Question about Konica Minolta Computers & Internet
Dialta di1611 ERRUR C500
2 Suggested Answers
  • 1297 Answers
SOURCE: Konica DiALTA Di1611 error message 2nd side door open although the door is closed.
Check and clean the sensors and actuators,verify the cable connection,verify if 5V appaire to red cable.
Posted on Apr 10, 2013
C500
first ensure the right side is closed (Section that exposes the drum cartridge) and that the latches are not broken OK with machine on take a paper clip end stick in the tiny hole on the right side of the control panel (From then on you can only use that paper clip:):):) for this procedure (Copier Tech humor:)) The paper clip is going to touch a small switch which turns the to several screens if its say abort that is ok what you are looking for is going to be on left side of the screen in the middle a small purple dot when you see the dot press 3 that will activate trouble reset it will still code out with your c500 code but now go to utility mode see the new button Maintenance touch it you will see trouble reset touch that machine will go thru the entire cycle again you will see the small dot DO NOT touch let it go to "Ready to Copy" if not you have a problem with fusing unit the Hot part DO NOT CONTINUE TO RSET you can catch the machine on fire have a tech come out a look at it.
Jan 31, 2014 | Minolta DiALTA DI2510F All-In-One Laser...
How can i reset my konika minolta 162 to function well which is writing service call and a code C0500
C500 fusing unit malfunction.Look at a liitle holle on the right side on display.Press the microswitch and wait will apeire * and press 3 and press trouble reset.
Jan 11, 2014 | Minolta DiALTA Di250 All-In-One Laser...
Konika minolta di1611 error xodes
You must be change the developer and the opc drum and drum cleaning blade.
Jul 26, 2013 | Office Equipment & Supplies
Apr 09, 2013 | Office Equipment & Supplies
Erreur code H4
press # interrupt C interrupt.then 14 then press copy.
Jul 29, 2010 | Sharp AR-5316 Advanced Digital Imager...
Porque sale error c0500 en la dialta 470
plz chek the thermostate heater unit fuse and heater lamp and clear truble button and relase this code c500
May 28, 2010 | Konica Minolta DiALTA Di200 Copier
Error code C0500
C500 is a fuser code, the hot part of the machine, the fuser fuses the toner to the paper, so that the toner does not smear off. But to solve this must have the model number. As each series of machine has a different way to reset machine
Jul 21, 2009 | Konica Minolta DiALTA Di200 Copier
Minolta Dialta620 copier error code c-0000
Code C0000 if a fuser motor failure.
Check to see if anything is damaged in the fuser (the thing that gets hot).
Also, check for a jammed transparency (if you use them).
Feb 10, 2008 | Minolta DiALTA Di620 All-In-One Laser...
Computers & Internet Logo
16 people viewed this question
Top Konica Minolta Computers & Internet Experts
Lawrence Oravetz
David Payne
David Payne
Tom Chichester
Are you a Konica Minolta Computer and Internet Expert? Answer questions, earn points and help others
