dyson Stowaway DC23 Bagless Canister...
    Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
