Question about Logitech Audio Players & Recorders
Logitech ls21 I purchased the Logitech LS21 speaker system yesteerday for my Acer Windows 8 laptop but there is no sound despite trying all connection methods - any suggestions?
  • 12 Answers
SOURCE: both rear speakers on my z540 system play only the left side rear
Hmmm, this sounds like either a driver issue, or a card/compatibility issue. you might try reverting to old drivers(last resort), making shure you have 4.1 enabled in sound control pannel(do this first), triple checking connections/connectors on both the speakers and the card(remember, you only have 5 speakers, not 8) and if you have the headphone-type phone plug for your speakers, you might try making shure that they are compatible with the jacks on your card, although, I would have to know more about your setup to be completely shure.
Posted on Dec 27, 2007
  • 45 Answers
SOURCE: logitech x-140 speakers
Have you connected both the power and the line in to the proper line out on the comp.
Posted on Jan 06, 2008
SOURCE: Connectivity of Logitech Z540 Speakers with laptops
huh?
Posted on Apr 06, 2008
SOURCE: speaker stops after a few minutes
I was having the same problem but I seemed to solve it by having the laptop volume maxed and using the dock to control volume. I think that it has a sleep function where if it is not getting a signal it powers off and for some reason the laptop isn't putting out a strong enough signal to keep it awake. Maxing the laptop volume seems to give it a constant enough signal so that the problem went away.
Posted on Mar 07, 2009
anjana03
  • 361 Answers
SOURCE: I purchases logitech S120 speaker system for my
check it is ok or not in another computer.
go control panel and click speaker and sound option look setin option and set it,
Posted on Nov 05, 2009
How do I raise volume on Logictech speakers Ls121
You mean LS21 speakers?
You turn the control on the separate control unit. I had similar Logitech speakers. I couldn't stand the hissss when they were turned OFF! I now have Bowers and Wilkins MM1 speakers which are amazing!
Amazon com Logitech LS21 2 1 Stereo Speaker System Electronics
Dec 17, 2015 | Audio Players & Recorders
I have an HP Laptop with Windows 7 and I have correctly set up my Logitech LS21 speakers, but the volume control does not enhance the sound coming from my laptop. The speakers work fine, but the sound is...
There are 2 volume controls on the audio output in windows 7. one is the system volume the other is the device volume. make sure that they are both at full and then control the sound volume on your speakers.
Jan 20, 2013 | Logitech LS-21 2.1 Speakers
I want the driver of frontech multimedia speaker model no.-1820
Speakers don't require drivers. Only your sound card. Connect as instructed. Usually the green 3.5mm port is the speaker input.
Oct 03, 2012 | Logitech LS21 3-Piece 2.1 Channel...
No green light on my logitech speakers
First and foremost, did you test those speakers at the store before you bought them? There must be an ON/OFF switch somwhere on those speakers. Or maybe, the AC cable is defective or loose. Try unhooking it from your speakers then hook it back. Or did you forget to plug it in the wall electrical outlet?
Jul 13, 2012 | Logitech Audio Players & Recorders
Logitech LS21 Speaker system
Please mention the fault on the system as there was no explanation
Dec 17, 2011 | Audio Players & Recorders
Does anyone there know how to wire a Logitech LS 21 speakers, meaning what wire goes where?
Improve the Fixya.com experience for everyone by voting!
The user manual has color set-up diagrams. Click on the following link for a copy of the current user manual and all the pertinent information.Official Logitech LS21 2.1 Speaker User/Installation Download
All the best,
Ben
Jul 21, 2011 | Logitech LS-21 2.1 Speakers
When i play music, the sound would come out from one speaker only. the audio jack seems to be fine, but do not know what is wrong. my model in logitec LS21
Hello
Try going to control panel,audio,settings.Make sure your speakers are set to 5.1 surround sound.
Next if there is software for these speakers or your audio device be sure it is also set for surround sound.
Apr 25, 2011 | Logitech LS-21 2.1 Speakers
I am running vista 32 bit on a dell computer. i have just bought logitech ls21 speakers. i have plugged everything together but the speakers don't work. in control panel/sounds/playback it says i have...
YES YOUR SOUND DRIVER IS NOT ISTALLED .
YOU ALSO USE THE INTERNET YOU DOWNLOAD THE NEW VERSION OF REALTEK SOUND AUDIO DRIVER AND THEN SOUND IS OPEN.
Apr 10, 2011 | Logitech LS-21 2.1 Speakers
I just bought the Ls21 external speaker system. They work but the volume is incredibly low and the sub doesn't work at all. Also it works without the plug being in. Very strange. Suggestions? Drivers? what...
OS these days are usually set up for additional hardware like speakers. But you should check the settings for the speakers from your computer first. To find out if the settings is the culprit, you can plug your speakers into another music player to test it. If the same issue arises, you may have to bring it back for exchange.
Regards
Mar 06, 2011 | Logitech Ls21 21 Stereo Speaker System 2 X...
Bas speaker has logiteck ls21 on back.sound has a
try this link
http://logitech-en-amr.custhelp.com/ci/fattach/get/329407/
if that doesnt get you there just go to logitech.com and click on support and it will lead you to there
Sep 18, 2009 | Logitech LS-21 2.1 Speakers
21 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
